Technical Qjet or Edelbrock?
Discussion in 'The Hokey Ass Message Board' started by Scumdog, Oct 17, 2019.
  1. Scumdog
    Scumdog
    Ok, going to change the Smokey SBC in the ot truck.
    It already has Edelbrock manifold and carb but I also have a fully rebuilt Qjet and manifold.
    What would be best for drivability and economy?
  2. I'd use the Qjet. Just keep your foot out of it for fuel economy. Those secondaries can suck a gas pump dry.
    Nailhead Jason and Deuces like this.
  3. Never liked the q jets. I would use the Carter AFB
  4. G-son
    G-son
    from Sweden
    Whatever carb you can and will spend the time to adjust correctly has good chances of working well. The Q-jet was good enough for many car manufacturers for ages, so it's probably good enough for you too.
    belair, papadaddio and Deuces like this.
  5. Deuces
    Deuces
    Q-jet....... ;)
    papadaddio likes this.
  6. OLDSMAN
    OLDSMAN
    Edelebrock is my choice
    Montana1 likes this.
  7. carbking
    carbking
    No absolute answer, it depends on your desires.
    If your engine is mostly stock and you want maximum driveability, fuel economy, and horsepower as well as reliability; then the Q-Jet is the answer.
    If you want to be the koolest kat at the drive-in with the hood open, then, depending on the experience of the viewers, maybe the clone is for you.
    Regardless of which you choose, use a manifold designed for that style (spread-bore - Q-Jet, or square-bore - most of the clones). Never mix manifold styles and carburetor styles using an adapter.
    Jon.
    egads, Blues4U, arkiehotrods and 7 others like this.
  8. Q-Jet for sure. I have a so-so relationship rebuilding them, but a local shop does a great job on them.
    Deuces likes this.
  9. BJR
    BJR
    Q jet for sure. They came stock on Cadillacs and many other cars. If it was good enough for Cadillacs with 500 cubic engines it's good enough for me. Good drivability and performance.
    Deuces, bill gruendeman and belair like this.
  10. If it's going to be a hot rod, then I would choose the Edelbrock.
  11. Terrible80
    Terrible80
  12. Elcohaulic
    Elcohaulic
    Quadrajet.
    Never could tune that cornering stumble out of those AFBs. Our roads hear are very steep and curvy..
    What ever you chose, use the intake manifold that was designed for it instead of spacers..
    Deuces likes this.
  13. Did you find out what was wrong with the engine currently in it?
  14. carbking
    carbking
    RJP - just read your variation on the glass 1/2 full parable in your signature.
    The variation I like is:
    The pessimist sees the glass as half empty
    The optimist sees the glass as half full
    The engineer simply designs and builds a glass of the proper size.
    Jon.
  15. There is absolutely nothing wrong with a quadrajet carburetor as long as it's properly tuned and in good condition but they can be a major pain when it comes to rebuilding, not everyone can rebuild a quadrajet carburetor and get good performance.
    I have had good success with them in the past but since I am not one that want's to be fiddling with a carburetor I started using Edelbrock's more than 20 years ago and I have been well satisfied. HRP
  16. Tri-power37
    Tri-power37
    I have only used edelbrock carbs for 20+ years on a 58 Edsel and a 63 Cadillac -so I can not comment much about quadrajet carburetors. But the edelbrocks never seem to give any trouble especially after sitting for long periods .I started the Cadillac after sitting for 5 years this summer - dribbled some gas down the carburetor fired it up and drove all summer. Never gave any trouble. And that carburetor is 15+ years old.
    6sally6 and Montana1 like this.
  17. scrappybunch
    scrappybunch
    from nj
    Q-jet. And tune it with a wide band A/F ratio monitor. The part throttle ratio is easy to adjust. Fuel economy will improve.
    bobss396 likes this.
  18. AHotRod
    AHotRod
    Q-Jet for the Win !
    Been using them all my life.
    Deuces and scrappybunch like this.
  19. I ran in a stock car class, the rules were no Holley 4-barrels. I ran a Holley 2-barrel with success, but a lot of guys ran Q-Jets and the cars were fast. If they are set up right, they are as smooth as silk. Carter used to re-pop them around 1975 or so and the $$ was very right.
    scrappybunch likes this.
  20. Q-Jet would be the best all around, I believe. That is, if you like to tinker and tune a bit til you get it right for your application. Those things were used on everything from a 230 ci OHC six to a 500 Cadillac, so there's a lot of variations in them.
    Once you get it right, you shouldn't have to mess with it. The secondary flapper spring might loosen up after a while, if you use it a lot.
    Truck64 likes this.
  21. lostone
    lostone
    from kansas
    Qjet here too.
    Built them for yrs, everything from stock to dual qjets on a 350 tunnel ram.
    Played with edelbrock and quickly understood why the qjets replaced the afb carb.
    AHotRod likes this.
  22. 2OLD2FAST
    2OLD2FAST
    from illinois
    Qjet -one of the most efficient best designed ,most used and.....most disrespected , abused , maligned carbs ever built...
  23. Q-jet for a driver
    Holley for a drag car
    Idelbricks for carrying lawn chairs to the monthly cruise night
    INVISIBLEKID, jvo and Deuces like this.
  24. slack
    slack
  25. Scumdog
    Scumdog
    Nah, still taking it out of the truck.
    Vac modulator good, under valve covers clean so at the moment I suspect it's plain wore out.
  26. I would run a Qjet, but I’ve had great success rebuilding them. The only problem I’ve come across is the throttle shaft bushings getting worn out in the base plate.
    BJR likes this.
  27. BJR
    BJR
    X2
    Truckdoctor Andy likes this.
  28. Black_Sheep
    Black_Sheep
    I've always had good success with Q-Jets... 51357631_2004356099601861_8767528878349484032_n.jpg
