Technical Need gas
Discussion in 'The Hokey Ass Message Board' started by pull toy, Jan 3, 2020.
  1. pull toy
    pull toy
    Gonna ask a question that I know is not new but here goes. My Street Rod is powered by a 454 bb Chevy. The carb is by Edelbrock model 1404 [new] the fuel pump is also Edelbrock model 1721 also new. The problem is after setting for two days its a crank-crank situation to get the engine to light off. After first crank up it's fine for a day or maybe two. I've talked to Edelbrock Tech and they blame it all on gasoline evaporation. Adding a low psi electric fuel pump between tank and manual pump, to fill the carb, will not work since manual pump is diaphragm operated and not able to push fuel through it. What is my best solution economically and safely short of trashing the entire carb setup and going all EFI. Fuel tank is in the very rear of bed approx 11 feet from manual fuel pump.
  2. onetrickpony
    onetrickpony
    from Texas
    Have you pumped the throttle and watched to see if the carb was really dry? My old truck does not have that problem, even during the hottest part of the summer. One pump of the pedal to give it a squirt of gas and set the choke and it fires right up. But it's a Holley.
  3. big john d
    big john d
    from ma
    my off topic car uses a 4 psi electric pump and it moves fuel to the carb through a holley mech pump no problem
    seb fontana and olscrounger like this.
  4. OFT
    OFT
    Could you bypass the mechanical pump and use only electric? I've used that set up for close to 40 years in the OFT in avatar. Tanks are just in front of dually wheels in photo. In past have run BBC with blower, SBC with blower, BBC without blower and SBC without blower.
    Atwater Mike and chryslerfan55 like this.
  5. Mopar Tony
    Mopar Tony
    I'm assuming you are pumping the pedal while trying to start it?
    clem likes this.
  6. PhilA
    PhilA
    1. Hydro Tech
    I have a small off-brand impeller type electric pump that draws through fine when it's not spinning- I have it hooked up to the starter button. Put the shifter into gear, push button to prime the pump then into N to get it to fire up.
    My only concern there is that your motor would draw significantly more gas than mine in a full-throttle situation... the flow may be impeded too much via the electric pump. If it is vaporization could you not make a loop system, pump draws up to a pressure regulator that dumps unused fuel back to the tank and keeps cooler gasoline from the tank circulated round, leaving the only "static" flow from the regulator to the float bowl?
    Just thinking out loud
    --Phil
  7. Happydaze
    Happydaze
    Subscribed. I have exactly the same issue which I can live with but would prefer not to if the fix was simple. A phenolic spacer made no difference for me. Admittedly I've never checked to see if there's any squirt from the accelerator pump when it's sat for a while. I'm using a stock Chevy fuel pump but my understanding is that there's a non return valve in there, but it's not as if the fuel in the bowl can syphon back to the tank anyway. Stumped and participating!
    Chris
  8. pull toy
    pull toy
    Thanks so much for the input. Yes I do pump the quick jet but carb is always dry at first start up. It seems my best bet may be as Big John d said to change out the Edelbrock mechanical pump with a pump that would allow flow through and add a small psi electrical pump next to the fuel tank and re-plum between the two pumps with a hard line. All I would need then is a push and hold switch to run the electrical pump for a short fuel line power up time. The trick will be to identify the right flow through mechanical fuel pump. To run an all electrical fuel delivery system would work fine if a safety cut-off switch was added along with a fuel pressure regulator and a hard fuel line, since that Edelbrock carb doesn't like anything over 6 psi. Happy New Year to each of you and God bless.
  9. seb fontana
    seb fontana
    from ct
    Put a check valve between in and out port of electric pump, look up carter rotary electric punp installation instructions, page 5 or so..Works for all electric pumps..
  10. hotrodjack33
    hotrodjack33
    I found an easy fix for this same hard starting problem on my old '32. It had a 302 Ford, stock mech fuel pump, Edelbrock 1406 and inline filter between the tank and fuel pump.
    I added a second fuel filter (clear see-through type) between the fuel pump and the carb. It seemed to hold enough gas to start the car and I think it prevented any carb leak-down.
    chryslerfan55 and clem like this.
  11. ...have had that same problem, this new gas evaps so quickly, I usually just gave it a sip of primer gas in the carb, starts rite up then, runs a lil rough til carb fills, then no problem.
    hotrodjack mite have a solution there, worth a try.
  12. town sedan
    town sedan
    Maybe it's the "gas" its self.
    Do you have ethanol free gasoline available and have you tried it yet?
    -Dave
  13. blowby
    blowby
    from Nicasio Ca
    Same issue on all 3 of my mechanical pump carbureted shitpiles. Qjet, Holley DP and 97s, so not the carbs. I took an empty quart of oil, poked a hole in the cap, pushed a foot of vacuum line through and that's my primer gas. Put a hole in the air cleaner lid with a push in plug.
  14. My ‘30 Ford roadster with SBC, 3 deuces had the same problem after setting for a few days. I was also thinking of adding one of those small low pressure electric fuel pumps, K&N, that I could turn on to prime the system. Wondered about fuel restriction when turned off. Interesting discussion.
