Projects And So It Begins
Discussion in 'Traditional Hot Rods' started by Piewagn, Jul 14, 2019.
  1. Piewagn
    Piewagn
    It’s funny because I didn’t do it intentionally. I bought the flatty and trans YEARS ago and the I picked up this coupe....it just seemed logical to clear up space on the floor. I’ll get to that stage probably in the spring. Thanks for following along!!
    loudbang and mctim64 like this.
  2. WTF really
    WTF really
  3. Piewagn
    Piewagn
    Of course just when I get ready to lay my engine and trans in place they decide to do a “restructure” at work and want to get rid of LOADS of gears sprockets and a whole bunch of other industrial stuff we haven’t used in ages and blew my spot up temporarily! BUT, I am still working on some things at home....
    Today is steering box rebuilding and some other odds and ends. I’m hoping to clear my spot out at work by the end of next week and get the eng/trans assembly in place. Hope you guys are havin’ fun thrashin’ away on your projects! IMG_1378.JPG
  4. Piewagn
    Piewagn
    Well, the tab from the star lock washer was missing so I just gave it a little zingo with the welder. Now I’ll just square it off with a file.... IMG_1380.JPG
    Tim, brEad, WTF really and 1 other person like this.
  5. Piewagn
    Piewagn
    I’ll be filling the box with the Lubriplate 105. Been using this stuff for ages in manual steering boxes. I use it exclusively in my Mercury Direct Reversing direct drive outboard lower unit gear cases...... IMG_1381.JPG
    waxhead and SquintBoy like this.
  6. Piewagn
    Piewagn
    Talk about motivating!! Big step! Now I can take my measurements and start on the mounts! YES!! IMG_1385.JPG
  7. Piewagn
    Piewagn
    I actually didn’t think I was gonna have this much space between the engine and firewall! Maybe a change of plans on the X member, l may be able to incorporate the existing crossmember somehow....we shall see! IMG_1386.JPG IMG_1387.JPG IMG_1388.JPG IMG_1389.JPG
  8. manyolcars
    manyolcars
    Do you think this stuff will be good in your U joint?
  9. Piewagn
    Piewagn
    Well, it’s a high pressure, water proof grease that also works at higher rpms in outboard gear cases. If you’re sealed up good! I don’t see why not.....
    It works great with straight cut gears....
  10. Piewagn
    Piewagn
    Put a set of wheels on the back to get close to ride height. I think I’m just about where I want to be! I still can’t believe I have that much space between the engine and firewall.....
    I think it’s time to start to get serious with the trans mount and the X maybe K type member. We’ll see how it goes once I start cutting and placing. I need to take some time and just stare at it, then clarity will set in and I’ll have a concrete plan. Thanks for following along fellas!! IMG_1390.JPG IMG_1392.JPG
  11. Dedsoto
    Dedsoto
    from Australia
    1. Aussie HAMBers
    Like what you're doing, looks like the body is sitting back about 2 inches though? Could explain the spare room at the firewall
    greaser and loudbang like this.
  12. Piewagn
    Piewagn
    Thanks!! It’s lined up with the mount brackets and bolt holes, right where it’s supposed to be....hey, I ain’t complainin’
    Dedsoto and loudbang like this.
  13. Piewagn
    Piewagn
    Finally painted my radiator since I had the 2 I bought repaired. We’ll see how the polished copper looks when it under the grille and the car is finished. I think it’ll look fantastic! The other one is available if anyone is interested. IMG_1398.JPG
  14. touring20
    touring20
    Great job !
  15. Piewagn
    Piewagn
    Thank you kind Sir! headed out to the garage now to get some other small things done.
  16. Piewagn
    Piewagn
    It seems you are correct Sir! Now I need to move the brackets forward.......this explains a lot!
  17. Piewagn
    Piewagn
    Been majorly sick! Blam! Hit like a ton of bricks! Finally feeling better...
    I started making mounts for the trans....I’ve changed my plans, you’ll see how it comes out when I get it tacked in place.... IMG_1442.JPG
    kidcampbell71 and loudbang like this.
  18. Piewagn
    Piewagn
    Ok, I’ve settled on this set up! Obviously it’s not secured yet, or diagonal braces in their final location. I still have to tweek it and finish up the other side, but I’m happy with this. After I secure the trans, I can locate the steering box and make the front mounts..... IMG_1462.JPG IMG_1464.JPG
  19. koolbeans
    koolbeans
    loudbang and Piewagn like this.
  20. Piewagn
    Piewagn
    Thank you! I was hoping to be further along than I am, but a bug really kicked my ass! Plus we've been restructuring our facility. I'll be able to cruise when we're finished and I'll have much more room!
    koolbeans and loudbang like this.
  21. koolbeans
    koolbeans
    I know the bug stuff. Me too. Rhino virus=cold. Well maybe, but took 2 months to fully recover. The stuff is bad!!!?!
    Sent from my XT1710-02 using The H.A.M.B. mobile app
    Piewagn and loudbang like this.
  22. Piewagn
    Piewagn
    Finished fabricating the trans mounts, got them in there loosely. I need to measure and set up final location and trim the ends of the diagonal braces, figure their final angle and location so I can hang my pedal assembly from them.... Some progress, slow but sure! Thanks fellas!! IMG_1472.JPG IMG_1474.JPG IMG_1473.JPG
  23. nunattax
    nunattax
    from IRELAND
    on the to do list,stock column with a 50s gm shifter grafted on ,auto shift.38 chevy truck
  24. Piewagn
    Piewagn
    I have located an F100 column shift/box set up. The grafting of a less dull shifter may be in order, thanks for the suggestion!
    loudbang and Rich B. like this.
  25. Piewagn
    Piewagn
  26. Piewagn
    Piewagn
    Got the main brackets welded in place! Now I can set my steering box location. I have a whole lotta figurin’ to do. I have some ideas for the mounting that I need to explore along with pedal assembly location. The column shift is going to be a challenge with the clearance available to the cylinder head. It’ll come together, just need to try some different options and see what works..... IMG_1489.JPG
    brEad, dehartcarl, Hotrodmyk and 4 others like this.
  27. Piewagn
    Piewagn
    Well, steering box quasi location. I will probably be able to get the column shift to work from this location, I’ll have to angle it in some for steering wheel to door clearance. It’s coming together slowly, but I’ll get there! If any of you guy have suggestions, please don’t hesitate!! Thanks fellas!!!
  28. Piewagn
    Piewagn
    I really would like to thank all those that drop a "like" on my posts, it is no small thing! It lets me know that folks are watching and keeping up with the build, although slow progress, it does motivate me keep pluggin' away! It has been exceptional mental therapy for me and just to know you guys are watching is GREATLY appreciated! So....here's a BIG thanks fellas!!
  29. Piewagn
    Piewagn
    Well....the column shifter will work out fine! I have all the clearance I need and with the box in this location it give me the perfect angle depth and clearance of column and wheel! I’m psyched!
    I made a temp bracket so I could remove the C clamps and make a template.....thanks for following fellas!! IMG_1527.JPG IMG_1529.JPG IMG_1533.JPG IMG_1535.JPG IMG_1536.JPG
  30. Mart
    Mart
    Why so low with the steering box mount? It's not like a mustang where that arm sticks up...
    Mounting close to the original location would be best, surely?
    There must be loads of cars with similar setups, what did they do?
    Mart.
    Steve Ray likes this.
