Technical Brake M/C Sleeving?
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jul 5, 2019.
  1. InstantT
    InstantT
    from SoCal
    Karps power brake, Upland, Ca.
    Sent from my LGLS992 using The H.A.M.B. mobile app
    john worden and brigrat like this.
  2. Beanscoot
    Beanscoot
    I see that Whitepost only mentions brass sleeves. I read some years ago in Skinned Knuckles magazine that the brass or bronze sleeves were okay for restorations that aren't driven much, but will wear quickly in cars driven a lot.
    Such cars should have stainless steel sleeves installed, the article said.
    Precision stainless steel thin wall tubing is available.
    brigrat likes this.
  3. brigrat
    brigrat
    from Wa.St.
    Makes sense!
    Seems I will have to reverse engineer this M/C, find the guts, springs, rubber "pucks", plunger, etc.. first than pick bore to fit..................................................
  4. brigrat
    brigrat
    from Wa.St.
    Jeb,I send a PM to you!
  5. john worden
    john worden
    from iowa
    From experience I too recommend Karps PB in Upland California. Explain the issue before you make changes.
    Talk to Sally or Jeff.
    34toddster likes this.
  6. Mike Moreau
    Mike Moreau
    I have the same issue, same parts (Chev pickup truck brake/clutch MC) GM calipers on the front. 56 Chev drums on the rear. I would like more stopping power. Can anyone can furnish an experienced answer on bore size for the brake bore and what vehicle uses that size piston/seal combination? Thanks.
    brigrat likes this.
  7. brigrat
    brigrat
    from Wa.St.
    Karps & the other 2 I called wanted 100 per hr., another wanted $200 a hole. None of that is going to happen.........................................................
  8. Mike Moreau and brigrat like this.
  9. enjenjo
    enjenjo
    from swanton oh
    I have used Apple Hydraulics for downsizing the bore. It's been some time back but it was not that expensive. They supplied all the piston, cup, and spring parts. As I recall I had them go from 1 1/8" to 7/8".
    brigrat likes this.
  10. Mike Moreau
    Mike Moreau
  11. slim39
    slim39
    from pa
    I used White Post Restorations in White Post Va. They did a great job
  12. Maybe if you can locate one; an IHC dual master which has 1" bores (pretty sure) would be more in line with the discs. Of course, it doesn't look as quite the same as a Chevy truck dual master.
  13. brigrat
    brigrat
    from Wa.St.
    The 1" bore IHC has a center line to each bore of over 3", my holes in the fire wall & brake assembly on the other side are set up for the 2 1/2" center line. Don't want to alter it!
    RICH B likes this.