  15. flynbrian48
    flynbrian48
    I had an issue with my '34, 283, Offy 360 dual quad intake with the little 500 CFM E carbs, percolating the fuel in the bowls when hot, and hard to start after a few minutes because it'd be flooded from fuel in the intake plenum. After a couple of days, that too would have evaporated and then it'd do what yours is doing, which is quite a bit of cranking before it'd fire. All that was fixed with a couple of spacers I made from some 1/4" Lexan between the carbs and the intake. I don't know if this could be what yours is doing, but a spacer won't hurt anything. Gas with ethanol in it is the culprit, it has a lower boiling point. My intake was a contributor, with it's very low profile, held heat more than a higher based intake would. So I was told anyway...
  16. Moon50F3
    Moon50F3
    This is an interesting discussion. I have a 1404 on the SBC in my truck. Mechanical pump and same situation as the OP. It will fire up the next day or two after running it without even touching the pedal, but if I don’t drive it till next week, there’s a lot of cranking and some pedal pumping to get it started.
    BTW, I run the ethanol free gas.
  17. Hdonlybob
    Hdonlybob
    Don't mean to pile on, but same situation here with m 283. Shut off warm and sit for ~1/2 hour or so, and flooded...sit a week and crank a lot..
    May try that spacer idea..
    I have a high rev starter, so not really a problem.
  18. dirty old man
    dirty old man
    When I built BGII, my Hiboy roadster, SBC powered, I had planned to run a mech. pump.
    But when I went to drop engine in, I discovered that because of a pinched P&J '32 repro frame with "A" frt. cross member, the pump wouldn't clear the frame without notching the frame.
    So I installed a Carter elec. low pressure high volume #4070 pump and my Edel 2X4 setup accepts it fine without a regulator, pressure readings approx. 5 psi.
    After sitting idle for even weeks, all I do is turn on switch, listen for sound of pump to change, which tells me pressure is up, slowly depress and release throttle, hit the starter, and it usually fires before it makes more than 2 revolutions.
    This is using premium 10% ethanol and Stabil 360* additive at label prescribed mix.
  19. pull toy
    pull toy
    I do have a micro filter, screwed into carb as a final filter , I just don't see how gas could evaporate back between carb and pump with no open air exposure.
  20. pull toy
    pull toy
    Non ethanol is all I use plus a good splash of Seafoam.
    chryslerfan55 and town sedan like this.
  21. pull toy
    pull toy
  22. pull toy
    pull toy
    So you just hard line between rear mounted elec pump and carb no regulator. power wired through ignition switch with a safety oil pressure cut off switch, block off the mech pump port. Sounds workable my question is does the elec pump cycle or does it run continuously? Probable either way it does not matter but a high quality pump would be required for dependability since in my case in this coe engine requires major dismantling, seat, carpet,floorboard & engine cover for access. I confess some of my concerns is sealing the engine compartment up and running without quick access. I have complete confidence in the mech fuel pump because of it's dependable history. I have crossed every tee and dotted every eye trying to get this thing right and now gasoline is gone to pot..
  23. hotrodjack33
    hotrodjack33
    With the large filter between the pump and the carb, it would hold enough gas to fire the car and get the mech fuel pump going to keep it running went from 15-20 revs to start to 3-4.
    Another thing to consider are any rubber hoses or rubber connecters and hose claps. I've seen rubber hoses and claps that were fluid-tight (no leaks) but were not air-tight.
    Shooting in the dark on this one...
    Is it possible, with the carb sitting higher than your gas tank pick-up, that there could be some kind of siphoning going on? With the car shut off and no more fuel pressure, is it possible to slowly let air in the jets and start a slow siphon of the fuel bowl...and perhaps all the way to the tank? This scenario could also happen with a porous rubber hose or loose clamp. Just a thought.
  24. I have a 750 Edelbrock on my '32 with an Edelbrock 110 gph mechanical fuel pump.
    I installed a boat tank hand pump in line next to the tank for those dry starts, but I found out the only time I need it is when I run out of gas or work on the carb. The mechanical pump draws through the hand pump without issue. ;)
  25. pull toy
    pull toy
    First thing I'm going to do is add a check valve in rubber line north of the mech fuel pump to be sure no drain back of fuel to tank exist That way if pump becomes dry it will have to be evaporation.
    chryslerfan55 and hotrodjack33 like this.
  26. I have solved the evaporation problem that occurs if rod sits for a few days.
    I have sbc with GM mechanical pump. Carter electric pump on frame near tank. Toggle switch on electric pump.
    To cold start I switch on electric pump. Wait 5 to 10 seconds. Crank and gently pump pedal. Starts with 5 to 10 seconds of cranking. Switch electric pump off. Done.
    Phil
  27. Hot start flooding issue solved. Quarter inch phenolic spacer under carb. Do not touch pedal while cranking. Fires right off.
    Phil
  28. hotrodjack33
    hotrodjack33
    I think your idea of a check valve between the carb and fuel pump might be the best solution. Let us know how it works out
  29. pull toy
    pull toy
    Thanks for all the input, I'll post any progress results
  30. lo-buk
    lo-buk
    from kcmo
    I use fuel filters that have check valves built in so fuel will not siphon back to the tank. Works good for me.
    chryslerfan55 and Mopar Tony like this.
