Technical Rodchester 2GC holes in base???
Discussion in 'The Hokey Ass Message Board' started by pecker head, Sep 29, 2019.
  1. pecker head
    pecker head
    Anybody know what these holes are for?? I’ve never seen before. Came off of 61 Impala 283.
    kidcampbell71 likes this.
  2. Mike VV
    Mike VV
    from SoCal
    Don't know their exact 1960 purpose, but have seen it on many Rochester (No "D" needed) carburetors.
    Like a purpose built vacuum leak, but NOT until the throttle is opened.
    They make the carburetor flow a TINY bit more air is about all they do.
    Not to worry, clean them, reassemble them and use them.
    Mike
    pecker head likes this.
  3. LOU WELLS
    LOU WELLS
    from IDAHO
    They Help The Idle Circuit...And Work...
    pecker head and Dino 64 like this.
  4. pecker head
    pecker head
    Thanks Guys.
    LOU WELLS likes this.
  5. egads
    egads
    ^^^^^^^^^^^^^^^^^^^ Vapor vent holes.
  6. pecker head
    pecker head
    85D31405-5E36-4B62-B362-56EE244285FC.jpeg 9D71996D-8154-4CAC-9A17-419DC40AC462.jpeg F6286B31-4457-4867-9426-EA41FEC299FB.jpeg Soaked all day yesterday, all day today, came home and sprayed with Eastwood carb paint.
    Lone Star Mopar likes this.
  7. They allow non filtered air and dirt to enter the interior of the carburetor. Idling around town the carb gets hot and the extra air is supposed to smooth out the idle. The plus is it adds extra air at higher rpms to cause detonation and suck in dirt. (poor man's hot idle compensator valve)
    They are similar to the idle control valves in the base of the Holley 2100 carbs.
    However Holley uses a vacuum valve to open and mix the ported and manifold vacuum
    to raise the idle so the engine does not stall.
  8. pecker head
    pecker head
    Unfiltered air is all that I can think about at night. That’s the reason I posted this.
  9. pecker head
    pecker head
    Can I sillycone them???
  10. Lone Star Mopar
    Lone Star Mopar
    JB weld them suckers up. I don't remeber any of my 2Gs having those..?!
    Sent from my LM-Q720 using The H.A.M.B. mobile app
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Put (fat) tooth picks in first and see how it idle's and or run's. If it don't then all that has to be done is pull them out.
    carbking and pecker head like this.
  12. carbking
    carbking
  13. sunbeam
    sunbeam
    Those are factory I have several with the holes.
  14. Sounds like solution in search of an actual problem.
  15. Blues4U
    Blues4U
    from So Cal
    Truckdoctor Andy likes this.
