Technical Radiator coolant pressure
Discussion in 'Traditional Customs' started by ruben solis, Oct 9, 2019.
  1. ruben solis
    ruben solis
    I recently decided to replace my single intake on my 48-53 flathead engine; A friend gave me a 32-48
    2 -duece intake it installed nicely started idled beautiful but now Im getting a lot of pressure in my radiator where I cant even take the cap off. Im thinking maybe that There's a miss match on the intake to the block or If the gasket I used which was for a 48 -53 intake is blocking a water path?
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    What have you done to allow that 8ba to breath??
    You have closed off the front vent in the valve galley by installing that intake.
    The new gasket also could be blocking a water inlet.
    I’d suggest you start over and inspect the new gasket with the intake off and see if everything is open and lines up.
    I’d also suggest installing a PCV setup while the intake is removed and allow that engine to breath.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    While we are in this subject....
    What distributor are you running???
  4. V8 Bob
    V8 Bob
    Flathead Ford intakes are dry-there are no water paths or inlets.
    55styleliner, Petejoe and deucemac like this.
  5. ruben solis
    ruben solis
    I have the standard distributer,removed the point and install protronics electronics. For the breather I removed the fuel pump built an breather weldment for oil fill and allowing the engine to breath see pics. I didnt see a water port when I removed the intake just fuel ports. 20190925_165321.jpeg 20190925_165328.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
  6. V8 Bob
    V8 Bob
    Your "breather" will not allow ventilation through the engine.
  7. ruben solis
    ruben solis
    Really isn't that a direct path through the cam path timing gear then down engine pan
  8. V8 Bob
    V8 Bob
    What is pulling air into the engine? That's what the 8BA road draft did, and what a pcv will do in it's place.
  9. ruben solis
    ruben solis
    So what your saying is that a 32-48 intake wont work on a 48-53 engine block . Because when I removed that original intake that road draft went with it and the ability to use a PVC also. Unless you know another way?
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    Yes it’ll work.
    I have a early intake on my 8ba.
    You block off the vent hole at the front of the galley, install a fitting and hose under the intake and run it to a pcv installed into your intake.
    Do a search here. Lots a varied examples.
    That’s correct, my mistake. There are no coolant passages under the intake. They are all under the heads. Sorry.
    Sounds as though your radiator overflow is blocked.
  11. Petejoe
    Petejoe
    from Zoar, Ohio
