Technical Pancake Hood
Discussion in 'Traditional Customs' started by Jamoke, Dec 11, 2019.
  1. stanlow69
    stanlow69
  2. stanlow69
    stanlow69
  3. stanlow69
    stanlow69
    Hoods are ugly when in the raised position. So you pancake it. It eliminate the ugly hood seams when showing your car. For more of a smooth look. Scan0865.jpg Scan0669.jpg
  4. Rounding the corners would be a big improvement, i feel pancaking really only works on more highly modified front ends. It helps keep the lines. I know on out 56 Chevy the hood was pancaked to keep the front end flowing while still being able to have the hood up for indoor shows when going for points. Its a lot of work to do. since you have alot of re-engineering to do with stuff like the latch and filler panels. I think the biggest pain is that you are practically welding up the nose into 1 piece.
    Pre-pancake (1989)
    With pancake today
    Had to completely redo the hood latch system and build the filler panel on top of redoing the structure of the hood to brace it.
  5. DIYGUY
    DIYGUY
    from West, TX
    Hey Taboo, could you post a pic with the hood closed ?
    Going to do something to my 56 Fairlane.
  6. Noah*
    Noah*
    Took 3.5" out of it
    stanlow69, DIYGUY and williebill like this.
