Technical Is this spindle spent?
Discussion in 'The Hokey Ass Message Board' started by 1950fleetline, Jan 3, 2020.
  1. 1950fleetline
    1950fleetline
    Finally getting rid of the old huck drums and installing a disc brake kit on my ‘50 Fleetline, I couldn’t help but notice this mark on the spindle. What do you guys think?
    Replace or is this spindle ok to use?
    [​IMG][​IMG]
  2. BJR
    BJR
    Put the outside bearing on it and take another picture.
  3. The threads concern me more then the nic.
    how did it come apart?
    Can you put it back together?
    Did this come off driving car?
    if the hub but tightens up I would run it.
    Hnstray, X-cpe and 1950fleetline like this.
  4. flatford39
    flatford39
    I agree with the above...and would run it. It is a pretty easy repair if you have access to a welder though. I certainly woudln't throw it away.
    1950fleetline likes this.
  5. How does the bearing race fit?
  6. 1950fleetline
    1950fleetline
    The bearing seems to fit good.
    Thank you for the reply
    VANDENPLAS likes this.
  7. Greg Rogers
    Greg Rogers
    If it's easy and not real expensive to get another I would.
    Tri-power37 likes this.
  8. Kiwi 4d
    Kiwi 4d
    If the bearing has spun on the spindle you will most likely know when you do up the spindle nut and cant get the last little bit of play out before the bearing locks up. Equals worn spindle. We had this happen on a 32 , the PO must have had it spin.
    BJR likes this.
  9. 1950fleetline
    1950fleetline
    Yep, it came apart fine,
    I drove the car all last summer with no bearing noises, I’m able to tighten the spindle but without any issues, so I don’t think I’d have an issue with putting it back together.
    VANDENPLAS and flatford39 like this.
  10. I wouldn’t give it a second thought either
  11. Hnstray
    Hnstray
    from Quincy, IL
    I think that is a bearing conversion. IIRC, Chevys up thru about 1960 had ball bearings, not tapered roller bearings. Perhaps the OE bearing is the one that failed, leaving the divot on the spindle. In any case, it looks like it would work 'OK', if you think just 'OK' is good enough. As mentioned above, the threads are less than ideal.
    Ray
    bct, 1950fleetline and VANDENPLAS like this.
  12. BJR
    BJR
    After seeing the picture I say go for it. It should be fine and safe.
  13. brading
    brading
    Bin it and get a new one. Even if the bearing land was good the threads are knackered. Is it worth risking other peoples lives and your own for a few dollars
  14. If you’re worried about the threads,,,,,use a new nut .
    Some wear there yes,,,,but very usable .
    Tommy
  15. Rusty Heaps
    Rusty Heaps
    Unfortunately I scrapped a complete front suspension from my avatar. The city got on to me and I couldn't give it away locally. Fortunately there is a junkyard close by that has several should I have a need.
  16. harpo1313
    harpo1313
    from wareham,ma
    How do the threads look after running a wire brush over them? hard to tell in the pic.
    1950fleetline and 6-bangertim like this.
  17. 1950fleetline
    1950fleetline
    Always a bummer to put in a situation to have to scrap old car parts.
    Very cool that you have a local source for parts, really wish I could find a junk yard that had old Chevy parts locally!
    Btw the car in your avatar pic is awesome!
  18. 1950fleetline
    1950fleetline
    I cleaned the threads up and they didn’t seem too bad, got it back together with the new bearings and rotor just fine. Thanks for the reply
    Hnstray likes this.
  19. 1950fleetline
    1950fleetline
    Thank you everyone for the reply’s. Really appreciate the help!
    got everything back together with new bearings /rotor and new spindle nut as well.
    Hnstray likes this.
  20. BJR
    BJR
    Now drive the hell out of it!:p
  21. Pete1
    Pete1
    from Wa.
    After you crash and wipe out some other people, let us know how that worked for you.
  22. 1950fleetline
    1950fleetline
    Hey Pete
    I really appreciate all comments when I ask for suggestions on here, I really do.
    As for yours, I take it your suggestion is replacing the spindle, which I may just do.
    I can tell you comments are a lot more helpful without smart ass remarks. Thanks for being that guy though
    harpo1313 likes this.
  23. Pete1
    Pete1
    from Wa.
    With modern people, it usually takes "smart ass" to get their attention.
    I will buy you a beer sometime.
  24. Hnstray is right........at least up to 54 Chevs had ball bearing front hubs and that groove I'd bet was made by a collapsed or worn ball bearing.......the tapered roller should be fine as it spreads the load.........tho' the stub axle threads do indeed look a bit iffy.......lol...... andyd
  25. Smiffy
    Smiffy
    This may be a bit too late now as you may have already made your mind up I seriously suggest you replace the spindle. I was driving a car when the spindle snapped ended up driving down the road on my front drivers stub axle and fender trying to keep the car in a straight line as there were other cars around me as in early morning rush hour traffic. I was damn lucky the stub axle didn't dig into the ground who knows what would've happened then. Post mortem afterwards when surveying the damage it was discovered a slight groove in the snout may have led to a hairline crack developing then under constant vibration the snout let loose.
    For the sake of a couple of hundred bucks verses the very real potential to lose your car and maybe take someone else out isn't worth it.
