Technical reversed a couple wheels yesterday..
Discussion in 'The Hokey Ass Message Board' started by Paul, Jul 12, 2019.
  1. Paul
    Paul
    Editor
    tires were a little close to the body on a fenderless A roadster for possible future cycle fenders
    and the hub caps of choice wouldn't clear the centers.
    so I thought I'd take some pictures of the process.
    no tire machine, no bead breaker, not even a tire iron
    did use a drill press and mig welder though..
    the process has been shown countless times before but here we go again..
    use something heavy to break the bead free of the rim
    roll the tire over and break the other bead
    rassle the tires off the rims, being careful not to hurt the tire
    center punch and pilot drill the rivets, but not all the way through
    using larger bit as a counter sink remove the swedged rivet head
    use a hammer and punch to knock the rivets out
    use the BFH and drift to knock the centers free of the rims
    clean up the mating surfaces and knock the centers back in aligning all rivet holes
    mount the wheel on an axle and check for true
    short welds in alternating pattern to avoid warping
    rivet holes welded and valve stem relocated
    wrestle the tires on to the rims, use a strap to force bead to rim and fill with air
    and there ya have it
    29EHV8, WC145, MO54Frank and 72 others like this.
  2. Very cool! Thanks for showing me with pictures. That is way better for me than just reading about it.
    Todd
    Paul, clem, kadillackid and 2 others like this.
  3. 19Fordy
    19Fordy
    Very well done.
    Paul and Deuces like this.
  4. Nice tech,thanks for the how-to.
    Paul, Stogy and Deuces like this.
  5. That’s very cool! You do nice work. Thanks for the how to article. This is something I never would have thought of doing
  6. buffaloracer
    buffaloracer
    from kansas
    Thanks for the how-to.
    Pete
    Paul likes this.
  7. Kan Kustom
    Kan Kustom
    Nice job. Thanks for sharing.
    Paul likes this.
  8. That's how it was done back in the day.
    Paul and Crazy Steve like this.
  9. Silva
    Silva
    Awesome quick tech...Love the A roadster!
    Paul likes this.
  10. Sporty45
    Sporty45
    Very cool, thanks for the write up :cool:
    Paul likes this.
  11. BuckeyeBuicks
    BuckeyeBuicks
    from ohio
    I knew a guy about 40 years ago that had an idea something like that, only he used a torch and a stick welder. When he mounted them on the back of his 56 Chevy it wobbled so bad it about shook all the rust and bondo out of that poor old car:eek: Your way looks a whole lot better! Thanks for posting.
    Paul likes this.
  12. Brand Apart
    Brand Apart
    from Roswell GA
    Very cool, I'm assuming these riveted wheels are not fairly common? I've never noticed but then again I just may not have really paid attention. I will in the future. Loved the dropping a truck on them to break the bead, chalk that up as another 'why didn't I think of that one" idea.
    enloe and Paul like this.
  13. ...you can mount tires on wheels by placing a garbage bag over the rim, then pry the tire over the rim....it helps the tire go over the rim,..mite need a bag to do each side of tire,..I tried this trick, it does work,...you can also use dish soap on the rim edge to help.
    Paul and Stogy like this.
  14. Paul
    Paul
    Editor
    I used Windex as the lube when taking the tire off the rim, WD40 on the wheels when knocking them apart and Armorall when puting the tire back on the rim.
    The Windex could have been any soap, WD40 could have been any good penetrant and Armorall was to not only lube but soften to help seal, it too could have been anything comparable..
    All were chosen because they were handy and in spray bottles.
    Texas Webb, Stogy and kadillackid like this.
  15. slowmotion
    slowmotion
    Good write up. I'd have been tempted to blast 'em and coat 'em with a shiney enamel of your choice, capless.
    But I'm one of those guys who just likes the looks of a true reversed wheel! :D
    Paul likes this.
  16. clem
    clem
    We use a tractor - easier to see as you drive on. - How do you do it ?
  17. Marty Strode
    Marty Strode
    We used to use a bumper jack, the square base put a lot of pressure on the bead. Great tech Paul, doing it like we did 55 years ago.
  18. Thanks for sharing a lot of common sense Garage Engineering - not so common these days.
    Texas Webb and Paul like this.
  19. I can see none of you guys have never had the misfortune to mount heavy truck tires. This is where a tire bead breaker hammer is used. It’s a large sledgehammer with a spoon type bill on it. A couple of well placed blows and the bead is broken. Practice on an old shity wheel and tire first. Get it wrong, and you will be looking for a new wheel. Heavy truck rims are slightly thicker than car wheels. Your results may vary!
  20. Stogy
    Stogy
    Holy Innovative Batman...Very Cool and the Hotrod Equally Very Cool...Run with Whatcha Got...
    @Paul Remington Cushion Air are those a Modern Tire like the Firestone Champions...They look Right at Home...;)
    Paul likes this.
  21. clem
    clem
    Nice welding, nice article. Thanks
    Paul likes this.
  22. clem
    clem
    We used an 80 ton press, and I was amazed at just how tight they were.
    Paul likes this.
  23. Never2old
    Never2old
    from so cal
    Are those repop hubcaps?
    Paul likes this.
  24. Paul
    Paul
    Editor
    To be honest I never looked at them real close, not my car.
    I just assumed they were original '56 Olds Fiesta.
  25. Great tech write up Paul! I could have used you at our tire store back in the day:D
    Paul likes this.
  26. flatheadpete
    flatheadpete
    from Burton, MI
    Nice! Thanks for the well written and illustrated how-to.
    Paul likes this.
  27. catdad49
    catdad49
    Last time I saw a how-to on this, the magazines were a lot smaller! I'm sure you took 'er for a test drive. Thanks, Carp.
    Paul likes this.
  28. HarryT
    HarryT
    Very instructive 'how-to'. Great job on the write up.
    Jim
    Paul likes this.
  29. bill gruendeman
    bill gruendeman
    Cool tech, the old school way
    Paul likes this.
