Hot Rods Rich's Coupe - a ten year odyssey
Discussion in 'The Hokey Ass Message Board' started by Rich B., Nov 10, 2019.
  1. Rich B.
    Rich B.
    from Portage,IN
    Scotty: yea maybe I should, or they will
    only have X ‘s for pics.
    thank’s Lou !
    chryslerfan55, scotty t and loudbang like this.
  2. I found your pics!
    chryslerfan55 and kidcampbell71 like this.
  3. Rich B.
    Rich B.
    from Portage,IN
    You’re killing me Scotty, go pick one of those 5
    garages, and get some work done!
    Rich
    kidcampbell71, loudbang and scotty t like this.
  4. Rich B.
    Rich B.
    from Portage,IN
    1. [​IMG]
      Rich B.
      from Portage,IN
      A friend here on the HAMB (scotty t) sent me a link to a post on embossing that
      gave him the idea to to press Plymouth into his valve covers. He knew I did this kind
      of thing, and asked if I would give him a hand. Well hell yes! Here's a link to that post:
      http://www.hotrodders.com/forum/how-emboss-lettering-into-sheet-metal-207719.html
      It's a great post with good info, and I have done this in the past. With the 18 gauge we
      are using I like to use a female pattern, and use the polyurathane as the male die. Either way will work, I'm used to doing it this way. I'm just an amatuer, and learn something new on every project. Enough yakking let's get started.
      The pic below shows the pattern marked out on the valve cover. Below the valve cover
      is the 16 gauge pattern taped to a piece of 18 gauge to use a test piece
  5. Rich B.
    Rich B.
    from Portage,IN
    Here's another pic showing the above pattern, and blank turned over with
    the polyurathane on top. I like to press the area with the small pieces taped 024.JPG
    to them first. The P, and O require them to finish the letter shape. Doing
    them first locks them in so they won't shift while pressing. Than work
    back ,and forth over each letter to finish.
  6. Rich B.
    Rich B.
    from Portage,IN
    In the next pic I have moved the assembly over to my work bench, and am
    chasing the letters with a home made corking tool for better definition. I like
    to clamp either side of the letter I'm working on to prevent possible distortion
    of the surrounding metal. This is only the test piece, but I treat it like
  7. alfin32
    alfin32
    from Essex, Ma.
    Outstanding, congrats!!
  8. Rich B.
    Rich B.
    from Portage,IN
    Just to be clear the pic in the last post has the pattern under the test piece. It will
    stick to the pressed piece, and you will have to pry it off when finished. The pattern
    beneath the piece will keep chasing tool in place as you work it. Size the tool tip
    to just fit the pattern width of a letter. The tool is just an old chisel with a small piece
  9. Rich B.
    Rich B.
    from Portage,IN
    Here's the finished test piece. Doing the test piece will give you a feel for the amount
  10. Rich B.
    Rich B.
    from Portage,IN
    Ready to press the valve cover. I centered the pattern, and taped it to the cover. The small pieces
    of tape on P, and O are all that is needed. If 2 layers are used it will imprint the valve cover.
    The pattern should have all edges rounded or you are libel to get an edge mark imprinted
  11. Rich B.
    Rich B.
    from Portage,IN
    Here's how I had to set up to press the odd shaped valve cover. Notice the apron
  12. Rich B.
    Rich B.
    from Portage,IN
    This view shows the urathane with a heavy backup piece of steel used to
    press with. I have a 50 ton press with air assit that I added to it which makes
    repeated pressings much easier. I mounted the floor treadle on the side of the press
  13. Rich B.
    Rich B.
    from Portage,IN
    Here I have moved the valve cover to the work bench, and am chasing the
    letters. I have just finished the T, and am ready to cover it, and start on the U. 013.JPG
  14. Rich B.
    Rich B.
    from Portage,IN
  15. Rich B.
    Rich B.
    from Portage,IN
  16. Rich B.
    Rich B.
    from Portage,IN
    I of course stole Scotty's idea since we both have the same valve covers. Mine is
    a Dodge truck Hemi . This pic shows the finished test piece, the pattern, and
    the polyurathane that we used. That's McMaster Carr's stock number.
    I made both patterns with my milling machine . I machined common block
    letters in them, and than used a small air file to square the corners of some of
    the letters as was needed. They could be plasma cut, water jetted. In the past
    I have made patterns by drilling, cutting with small air saw, and lots of filing! DSC01181.JPG
  17. Rich B.
    Rich B.
    from Portage,IN
    This pic shows the pieces to back up, and press the covers. I surfaced one of
    the apron pieces in my mill, and also the cover piece. Care here will make a
  18. 54reno
    54reno
    Fantastic, Awesome work. Beautiful Hot Rod.
    nunattax, scotty t and loudbang like this.
  19. Rocky72
    Rocky72
    from Pa.
    What 54reno said . It's nice to see guys that take pride in their work .
    nunattax and loudbang like this.
  20. Rich did an awesome job on both of our valve covers. He did 100% of the work, the only thing I had to offer was a little tip that I found on the interweb. Rich's car has so much more detail than you can see in the pictures, he spent many hours on some of the smallest details, the fit and finish is unbelievable. There are so many little details that every time you look at the car you see something you hadn't noticed before.
    kidcampbell71, loudbang and Thor1 like this.
  21. sodas38
    sodas38
    Just great work here. Coupe is looking awesome!!
  22. -Brent-
    -Brent-
    The A is really coming along! Nice work, Rich!
    Great minds think alike...
  23. Rich B.
    Rich B.
    from Portage,IN
    Brent: I love that early gasser look! I like the way you covered the front mounting feet!
    kidcampbell71, loudbang and -Brent- like this.
  24. Rich B.
    Rich B.
    from Portage,IN
    Here's the dies I used to press the firewall. I cheated, and used my cheap
    mill to do most of thr work. Most of my projects were done with saws
    files, and hand tools.
  25. Rich B.
    Rich B.
    from Portage,IN
    The vin tag is pressed in from opposite direction. I saw pic on one of the cars from England,
  26. Rickybop
    Rickybop
    Sure is neat to watch a craftsman at work.
    Watching you lead... and your other work... reminded me of something.
    When I was a kid, my dad and I were having breakfast at a restaurant, sitting at the counter. We could see the cook preparing the meals. My dad told me to watch how he buttered the toast. That guy lined up half a dozen pieces of toast, and zip... buttered them all in one swipe! LOL!
    My dad said to me...
    Whatever you do... do it well.
    Rich, you're really good with the butter.
    Sent from my VS835 using The H.A.M.B. mobile app
  27. Rich B.
    Rich B.
    from Portage,IN
    The main design ready to press. You want to stretch the metal into the
    die not pull it from the surounding area. Don' forget the oil.
  28. Rich B.
    Rich B.
    from Portage,IN
    Sharp eyes will note the last pic is hot rolled with scale. I was not happy with my first
    pressing, and used some hot rolled to see what the problem was. It worked so well, I'm
    using it. You didn't really think I was done wih that firewall yet diid you!
    I'm using a firewall mounted pedal assembly, and want no flex .
    I'musing 1/8" plate which will be plug, and edge welded to the back upper half.
    There will also be support rods tieing dash, and steering column together.
  29. Rickybop
    Rickybop
    kidcampbell71 and loudbang like this.
  30. rd martin
    rd martin
    from indiana
    there is nothing rich cant do! hes the man with metal!
