Technical Transmission removal advice needed 36 Ford
Discussion in 'Traditional Hot Rods' started by edwardlloyd, Jun 24, 2019.
  1. edwardlloyd
    edwardlloyd
    from Germany
    I'm about to swap a 39 transmission into a 1936 Ford. As I have the rear axle out anyway I've figured I can remove the transmission with the engine in situ but it's tight.
    Can anyone who's done it this way advise me if I need the raise the rear on the engine a little bit? I'll remove the UJ of course, but does it come out with the rear transmission mount still attached?
    Thanks
    Ed
    Sent from my SM-G935F using The H.A.M.B. mobile app
  2. Boryca
    Boryca
    from Detroit
    Trans mount stays on. You'll definitely have to support the rear of the engine, as once you pull the trans there's nothing holding it up. Talk to 6 guys and you'll probably get 6 different ways to do it, but I like to pull the floorboards and put it in from the top (on a truck, might be too much a PITA on a car?). I find I have way more control, etc. and they go in easy for me that way.
    Hnstray likes this.
  3. tub1
    tub1
    from tasmania
    only way is remove floor support engine ,I use a bracket I made that sits on the radius rods to support the engine undo the bolts out she comes , long time ford drivers are used to this lol
  4. clem
    clem
  5. edwardlloyd
    edwardlloyd
    from Germany
    Yes I've got the floor out. So yes I'll need to support the engine of course. Then just pull the transmission back and up land out eh?
    It's a convertible with the seat out so I've plenty of room inside. 20190624_130457.jpeg
    Hnstray likes this.
  6. I have aways pulled them out through the top.
  7. WB69
    WB69
    from Kansas
    I've done it both ways. A lot easier from the top if your floor boards come out.
  8. Boryca
    Boryca
    from Detroit
    You're halfway there! Don't forget to disconnect the clutch linkage, I've forgotten that and it's a bitch when you remember with the trans dangling from your fingertips. :p
    edwardlloyd likes this.
