I have a 1950 Chevy convertible all original with stock 216, 3spd, 6 volt, and 3.55 rear closed torque tube. I have a line on a 53 Chevy 235 with powerglide and 12 volt. I’m wondering if this swap is going to be worth my time and energy. At the end of the day if I do the swap it would still be a closed driveline. Would be nice to have a automatic trans Though. Any input or advice would be greatly appreciated. Thanks
Lots to consider when significant changes are done. I have owned a couple, and a rebuilt 235 will take a few amount of abuse. Unless you find a sweet (complete) closed shaft Power Glide set-up, I'd bolt the 235 in and keep driving.
Here's some info from a old Patrick's catalog...might help. Sent from my SM-T387V using The H.A.M.B. mobile app
^^^^^^^ Ditto I swapped a 1961 235" into my '37 Chevy coupe after I blew the babbited bearings on the 216 five hundred miles from home on a tour. That was back around 1985 and I drove the car 2k-4k miles every year for 34+ years with an engine with more horsepower and one that was more dependable. Do the swap- you won't regret it.
I have a '37 Chevy Coupe I bought last Spring. The prior owner liked to tour with the car and installed, what else, a '53 235 from a Powerglide car. He chose that model for two specific reasons, the primary being the full pressure lube/insert bearings and secondarily, the ;53 was the last to use the early style valve cover. The car was a prize winning restoration and he wanted to maintain the appearance of the OEM 216. Though the engine runs very well, I am pulling it in favor of a warmed up 250 and open drive line. In any case, you will enjoy the improvement in performance and durability. Ray
Being the Resident Contrarian , it is my duty to express the opinion that Powerglides, even the old cast iron PG, are fine for street cruisers. The OP's '50 Convertible will be plenty enjoyable with a transplanted '53 235/iron PG. The '53 parts car will provide all the needed bits and pieces to make it a bolt-in proposition. Ray
