Motion Pictures The Glory that is the Big block, Picture thread!
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Oct 7, 2018.
  1. loudbang
    Mercury 410 Marauder
  2. Flogknaw
    Flogknaw
    from Texas
  3. loudbang
  4. loudbang
  5. 65pacecar
    65pacecar
    from KY, AZ
    RustyDogg, JUNK ROD, das858 and 7 others like this.
  6. loudbang
    1964 Superstock
    JUNK ROD, das858, 1947knuck and 5 others like this.
  7. 65pacecar
    65pacecar
    from KY, AZ
    One of the most beautiful engines a factory ever built.
    Deuces, enloe and loudbang like this.
  8. 65pacecar
    65pacecar
    from KY, AZ
  9. loudbang
  10. badvolvo
    badvolvo
    IMG_2636.jpg BBC going into my 40 Chevy. OT cubic inches
  11. loudbang
  12. 65pacecar
    65pacecar
    from KY, AZ
  13. 65pacecar
    65pacecar
    from KY, AZ
    [​IMG][​IMG]
  14. ^Its a Doozy^
    loudbang, 65pacecar and Deuces like this.
  15. loudbang
  16. Deuces
    Deuces
    Those carbs look like they had the choke horns milled off.... Great way to gain a little more cfm...
    loudbang and enloe like this.
  17. 65pacecar
    65pacecar
    from KY, AZ
  18. loudbang
  19. badvolvo
    badvolvo
  20. Deuces
    Deuces
    Sounds healthy!... :)
    badvolvo and enloe like this.
  21. hammer-time
    hammer-time
    IMG_0950.JPG Can't wait...getting closer everyday!
  22. loudbang
    It that a 632 Cubic inches engine?
    1947knuck, enloe and Deuces like this.
  23. badvolvo
    badvolvo
    Yes it is. I debated over this for a year or more. I wanted enough power to get to out run my last one. So I had a choice, blown, hi-compression or massive cubes. I decided to go with a pump gas, 10.35 compression, roller cam, good heads. I did not dyno yet, but based upon past builds, it's 915-950 at the flywheel. I should be able to take it easy and still get where I want to be. I will run it on a chassis dyno during the initial tuning, but it's still got a ways to go.
  24. loudbang
    Wow that is going to be a stump puller. :eek:
  25. loudbang
    390 Ford Webbers
    1947knuck, mgtstumpy, enloe and 2 others like this.
  26. mgtstumpy
    mgtstumpy
    1947knuck, Deuces, Kan Kustom and 4 others like this.
  27. mgtstumpy
    mgtstumpy
    1947knuck, Deuces, Kan Kustom and 3 others like this.
  28. loudbang
    413 Ramcharger
    1947knuck, mgtstumpy, das858 and 4 others like this.
  29. loudbang
