Hot Rods Exhaust header paint
Discussion in 'The Hokey Ass Message Board' started by flatford39, Jul 19, 2019.
  1. flatford39
    flatford39
    Just received my exhaust headers from Red's for my AV8 and to tell you the truth they are beautiful. I really don't want them to rust and I don't like the looks of wrapping them so what kind of paint or high temp sealer is recommended to keep them from turning into rust.
    Is there a high temp clear that could be sprayed on???
    If I have to paint them it would probably be black or maybe white.
    thanks for any help.
    Deuces likes this.
  2. Mike Colemire
    Mike Colemire
    Grill paint works good and yes I've seen Hi Temp clear.
    Deuces and flatford39 like this.
  3. flatford39
    flatford39
    Clear is what I am after....do you remember the manufacturer.
    Thanks
    Deuces likes this.
  4. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Deuces likes this.
  5. oldiron 440
    oldiron 440
    I haven't had the best luck with Rust-oleum on headers, it blisters off.
    How about treating them with oil or ceramic coatings.
  6. flatford39
    flatford39
    Has anyone used the POR 15 high heat paint on brand new tubular headers or does it only work on rusty cast iron headers???
    They have a gray color that would be perfect.
  7. Gman0046
    Gman0046
    gkz4KZrsQg6RQf%PzkX6Sw.jpg This is Jeg's blue header paint.
  8. flatford39
    flatford39
    Thanks..but I am asking about brand new tubular headers and not cast iron.
  9. quick85
    quick85
    Unless you are absolutely going for a look you can't beat having them ceramic coated.
    A semi-gloss look that stands up like nobody's business. My ceramic coated headers
    have been on the car for 25 years now and look great. Check with a powder coater
    about clearing them. It's worth the cash outlay.
    dmdeaton likes this.
  10. Paul
    Paul
    Editor
    Don't know if this comes in clear also but the silver goes on and stays nice and it takes touch up very well
    flatford39 likes this.
  11. Eh-Bone
    Eh-Bone
    In the past I have used a product by VHT, I used the “as cast” color on my OT 70 Cuda’s factory iron big block exhaust manifolds. Held up damn good, didnt allow rusting and didnt peel or flake off.
  12. flatford39
    flatford39
    Paul,
    Have you used it on brand new tubular steel headers and not porous cast iron???
  13. Paul
    Paul
    Editor
    Yes, new steel headers
  14. 1946caddy
    1946caddy
    from washington
    Clean them real good with something like brake clean and don't touch them with your bare hand before painting. You don't want oil off your hand on them. Several light coats and allow to dry between coats.
    chop job likes this.
  15. flatford39
    flatford39
    Thanks Paul...I respect your work and your opinion. Thanks again
  16. boo
    boo
    from stuart,fl.
    if the headers are for a flathead, look and see that where the pipes are welded to the other that the hole in the pipes are cut out all the way.i bought a set years ago and there was only about a 1/2 inch hole for the exhaust to exit. had to reach into the pipe with a stick welder turned up hi to burn out the hole.
  17. flatford39
    flatford39
    Thanks but all ports are wide open.
  18. rusty rocket
    rusty rocket
    Im with quick 85, have them coated they will last forever.
    Both of these were coated and still look as goos as the day they were done. image.jpg image.jpg
  19. Vimtage Iron
    Vimtage Iron
    I used KBS high heat primer and paint, the headers were used and came on a 312 in a 56 C600 series Ford truck, I had them sand blasted and then hit them with the KBS and followed directions to a T for a change, and as 46 caddy said keep you fingers off of them, I've put several hundred miles on that truck and no problems. PICT2599.JPG
  20. 29moonshine
    29moonshine
    I have had good luck with it you can all ways recoat if needed
  21. Crayons
    Crayons
    What I have used , is Eastwoods stain less steel paint. Comes in several colors and gray is one of them. This stuff is indistructable and will never burn off. Bill Hirsch also sells it. It will last forever.
