SOLD Ford Split Front Radius Rods These are split '37-'40 and fit the 2 1/4" thick axle. Will work with a 2" axle with a spacer. No rust pits, not bent. Nice smooth job with adding the weld in bungs for the tie rod ends. These ends are larger than the standard Ford tie rod ends. 1/2" hole drilled in each one. I don't know what for. Easily repaired if you don't need them. $150 + shipping
