Technical Metal in Fresh Motor Oil Pan
Discussion in 'Traditional Hot Rods' started by StevieJ455, Jul 14, 2019.
  1. StevieJ455
    StevieJ455
  2. lippy
    lippy
    from Ks
    That's a lot of stuff. Block possibly not clean enough? Maybe drop the pan and look at some bearings to be sure. Not saying it's from bearings . Are those big chunks in your hand magnetic? Just suggestions. Lippy
    porknbeaner and fauj like this.
  3. not a good thing
  4. toxic waste
    toxic waste
    from Iowa
    What 455 ? Pontiac 455 has 3 1/4 main diameter. They need around .003 clearance. They don't like high rpm. Just watch your oil pressure and run it .
  5. saltflats
    saltflats
    from Missouri
    New flat tappet cam?
  6. StevieJ455
    StevieJ455
    Yes, Pontiac 455
  7. StevieJ455
    StevieJ455
    Yes. New Erson Flat tappett cam
  8. saltflats
    saltflats
    from Missouri
    Did you do proper breakin procedure?
  9. Did you use break in oil? HRP
    VANDENPLAS and m.ralph like this.
  10. StevieJ455
    StevieJ455
    Yes, 2k but only got about 10 minutes on the run stand. The radiator on stand was undersized and it started to overheat.
  11. toxic waste
    toxic waste
    from Iowa
    Make sure you have pontiac lifters not Chevy lifters. They will fit but not oil right.
    phantompjcoupe likes this.
  12. StevieJ455
    StevieJ455
    Correct. Break in oil used.
  13. Lost in the Fifties
    Lost in the Fifties
    Some of the metal in your hand looks like metal from turning the crank. Did you use a gun bore brush through all oil holes in crank? Machine shops turn crank, but most don't clean them out afterward.
  14. lostone
    lostone
    from kansas
    I agree with a couple above, as big as the pieces are it looks like inadequate cleaning of parts when assembling.
    I'd pull the pan and plasti-guage the rod and main bearings, if they check out bolt it back together and run it.
    flatford39 and anthony myrick like this.
  15. saltflats
    saltflats
    from Missouri
    10 minutes isn't enough time.
    It would be okay to shot it off, but when fired again it needs to back up to 2000 rpm for the remainder of the breakin time.
    harpo1313 and 48fordnut like this.
  16. m.ralph
    m.ralph
    What break in oil did you use?
  17. koolbeans
    koolbeans
    If that came out of the oil pan or filter motor needs to be taken apart and thoroughly cleaned and inspected. No way that trash is a good sign.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  18. 3,000 rpm for thirty minutes to break in a cam. With low tension valve springs. then after break in you install the stiffer springs. You gotta really clean a new assembly. And prelube the engine before you start it. That engine is contaminated. take it apart and assemble it correctly and clean enuf to eat from.
    Boneyard51, harpo1313, 302GMC and 2 others like this.
  19. toxic waste
    toxic waste
    from Iowa
    If there are big cast iron chips , that's from boring cylinders. Someone did not clean very well after all machining was done. The crank was just polished that would be very fine grit. It's all about cleaning. I worked at a machine shop and the blocks went in cleaner 2 to 3 times. All holes was brushed and hosed out.
  20. Who assembled the engine... You or the machine shop?
  21. StevieJ455
    StevieJ455
    Long block from the machine shop
  22. StevieJ455
    StevieJ455
    Joe Gibbs break in Oil, Driven.
  23. StevieJ455
    StevieJ455
    Long block from machine shop.
  24. 1946caddy
    1946caddy
    from washington
    Not what you want to hear but I would tear engine completely apart and check everything. Had to go threw oil pump to get to the filter which means in is everywhere in your engine.
  25. toxic waste
    toxic waste
    from Iowa
    I would take it back to machine shop as is and show them .
    RMONTY, Never2low, edcodesign and 2 others like this.
  26. That’s the best thing to do,,,
    Pray nothing got tore up, it will be obvious if it did because that’s a lot of debris.
    The cam break in procedure key to success is light duty valve springs. It’s a ROYAL PITA and double work. Funny that years ago it was never done and rare to hear of a problem.
    Old wolf likes this.
  27. toxic waste
    toxic waste
    from Iowa
    A curtain brand of oil pump has been known to have chips in them. Most Pontiac engine builders disassemble oil pump and clean and lubes.
    Black_Sheep likes this.
  28. Don't tear anything more apart on it! Take your oil sample and filter to them and let them tell you what to do next. Assuming they're a "stand-up" machine shop. The less you touch the less reason they have to suspect your motives.
  29. YES/AND NO! Yes- I'de fully tear it apart to inspect before running it. But NO- I'de take the samples of the picture shown back to the machine shop, and raise a lil hell.... Sorry- I don't care what make/model/engine that's from, that's just unacceptable.....
    And it's been run...... Hey- Not to piss in anyone's Wheaties, but- if that was caught in the oil filter, Just think where the rest went, and circulated through..........:(
  30. footbrake
    footbrake
    DON'T DO ANYTHING ELSE BUT TAKE IT ALL TO YOUR BUILDER AND SHOW HIM!!!
    Never2low, Black_Sheep and 48fordnut like this.
