Hot Rods THE INDUCTION THREAD
Discussion in 'The Hokey Ass Message Board' started by mad mikey, Dec 9, 2016.
  1. 340HilbornDuster
    340HilbornDuster
    Thanks for the Link BRR!
    These guys makes some Cool Stuff - for THE ENGINE!
    The valve cover spacer is actually a Valve spring Oiler...
    The Drill it and put little nozzles at each valve..hence the AN Fittings!
  2. deadbeat
    deadbeat
    That blown 427 Ford engine, was that for a boat and what is that on the bell housing above the starter? Cheers and thank you
  3. Stebo27
    Stebo27
  4. loner1
    loner1
    from Texas
  5. loudbang
  6. loudbang
    From the Mecum-2019 Harrisburg Werner Collection
  7. loudbang
  8. 402BOSSMAN
    402BOSSMAN
    Well, I can answer any questions people have since that's my baby right there!
    I'll address the nozzle placement - yes above the blades and those are the only ones. With careful research you will find that on gas the higher the placement the better for horsepower. I wanted a near showerhead design We will be idling or WOT for the majority of the time - ie "Great White Dyno" of the salt. Keep in mind Gene Adams, Don Enriquez, and myself all have input on this system with Gene doing the tuning.
    The valve cover spacer is best explained here.
    This has been a design I've pondered for some time, Gene actually flowed it to compare to what other SB2.2 Nascar motors see for orifice flow. From the blanks, I machined the rest on my manual mill from there, killer piece for sure.
    Engine Labs is doing a writeup with more details that will be out soon. Any other questions?
  9. DDDenny
    This retired machinist agrees, that's a neat piece(s).
    Speaking of "showerheads", for those that don't know it, that's what the injector hat was called that is on that SOHC Ford posted prior, made by Enderle in the early/mid 60's.
    Stogy, loudbang and 402BOSSMAN like this.
  10. Stebo27
    Stebo27
  11. loner1
    loner1
    from Texas
  12. loudbang
    FE T-Bird Trips
    FE Webbers
  13. loudbang
    From the Mecum-2019 Harrisburg Werner Collection.
  14. Deuces
    Deuces
    More trips and duals..... IMG_20190818_104901.jpg IMG_20190818_104849.jpg IMG_20190818_104938.jpg
  15. saltflats
    saltflats
    from Missouri
  16. Deuces
    Deuces
  17. XXL__
    XXL__
    The glitter of gold...
  18. Deuces
    Deuces
    Looks like jewelry..... :)
  19. loudbang
    From Mecum 2019 Werner Collection.
    Ford SOHC
  20. loner1
    loner1
    from Texas
  21. Stebo27
    Stebo27
  22. cruiserjohn76
    cruiserjohn76
  23. loner1
    loner1
    from Texas
  24. Stebo27
    Stebo27
  25. 340HilbornDuster
    340HilbornDuster
  26. seb fontana
    seb fontana
    from ct
    That is actually a Parker Funnel Web for SBF windsor type heads..The little squarish boss just in front of carb flange has PARKER script on it and the water cross over has the script FUNNEL WEB [which is the name of a spider]..Pretty tall at 6.312;)
    Bowtie Coupe, Stogy, loudbang and 2 others like this.
  27. loner1
    loner1
    from Texas
  28. Stebo27
    Stebo27
  29. loudbang
    Dead End Kids, Red Lang, Spider Razon, and Joe Anahory.
  30. loudbang
