Hot Rods Mr Cheaters 32 ford truck build
Discussion in 'The Hokey Ass Message Board' started by Mr cheater, Jan 26, 2019.
  1. Mr cheater
    Mr cheater
    So it’s been pretty hot here lately like too humid to be out side along with getting all my unneeded possessions ready to go to Iola [​IMG] I finally got some paint on the frame[​IMG][​IMG]
    Hotrod1959, lucky ink, brEad and 7 others like this.
  2. Mr cheater
    Mr cheater
    [​IMG]Here we see Bob K’ s vice in action it’s really the only celebrity tie to this build [​IMG][​IMG][​IMG]just some random shots of the axel assembly be sure to use caution when putting in the king pins so you don’t break the shims [​IMG]picture of the frame ready for assembly [​IMG][​IMG]had some time to get the rear end put in
    rat bastad, lucky ink, brEad and 9 others like this.
  3. Roadsir
    Roadsir
    Nice work! Assembly for the last time always gratifying.
  4. Nice work, and that F100 is gorgeous.
    fauj, brEad, Mr cheater and 1 other person like this.
  5. Mr cheater
    Mr cheater
    IMG_0558.JPG IMG_0559.JPG IMG_0562.JPG IMG_0583.JPG just some pictures of where we are at now got the frame made into a roller and had to redo/ fix a few things and started to run brake lines IMG_0584.JPG had to shorten up the shock mounts because they interfered with the steering IMG_0586.JPG IMG_0587.JPG IMG_0581.JPG IMG_0592.JPG ruffing in the f-1 steering box. Up next I will mount the cab to finalize the steering box placement.
    lucky ink, Aaron D., AHotRod and 6 others like this.
  6. Mr cheater
    Mr cheater
    [​IMG]before picture of the fire wall [​IMG]and with a little work performed on it [​IMG]little trick I used to hold the patches in the holes[​IMG]and another view of the fire wall with more holes filled[​IMG][​IMG]got the cab on the frame. Me thinks it sits a little high in the rear end I am going to take a few leaves out of the rear spring.
    lucky ink, Stogy, Hotrodmyk and 8 others like this.
  7. Mr cheater
    Mr cheater
    IMG_0605.JPG IMG_0607.JPG IMG_0608.JPG IMG_0609.JPG IMG_0610.JPG pictures of the 32 Chevy dash I’m fitting in the truck IMG_0612.JPG IMG_0614.JPG IMG_0615.JPG monkeying around with seat placement and mounting the steering box
  8. lodaddyo
    lodaddyo
    Looking good! Always had a soft spot for those trucks. One day i might build one. Keep up the good work
  9. Mr cheater
    Mr cheater
    IMG_0635.JPG put the fire wall in and the mocked up steering box to set the length of the steering wheel shaft IMG_0633.JPG a view of the pitman arm IMG_0634.JPG my vintage Covaco steering wheel in place IMG_0636.JPG got the motor set in and the radiator set down
    lucky ink, brEad, Aaron D. and 6 others like this.
  10. Mr cheater
    Mr cheater
    816B344B-213B-42EF-B2C2-2D2366CBDF68.jpg CF8392AF-DA8C-4829-A102-5E4113B12584.jpg i forgot to include pictures of the modified steering box flange
  11. Mr cheater
    Mr cheater
    [​IMG][​IMG]got the drag link hooked up for the steering [​IMG]and the steering column put in
  12. Mr cheater
    Mr cheater
    In some ways I feel like I’m kinda jumping around on this project but oh well. Taking some time to do some rust repair on the doors[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]thats the passenger side driver side is about the same [​IMG]
    brEad, Stogy, tb33anda3rd and 4 others like this.
  13. Mr cheater
    Mr cheater
    So after finishing the doors I decided to tackle the back or the cab IMG_0899.JPG here is a picture of the bracing I put in the cab to keep everything where it should be IMG_0897.JPG the first cut IMG_0900.JPG and the second cut IMG_0902.JPG here is one corner cleaned up IMG_0904.JPG if anyone wonders about he stuff from United Pacific I’d say it’s pretty spot on IMG_0903.JPG and here’s a picture or the patch panels IMG_0898.JPG more to come later
    fauj, brEad, osage orange and 9 others like this.
  14. Mr cheater
    Mr cheater
    [​IMG]Repairing the sub frame rail[​IMG][​IMG]fitting the new cross channel [​IMG]the parts that will make up the new door pillar [​IMG]new door pillar welded up[​IMG]and fitted
    hfh, brEad, Stogy and 8 others like this.
  15. Tim
    Tim
    from KCMO
    Looking good!
    Stogy and loudbang like this.
  16. AHotRod
    AHotRod
    Your Trucking-right-along .... and I like the way your doing it.
  17. Mr cheater
    Mr cheater
    Took some time today to rivet the United Pacific panels in today don think I would have made it on the ford assembly line back in the day[​IMG][​IMG]after getting that done I got the back panel tacked in[​IMG]
    hfh, brEad, 32SEDAN and 4 others like this.
  18. Mr cheater
    Mr cheater
    hfh, fauj, brEad and 8 others like this.
  19. error404
    error404
    from CA
    Thanks for showing all the work! Great inspiration for my chevy :)
    loudbang and Mr cheater like this.
  20. Halfdozen
    Halfdozen
    Nice work. I like the idea of using the bellhousing mounts.
    Beautiful axle drop too.
  21. Terraizer
    Terraizer
    looking good
  22. Mr cheater
    Mr cheater
    So with the rust repair done the doors got put in the holes[​IMG][​IMG]and the box got pulled out of the corner and I saw my roadster[​IMG]here are some pictures of the box it’s really not in too bad of shape so I’ll try and fix it[​IMG][​IMG][​IMG]turns out sometime in my trucks life it got fitted with model a fenders [​IMG][​IMG][​IMG]
    brEad, Stogy, AHotRod and 5 others like this.
  23. Mr cheater
    Mr cheater
    [​IMG][​IMG][​IMG][​IMG]took a little break from rust repair and turned my radiator around so I can run a mechanical fan[​IMG][​IMG]some pictures of the radiator mounted to the frame
    lucky ink, Stogy, tb33anda3rd and 5 others like this.
  24. Tall t 26
    Tall t 26
    Just plane awesome. Moving right along. Doing a great job, its gonna be a neat little truck when finished. Thanks for sharing the process!!
  25. HotRod33
    HotRod33
    I like what you're doing....nice workmanship
  26. Mr cheater
    Mr cheater
    So once again kinda jumping around on the truck doing some work that only takes time and no money I started repairing the bed sides[​IMG][​IMG][​IMG][​IMG] probably should have shown how I made this part [​IMG][​IMG][[​IMG][​IMG]As you can see I have lots of welding to do
  27. Mr cheater
    Mr cheater
    Another part that had to be modified was the thermostat housing [​IMG][​IMG][​IMG][​IMG]took this picture from far away didn’t feel like showing my lack of dime dropping ability
    fauj, brEad, tb33anda3rd and 5 others like this.
  28. AHotRod
    AHotRod
    Fantastic vision, well done !
  29. Great build keep the updates coming.
