Hot Rods final drive ratio for burnouts :)
Discussion in 'The Hokey Ass Message Board' started by Gordon Reed, Sep 2, 2019.
  1. Gordon Reed
    Gordon Reed
    what’s going on guys, out of curiosity i had a question about final drive/ rear axle gear ratios. i have a 327 small block (originally 250 horsepower) now closer to 350/375 horsepower. in my rear end right now i have 2.73 gears (open diff) and can’t get that one tire to spin for shit. it’s a 225/60/15 tire so it has a bit of meat but still, i thought i’d be able to get it to let loose. i bought a kit that comes with 3.55 gears and a posi that i will be putting in sooner or later. do you guys think that a posi and 3.55 will help or will i still have trouble?
    1947knuck likes this.
  2. squirrel
    The gear ratio will probably help, but the posi will hurt.
    There are a lot of other variables, you know....we don't even know if you have a manual or automatic transmission, what kind of tires you have, what kind of car it is (heavy, light, wagon, T bucket, ????)
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    I think you are off on your horsepower estimate.
    My OT '72 Formula 350 Firebird is rated @ 180 HP and has a 2:73 posi differential, and 245/60 tires.
    It will smoke the tires from a dead stop until it shifts to second gear.
    Really there is no good reason other than to show off to smoke your tires.
    I am not so well off that I want to ruin a rear set of tires any way.
    KK
  4. Elcohaulic
    Elcohaulic
    Crank up the initial advance.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Put a motor in it that will break the tires loose at 60 mph ,then you'll be able to do all the burnouts you want ....
  6. Deuces
    Deuces
    Burning rubber costs $$$$$....
  7. Slopok
    Slopok
    Find a water puddle or some gravel and then grow up!
  8. Deuces
    Deuces
    Don't think we'll see him again.....
  9. Gordon Reed
    Gordon Reed
    ouch.. lol i have a power glide, the car is a 65 chevelle sedan.
  10. Gordon Reed
    Gordon Reed
    i tried both but haven’t gotten any older
  11. 65 chevelle,18 years old.Most of us did this at that age.
  12. Gordon Reed
    Gordon Reed
    power glide in a 65 chevelle malibu sedan
  13. oldolds
    oldolds
    There must be something wrong with your motor. It should light up that tire. Have an old guy show you how it is done!
    Deuces likes this.
  14. sdluck
    sdluck
    PG 273 R and P car stock 1965 chevelle will not spin a tire without a neutral drop
    Deuces and loudbang like this.
  15. harpo1313
    harpo1313
    from wareham,ma
    Reverse roll comes to mind.
    32fenderless, Dino 64 and Deuces like this.
  16. sdluck
    sdluck
    That too.
    Deuces likes this.
  17. Dooley
    Dooley
    from Buffalo NY
    I have a powerglide with a 300something 350 and 3:70 gears..I can smoke em good.
    Deuces likes this.
  18. liliysdad
    liliysdad
    from Oklahoma
    I find it hard to believe that folks don't genuinely enjoy a good, smoky burnout now and again.
    WC145, Chuck Lauer, FlynBrian and 8 others like this.
  19. I had a 3.08 gear in this 4000 pound beast. I did not have my foot on the brakes and was running 235/70/R15 Coopers.
    Dino 64, FlynBrian, harpo1313 and 3 others like this.
  20. 327Eric
    327Eric
    Your problem is the powerglide. Get a turbo 350 or aod
    Deuces likes this.
  21. A powerslip will work fine if you boost the line pressure. :D
    Deuces likes this.
  22. gimpyshotrods
    gimpyshotrods
  23. with that gear you could roast the tires with a Briggs n Straten :D
  24. error404
    error404
    from CA
    stand on both pedals, or get a brake line lock for the fronts only
    Not quite! My old jeep had 5.38 gears, it wouldn't chirp the tires unless I dumped the clutch at full throttle, a blistering 3400 RPM. haha! Fun spinning around on dirt though!!
    Deuces likes this.
  25. Bandit Billy
    Bandit Billy
  26. Gordon Reed
    Gordon Reed
    what is the difference that will help with doing burnouts? i understand turbo 350’s have 3 gears instead of 2 but why specifically will it help with burnouts?
  27. I have a 65 Valiant that had a stock 318 and 2.72:1 gears and it had no problem...maybe it’s a Chevy thing.
  28. And 13” tires! Hence the smiley face.
    Deuces and Hnstray like this.
  29. And here I thought it was the power the worn out 318 had.
    Deuces likes this.
  30. Gordon Reed
    Gordon Reed
    that one hit deep into my heart
