Projects 54 Chevy Bel Air 2dr ht mild custom “Lolita”
Discussion in 'The Hokey Ass Message Board' started by Early Ironman, Sep 16, 2016.
  1. oldsman41
    oldsman41
    Very nice. My cousin has a mild custom 54 hardtop i really like them pretty lines
  2. Early Ironman
    Early Ironman
    [​IMG][​IMG][​IMG][​IMG][​IMG]
    Got a bit more accomplished today.
    White under the dash makes it so much easier to see. When installing everything later.
  3. Early Ironman
    Early Ironman
    They are a safer more secure latch than the original.
    Plus, when I had the car acid dipped. The alloy base that the factory latch striker secured to dissolved away. So was pretty much forced to do this instead.
  4. Early Ironman
    Early Ironman
    Did some much needed cleaning and organizing. Back to sanding now.
  5. Early Ironman
    Early Ironman
  6. Early Ironman
    Early Ironman
    [​IMG][​IMG]
    Slowly making progress with a ton of block sanding.
    At least now I have Netflix in the shop during this mindless process to make it a bit more bearable.
  7. Early Ironman
    Early Ironman
  8. Early Ironman
    Early Ironman
    [​IMG][​IMG][​IMG]
    Modified the original steering wheel to fit an aftermarket steering column.
  9. Early Ironman
    Early Ironman
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Laid some paint the past couple of days.
    Inching ahead a little at a time.
  10. Dyno Dave
    Dyno Dave
    I'm in the process OK ("slow, very slow")of redoing my '54 Bel Air 2dr. firewall & inner fender panels, while on the firewall noticed that body stamping is also set up to be done as a right hand drive car, curious did you find the same ? Dyno Dave
  11. Early Ironman
    Early Ironman
    No, mine was not set up to be converted to right hand drive. Would like to see how yours is set up and where it was built to be like that though.
    Bowtie Coupe and loudbang like this.
  12. 19Fordy
    19Fordy
    Beautiful design and execution.
    Are you sure you want to paint it green?
  13. patterg2003
    patterg2003
    Great work. Look forward to seeing it in colour.
  14. Dyno Dave
    Dyno Dave
    I checked my photo gallery, lots of pictures of the cleaned up firewall, none of the original. Look at your right side floorboards, spot the two 3"x 3" small relief squares = clutch & brake, to the right 3" round relief = gas pedal, don't they match the ones on the right ? Thinking there was some indication where the steering tube & column shift lever shaft would have passed through the firewall.. Your car is going to be outstanding... Dyno Dave
  15. Early Ironman
    Early Ironman
    Back home from work and laid some clear.
    Really love this green!
  16. Lines
    Lines
    from Germany
  17. loudbang
    Good looking green.:)
    Lines, Bowtie Coupe and Early Ironman like this.
  18. gsnort
    gsnort
    Agree on the green. It fits the body so well, so far.
  19. greaser 35
    greaser 35
    from FRANCE
    The green is absolutly fabulous !!!:cool:
  20. Early Ironman
    Early Ironman
  21. Early Ironman
    Early Ironman
  22. Early Ironman
    Early Ironman
  23. 19Fordy
    19Fordy
    Huge scallops look over powering..
  24. Early Ironman
    Early Ironman
    Agreed, they won’t be that thick. That was just me scribbling on a picture on my cell phone.
  25. Early Ironman
    Early Ironman
  26. Early Ironman
    Early Ironman
    Took Lolita around the block a couple laps for the first time. Hadn’t been on the road since 1995.
  27. Early Ironman
    Early Ironman
  28. 41rodderz
    41rodderz
    from Oregon
    Glad your keeping the family member.:cool: Love that your " hands on" everything . It is inspiration to watch this thread:). One major negative is to be close to your level , I now have to go clean up the shop, build a shed to house the "extras":oops: and get to work on a project:eek:. :D Two thumbs up :cool:
  29. Early Ironman
    Early Ironman
