Hot Rods Chris Magee's 32 Five Window
Discussion in 'The Hokey Ass Message Board' started by DRD57, Feb 1, 2019.
  1. DRD57
    DRD57
    We're starting a new project to build Chris Magee's 32 five window. He has been collecting all the parts and building the car in his head for a long time, now it's time to make it real. Aesthetically it will be a fraternal twin to my green roadster but powered by a flathead with a 39 trans and a QC rear end.
    We started by taking the frame rails that had their cross members removed and jigged them up to put the K-member back in along with a Model A rear cross member and an aftermarket front Model A cross member. Ideas for mods to the rear cross member were robbed from other posts here on the HAMB. The K-member, engine mounts and cross members are just bolted in for mock up but will be riveted in.
    We added reinforcements to the rear frame as Ford did on later 32 frames since these rails did not have them. We also had to replace the rear frame horns that had been bobbed in a previous life.
    Stogy, ls1yj, akoutlaw and 6 others like this.
  2. DRD57
    DRD57
    The front cross member was modified so it too could be riveted in place. Engine mounts were fabricated and will also be riveted.
    Stogy, akoutlaw, Deuces and 4 others like this.
  3. DRD57
    DRD57
    Next up was to mock up the engine, trans, rear axle & body to double check cross member placement.
    Now we have a bunch of sheet metal repairs to do.
    texkbc, Stogy, akoutlaw and 12 others like this.
  4. brady1929
    brady1929
    Looks great. Can't wait for more progress.
  5. A Boner
    A Boner
    Going to be cool!
    Expensive paint jobs take the fun out of hor rods.
  6. Any updates?
    Phil
  7. Patiently waiting. HRP
    Just Gary likes this.
  8. DRD57
    DRD57
    4D47A496-4405-4AE8-87ED-DDBD7630708C.jpeg 9C9BA79F-7541-4DFD-8D09-08D125E50CB6.jpeg
    It’s back apart and we’re beginning the rust repair of the body. The floor just about fell out when we lifted the body up onto the cart. The bottom edges have all been cut to reasonably solid metal in preparation for the numerous patch panels. Now we’re waiting on the new floor from UPAC.
    Three of the fenders and the deck lid needed some minor repairs, which are done. The left rear fender was too beat to use so we’re waiting on Chris to score a better one.
    63fdsnr, loudbang and 40ragtopdown like this.
  9. DRD57
    DRD57
    Well, that took a lot longer than I thought it would. We waited for the floor from UPAC for 3 months It's finally here and it looks good. While we were waiting we got the cross members and motor mounts riveted to the frame. 010.JPG 011.JPG 012.JPG
  10. DRD57
    DRD57
    We bolted the floor on the frame and started the modifications to clear the Model A rear cross member.
    Stogy, ls1yj, 40FORDPU and 5 others like this.
  11. Looking good, Don. :)
  12. A Boner
    A Boner
    Don, make sure you document your "matching paint tricks" like you did with your green deuce.
    loudbang and DRD57 like this.
  13. DRD57
    DRD57
    Finishing up the 00058.JPG 00059.JPG 00060.JPG 00061.JPG 00062.JPG 00063.JPG trunk floor to cover the cross member.
    Stogy, PONTNAK123, ls1yj and 5 others like this.
  14. DRD57
    DRD57
    Set the body in place and line it up in preparation for the patch panels.
    00064.JPG 00065.JPG 00066.JPG 00067.JPG 00068.JPG 00069.JPG 00070.JPG 00071.JPG
  15. DRD57
    DRD57
    Fitting the patch panels.
  16. DRD57
    DRD57
    Finishing the patch panels.
    00078.JPG 00079.JPG 00080.JPG 00081.JPG 00082.JPG 00083.JPG 00084.JPG 00085.JPG 00086.JPG 00087.JPG
  17. DRD57
    DRD57
    The rear panel was toast so, we replaced it with a part from UPAC and the bottom of the trunk lid had to be fabricated to repair the rust and fit the trunk to the hole.
  18. A lot of work but will be well worth it.
  19. Malcolm
    Malcolm
    from Nebraska
    Coming along nicely.. Thanks for sharing with us, Don!
  20. Looking great so far!!
  21. A Boner
    A Boner
    Hey Don, Home Depot sells small containers of their oil base house paints, as test samples, as an aid for customers to get the exact color they are looking for. Have them mix up a matching maroon sample, and then get samples both darker and lighter in graduated steps to match all the original different maroons that have developed over the years on the 5W body. Should be able to get a bunch of different shades for not much $.
    Patiently waiting for the final touch on this work of art!
  22. Quality craftsmanship..nice build.
  23. brady1929
    brady1929
    Don,
    Where did you get the patch panels? Specifically, between the door and the wheel well, please.
  24. Very nice. :)
  25. DRD57
    DRD57
    0C1A2695-F18F-42B5-B371-5A4D3B5937F0.jpeg BA8F3759-21EC-4E27-965A-EF3AE02D63B3.jpeg
    Fenders are patched and fitted.
  26. DRD57
    DRD57
    The floor and rear panel are United Pacific , all the other patch panels are from Mac’s.
  27. brady1929
    brady1929
    Thank you very much.
  28. DRD57
    DRD57
    You’re welcome
  29. Fitnessguy
    Fitnessguy
    great looking build so far!
  30. DRD57
    DRD57
    Most of the work on this project over the past few months has been doing a little body work to the patched areas, saving a pair of 25 louver hood sides that had the lower edge trimmed off, and matching the paint to the abused and neglected finish that covered the few parts we didn't have to patch.
    We started with getting some Omni solvent based base coat, color matched to the maroon that was last painted on the car. Below that appeared to be an odd shade of red oxide primer. Below the primer appeared to be the original black and peeking out below that in a few spots was surface rusted bare metal.
    The painting process began with a coat of black epoxy primer then before spraying the next color we taped off a few odd shapes and spattered some rubbing compound on it. The second paint layer was a mad scientist mix of several different shades of epoxy primer to closely match the odd red oxide color. Then a little more tape and a little more rubbing compound splatter. The final layer was several coats of the color matched maroon base coat with a little hardener mix in it.
    Once all this cured the parts were pressure washed to expose and remove the rubbing compound splatter and the tape was out of the paint to reveal the different layers. Next up was scuffing the finish with Scotch Brite pads, various grits of fine sand paper and some buffing with coarse compound to get the overall finish to match the old.
    A little trial & error and making it up as we went. It's mostly just mocked up again. We still have to get a fuel tank and the front valance and get them painted then we will do a little more to get the final finish where we want it. So far I think it's looking pretty cool and just what the customer wanted.
