Technical Mystery motor needed ID please help
Discussion in 'The Hokey Ass Message Board' started by cb1, Oct 15, 2019.
  1. cb1
    cb1
    from Wisconsin
    Been awhile, but you guys usually know the deal,
    Going to an auction here shortly and may need to add this engine to my rack of motors, LOL. Not sure if industrial or old car. Auction site has no clue, and apparently seller either didn't know or care to let it out.
    Valve cover is about 2 inches wide, not sure how anything can work in there.
    Thanks for any help!!!
  2. ol-nobull
    ol-nobull
    Hi. 4 cylinder farm/industrial. Looks like the water pump is driven by shaft out the rear end of gen./alt. Has water hose from pump to lower radiator outlet and radiator inlet that huge hose coming out of the side of the block. Could be for a pump, welder, etc. Look around and see what farm/industrial equipment is also for sale that needs an engine. Jimmie
  3. cb1
    cb1
    from Wisconsin
    The more I study it, it looks to be overhead cam with some sort of bevel shaft drive in the front. Starter looks Ford tractor, so there is that.
  4. cb1
    cb1
    from Wisconsin
    I found it, Crosley cobra engine, circa 1948 ish..
    I was missing one word on by search, but found it!!,
    Now what's it worth? She must be a powerhouse in it day!
  5. cb1
    cb1
    from Wisconsin
    "The block weighs 14.8 lbs. The engine Powel Crosley is holding weighed 58 lbs. Complete with all accessories including flywheel it still only weights133 lbs."
    Looks like a great engine for my motorcycle build.... Just sayin,,
  6. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    One of the best 4 cly designes at the time for massproduction,had 5 mains and tower gear driven OHC,was kind of close to Offy in concept,out lived the car,to go on as reffer power unit + others an then as a outboard motor{ Homelite} ,was the main stay power for TQ midget racing tell into the late 1970s,plus lived as SCCA H-Mod racing all over USA.
  7. cb1
    cb1
    from Wisconsin
    thanks, serial number puts it into the latest production and cast iron block, so 30 more pounds. from what I read so far, could be industrial or military.
    dana barlow likes this.
  8. cb1
    cb1
    from Wisconsin
    Now I'll have to dig around the auction site for the tranny..
  9. cb1
    cb1
    from Wisconsin
    And there it is...
    Jet96 and kidcampbell71 like this.
  10. cb1
    cb1
    from Wisconsin
    Also, upon further review, looks to be a tin block, not cast..
    Speed Gems likes this.
  11. Boneyard51
    Boneyard51
    Better snag those! Could be some fun!
    Bones
  12. Blue One
    Blue One
    from Alberta
    You called it a motor and then later an engine.
    You seem really confused :D
    I don’t see a motor in the pictures.
    It’s beyond me why you have a rack of electric motors that you would store it with if you buy it. :confused: :D
  13. BJR
    BJR
    So the Ford Motor Company made electric motors?:p
    weps, Jet96 and Blue One like this.
  14. cb1
    cb1
    from Wisconsin
    Yeah, I know. Electric motors and gas engines and hot air balloons..
    But then I collect GMC trucks. General MOTORs Corporation, so I have an excuse...
    Probably not...
  15. RichFox
    RichFox
    The brazed sheet blocks mostly rusted out. That is why they were replaced with cast iron.
  16. studebakerjoe
    studebakerjoe
    Cb1, if you need parts for that transmission or another one they are still being made today. I think the company is called olympic gear or something like that. That t92 warner transmission was used in quite a few small tractors as well as other equipment.
    tractorguy and Hnstray like this.
  17. I had one of those that had previously been in a small boat.
    Hnstray likes this.
  18. Keep looking, you'll find it
    Blue One and Hnstray like this.
  19. arkiehotrods
    arkiehotrods
    A friend of mine has several Crosleys. He claims he can overhaul an engine while sitting at the kitchen table.
  20. cb1
    cb1
    from Wisconsin
    We'll, now I can't do a trike. Damn it..
    Nice trike
    cb1
  21. cb1
    cb1
    from Wisconsin
    Apparently, so high performance parts out there.. Nice
  22. Los_Control
    Los_Control
    from TX
    And then we talk about the people that are still married ... :D
    Not saying it is bad, just saying my wife has a opinion on this :p
    Texas57 and arkiehotrods like this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    There were some speed parts for crosleys because the midget racers used em back in the day. the overhead cams made for a high winding engine and the fact that the cylinder head is an integral part of the block means you can run a lot of compression, no head gasket blow outs to worry about. The speed parts are hard to find and expensive. I paid 750 bucks for that Braje dual carb intake...
    dana barlow and kidcampbell71 like this.
  24. Dedsoto
    Dedsoto
    from Australia
    1. Aussie HAMBers
    Nice little mill, I may be wrong, but I'd wager that's an A model Ford transmission
  25. cb1
    cb1
    from Wisconsin
  26. cb1
    cb1
    from Wisconsin
    Its actually sitting on a pallet with two model A transmissions. Definitely not the same..
    A T92 Warner as mentioned previously.
    cb1
    I'll have to win all three if I want the tranny to go with.. The peril's of an auction. Box of parts, etc..
    kidcampbell71 and Dedsoto like this.
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    gone, I just deleted it
  28. My feelings weren't hurt. I was a bike guy long before I was a car guy. Just being a smartass
