Projects Seagrave 531 V12 Special BuiLd Up in Brazil
Discussion in 'Traditional Hot Rods' started by Drmalacarne, Sep 5, 2019.
  1. drtrcrV-8
    drtrcrV-8
    Thank you for also posting over on "Unusual Engines" as well!! Everybody needs to see this "build"!!
    loudbang, Drmalacarne and Deuces like this.
  2. 51504bat
    51504bat
    Damn, maybe you can make honey out of dog sh*t! Awesome craftsmanship. Can't wait to see what's next.
    Deuces, loudbang and Drmalacarne like this.
  3. Drmalacarne
    Drmalacarne
    Finished all the internal engine works we started to put everything back together.
  4. Drmalacarne
    Drmalacarne
  5. -Brent-
    -Brent-
    This project is in great hands. Should be a fun build.
  6. These are originally Auburn V12 engines re purposed as firetruck engines.
    Deuces, loudbang, Drmalacarne and 2 others like this.
  7. Drmalacarne
    Drmalacarne
    After partial rebuild the engine went to the chassis.
    Looks like a porcupine.
    We found a nice position for the V12 heart of he Hot Rod.
    Enviado do meu iPhone usando H.A.M.B.
  8. Drmalacarne
    Drmalacarne
    4d6623a5-71d8-4abd-9c9b-5dc1c74d0318.jpg 6c590460-82a3-467b-bb30-37739a1c65d6.jpg f9130953-15ba-4dbe-b518-2d113bfeb292.jpg
    brEad, flyin-t, JUNK ROD and 22 others like this.
  9. nunattax
    nunattax
    from IRELAND
    looking forward to hearing it running
  10. Drmalacarne
    Drmalacarne
    New friction for the clutch and restored gas tank cap.
    The gas tank will be custom made to fit the rear of the body.
    b4ff15a6-7143-4421-a0d6-9a0ca0b840be.jpg becf33aa-b154-4104-ac26-5078a433624a.jpg
  11. Drmalacarne
    Drmalacarne
    brEad, flyin-t, Tim and 24 others like this.
  12. 1-SHOT
    1-SHOT
    from Denton
    I noticed that the clutch disc does not have any antichatter springs.
  13. Boryca
    Boryca
    from Detroit
    Loving this build. Interesting tidbit @Bones - this is the same procedure used for checking airplane mags. On piston engine aircraft, there's 2 plugs per cylinder, ran off 2 separate mags. On startup, for your pre-flight inspection you always run on each mag by itself and note the RPM drop (should be about 50-100 rpm if memory serves...). Taking one mag out of the equation tells you a lot about how healthy everything else is.
    Mike
  14. SR100
    SR100
    No, this is a Seagrave engine. The Auburn-based V12 firetruck engine was used by American-La France. Here is an Auburn-derived ALF V12:
    (The Auburn 12 was smaller than this and had one spark plug per cylinder) The Auburn/Lycoming 12 had horizontal valves, sort of like a late Oakland V8.
    The Pierce-Arrow design that Seagrave used probably had more performance potential.
  15. Drmalacarne
    Drmalacarne
    Find a new ser of head gaskets is like find a oasis in Sahara desert!
    So, we refurbished the original ones using Loctite Cooper Spray.
    They where in good shape luckily!
    7bf7b057-7817-4fc5-9fe4-50c045b77245.jpg f3e72a0a-7579-44b0-83f5-cb33d92854da.jpg 6e01f48f-d4a5-45c4-8f89-6518d66ec824.jpg d7177761-1b17-477e-9a3d-c078b351de2f.jpg 5f394cad-b8a6-4b32-a266-edc8aa0d94eb.jpg
    brEad, flyin-t, JUNK ROD and 26 others like this.
  16. so cool - inspiring - hats off and watching
  17. Drmalacarne
    Drmalacarne
    The gearbox was opened.
    No so much damage inside, considering its age.
    We made some manual work on the gears and reassembles everything.
    ca015085-3984-4732-980c-8b4de0a5e224.jpg 69453c03-550c-45ee-acc6-4422ce23ef03.jpg 27641599-04a6-4245-8188-060f6d9b68db.jpg cafa3c1e-5874-4f61-8912-eefc8dc1f294.jpg dbf4cb92-79bf-4766-a0f7-85c16190e8af.jpg
  18. Fortunateson
    Fortunateson
    I'm following! With your skills how about a new intake exhaust system? Eight '97s or behaps a blower or two! LOL. This is going to be great!
  19. treb11
    treb11
  20. Drmalacarne
    Drmalacarne
    I thought about a Potwin style Blower.
    Built I decided to keep the project as simple as possible.
    brEad, JUNK ROD, 41 GMC K-18 and 11 others like this.
  21. 52HardTop
    52HardTop
    Can there be a video when she is started? That should be record breaking viewership if you schedule a time for viewing.
    Boryca, Deuces, kidcampbell71 and 2 others like this.
  22. Drmalacarne
    Drmalacarne
    How can I put a video in the Blog?
    41 GMC K-18 and chryslerfan55 like this.
  23. daliant
    daliant
    Put it on YouTube and link the video in a post.
    41 GMC K-18 and BradinNC like this.
  24. Drmalacarne
    Drmalacarne
    Ok. Thanks.
    deathrowdave and chryslerfan55 like this.
  25. Drmalacarne
    Drmalacarne
    First turn to see if it was free.
    Tim, prefect20, JUNK ROD and 14 others like this.
  26. Drmalacarne
    Drmalacarne
    Next step was the rear springs.
    We made new springs 20cm longer, to put the differential backwards, to increase the wheelbase.
    2d7f93ec-ac5d-40b2-83b8-08387f735bf8.jpg aa9f46ce-20a0-48fa-8338-568e94ae9bce.jpg fb1e8da8-fd5b-4bea-b50a-087a1bb0adba.jpg
    The Seagrave gearbox has open output, and the 1926 Buick driveshaft is of torque tube type.
    So we had to do a special treatment for join one with the other.
    brEad, flyin-t, JUNK ROD and 11 others like this.
  27. Joe Poletto
    Joe Poletto
    from Brazil
    Amazing Work! It's hard to do things the "right way" here in Brazil but, so far, you are nailing it!
    Cheers from Rio Grande do Sul!
    Sent from my Moto G (5S) using The H.A.M.B. mobile app
    Deuces and Drmalacarne like this.
  28. flatford39
    flatford39
    I see you have a Model AA split rim spoke wheel on the rear end. Is it bolted or just a mock up?? Looks like a nice wheel. I could use one more.
    Drmalacarne likes this.
  29. weps
    weps
    from auburn,IN
    Here is a pic of my ALF V12.
    Do yourself a favor, when you shit can those old plug wires, get TWO DIFFERENT colors/styles so that you can troubleshoot one ignition system at a time, with merely a glance.
    BTW, there is 106' of plug wire on this machine.
    Also, post up a clear pic of your distributor cap, top and bottom.
    41 GMC K-18, 40two, catdad49 and 6 others like this.
