Hot Rods Think'in about putting anti-seize on my sparkplug threads after........
Discussion in 'The Hokey Ass Message Board' started by 6sally6, Oct 30, 2019.
  1. 4wd1936
    4wd1936
    from NY
    How about di-electric grease, I've done it for years. Seems like a win-win.
  2. H380
    H380
    from Louisiana
    Up to 1800F. They make some nickle based stuff good to 2400F. Just like a glue stick.
    egads and loudbang like this.
  3. Boneyard51
    Boneyard51
    HRP, thanks for the memories! My grandfather, who never had a TV, saw this commercial on our TV and I guessed it caught his eye. He would say... wonder what would happen if I used TWO dabs..... then laugh his little chuckle. That was quite a statement from an otherwise very quiet man. I lost him in February 1962. Again thanks for the memory.
    Bones
  4. winduptoy
    winduptoy
    It is, that if you use antisneeze and don't break the plug, they don't get to sell you a new plug
  5. I think you mis-read bobss396's post, the same way I did at first. His post states that "NGK says to use" the anti-sieze paste. I think the word "never" is what threw us off-track. :oops:
    In other words, don't not never use the never anti-sieze paste, ever! o_O
  6. Boneyard51
    Boneyard51
    I read it wrong too!
    Bones
  7. RidgeRunner
    RidgeRunner
    from Western MA
    As well here. Not the first time I've let speed reading trip me and land azz face up!
    Ed
    Boneyard51 and loudbang like this.
  8. bill gruendeman
    bill gruendeman
    Your not using enough anti sieze if you don’t have it all over hands, tools and your shirt. I think the op broke the plugs by putting to much side pressure on the socket ( I have done it)
    '51 Norm, Boneyard51 and loudbang like this.
  9. 427 sleeper
    427 sleeper
    I only use anti-sieze on plugs that go in aluminium heads to prevent galling of the threads. I've also found that if you remove the rubber insert from the plug socket, you don't break anymore spark plugs.
    Boneyard51 likes this.
  10. deathrowdave
    deathrowdave
    from NKy
    I put that shit on everything !
  11. I use it too however I have one engine that the plugs for it have there own coating and specifically states no coating or oil.
  12. s55mercury66
    s55mercury66
    from SW Wyoming
    Another one who uses it on everything. The anti seize goes on before the threads go in.
  13. Yaaaaa.. you guys fell for it.....
  14. buick bill
    buick bill
    from yreka;ca
    ive had the same 2 bottles for yrs. and will have them for life! cause the brush wont reach the last 25% !!!!!
    Boneyard51 and 427 sleeper like this.
  15. deathrowdave
    deathrowdave
    from NKy
    Add a few drops of oil when it gets crusty and it starts the process all over again . A proven fact 2 table spoons will completely cover a battleship bow to stern , port to starboard , and every squids hat brim in between .
  16. noboD
    noboD
    I have put it on all spark plugs for about 50 years. Every repair manual I have read says to NEVER use it. I also have used it on every battery terminal I have had apart for 50 years. Stops corrosion. It usually winds up on your glasses and zipper, but not at the same time. As said above if it starts to dry out in the bottle mix in a few drops of oil.
