Hot Rods MODEL A COUPE CHOP QUESTION???
Discussion in 'The Hokey Ass Message Board' started by Nos1partstore, Sep 28, 2019.
  1. Nos1partstore
    Nos1partstore
    I just chopped 3 inches out of my 31 coupe. Now i am curious which area to start at to start tacking back together. I appreciate any suggestions from someone who has done this before
    kidcampbell71 and kadillackid like this.
  2. Budget36
    Budget36
  3. 41rodderz
    41rodderz
    from Oregon
  4. Corn Fed
    Corn Fed
    I would do the B pillars first. Then move to the A pillars. Then work the back.
    WB69 likes this.
  5. choptop40
    choptop40
    Second the motion on B pillars...
  6. Dino 64
    Dino 64
    from Virginia
    Did mine 3” as well, I started with the a pillar because it stronger, thicker gauge and it’s critical for alignment of the doors. That a pillar needs to vertical or the doors will difficult to get right. Then I worked the b pillar, then the t strip to get the rear of the top on line. I’d be the last one to say this is the best way, but it worked for me, just my 2cts.
    Sent from my iPad using The H.A.M.B. mobile app[/IMG]
  7. Looks great to me, Dean.
    Dino 64 likes this.
  8. brady1929
    brady1929
    The only comment that I can add is that they both look great.
    lothiandon1940 and Dino 64 like this.
  9. Dino 64
    Dino 64
    from Virginia
    Thanks Don :):)
    lothiandon1940 likes this.
  10. Nos1partstore
    Nos1partstore
    That looks awesome...thank you for the information
    Dino 64 likes this.
  11. scoop
    scoop
    Beautiful job,what tires are those?
  12. Tim
    Tim
    from KCMO
    Looks like excelsior sport radials. Judging by the box I’d say they came from coker
  13. Dino 64
    Dino 64
    from Virginia
    Good eye, thanks
  14. Dino 64
    Dino 64
    from Virginia
    Thanks@ scoop for the kind words :):)
  15. jbon64
    jbon64
    Lopped 4 inches out of mine. I started at the T strips and back window then around to the quarter windows then to the A pillars.Tack welds only , didnt take much clamping or ratchet strapping it all fell pretty much in place. 20191002_183306.jpeg
    Sent from my SM-A505U using The H.A.M.B. mobile app
    akoutlaw, lothiandon1940 and Dino 64 like this.
  16. Dino 64
    Dino 64
    from Virginia
  17. Dino 64
    Dino 64
    from Virginia
    Looks great Jeff !! ^^^^^^^
  18. Nos1partstore
    Nos1partstore
    Well, i did the A pillars, b pillars, then the rear....wasnt as hard as i thought....getting the doors to close flush may be a different story
    Just Gary likes this.
  19. Dino 64
    Dino 64
    from Virginia
    Did you have the doors on when you started the chop ? That would have helped keeping them in alignment. That A pillar too and bottom need to be vertical and at the same angle or the doors will be hard to get right. You can also use shims under the body mounts up front compensate
    Hope that helps, how much did you take off, looks good
  20. Nos1partstore
    Nos1partstore
    Sir, yes i tacked the doors in place and chopped everything at the same time. I did a 3 inch chop
  21. Dino 64
    Dino 64
    from Virginia
    My suggestion would be to put a straight edge against the inside of the A pillar after you clean up the welds. See if the top is aligned to the bottom.At the same angle. Hope that helps
    I like a 3” chop:rolleyes::).
