Projects 32 Roadster project
Discussion in 'Traditional Hot Rods' started by HomemadeHardtop57, Jun 16, 2019.
  1. HomemadeHardtop57
    HomemadeHardtop57
    Started banging away on a roadster project I picked up to finish. My good friend put this together. Original steel with some Brookville patches. Original rails, built up 324 Olds, 37 LaSalle trans, 39 dash, 40 front end with Lincoln brakes. Was bodyworked and sprayed with a flattened down single stage.
    Runs and drives but needs a few things. I upholstered the seat about a year ago for the former owner.
    20190615_155355.jpeg IMG_20190613_161848_509.jpeg 20190613_160146.jpeg 20190615_204356.jpeg IMG_20190613_161848_503.jpeg 20190613_160119.jpeg
    Sent from my SM-G892A using The H.A.M.B. mobile app
  2. Stogy
    Stogy
    Congratulations on the new member in the Family... A great base for another inspiration in Hotrod...Big plans Jerry? Look forward to your well honed take on things...it sure has a lot to offer already...;)
  3. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    I dig that Olds powered roadster. Man what a score!!!!
  4. chevyfordman
    chevyfordman
    Nothing more fun than a 32 Ford roadster.
    lothiandon1940 and loudbang like this.
  5. brady1929
    brady1929
    Can't wait until you put your spin on it.
  6. A Boner
    A Boner
    Nice, looks like the only thing that needs to spin is the odometer!
  7. Squablow
    Squablow
    Great car, dig the Olds/LaSalle combo. You mentioned the '40 frontend, is the wishbone also '40? And is it unsplit? I've got a '40 wishbone for my '34 and I was wondering if that works/fits.
  8. HomemadeHardtop57
    HomemadeHardtop57
    They are split. The brackets to mount the wishbone ends are on the inside edge of the frame and also angled. Looking from up above it appears that they are not split doing it this way. These 37-40ish front ends are tough because you have very little room for tire turning clearance when splitting the bones. I can send ya pics of the mounts if youd like
  9. HomemadeHardtop57
    HomemadeHardtop57
  10. loudbang
    I like your other build thread and your good work. Will be following this one along too. :)
    1947knuck and brady1929 like this.
  11. GordonC
    GordonC
    Nice ride!
  12. Squablow
    Squablow
    No need for pics, just curious how it was done. It does look very nice the way you have it set up, I appreciate the response.
  13. A Boner
    A Boner
    How about posting the pics so we all can see!
    -Thanks
    kidcampbell71 likes this.
  14. 56shoebox
    56shoebox
    Is there any particular reason to mounting the brackets on the inside or outside of the frame rails? My 31A, on the original frame, with split bones has the brackets mounted on the inside rail and the wishbone connects on the engine side of the bracket. This puts the rod end and zerk fitting very close to the exhaust.
    Stogy and loudbang like this.
  15. oldbanger71
    oldbanger71
    good to start with.... will follow this thread.
  16. HomemadeHardtop57
    HomemadeHardtop57
    On 28-36 axles, when splitting bones the ends can be mounted on the outside or inside the frame rails..and all points in between. Its a matter of where youd like them. 37-41 axles have a small distance between the spring perch hole and the kingpin hole. If you dont tuck the ends of the bones under when splitting, ( using a 37-41 axle) the tires will hit the bones when turning.
    Bringing the rod end in from the back or through the front of your mounting plate is all preference. I have seen it done both way
    lothiandon1940, Stogy and loudbang like this.
  17. HomemadeHardtop57
    HomemadeHardtop57
    Sewed a tonneau cover and started working on a 32 dash for a swap. Temp gauge out for repair.
    20190629_163722.jpeg 20190629_164023.jpeg IMG_20190630_001709_652.jpeg 20190701_210106.jpeg
    1947knuck, enfieldjoe, 35cab and 8 others like this.
  18. Stogy
    Stogy
    Hi Praise from this vantage point...and that is a very regular occurrence with your well honed understanding of the World of Vintage Hotrod...Always impressive work and detail @HomemadeHardtop57
  19. BJR
    BJR
    A car that nice deserves shiny paint!:)
  20. x77matt
    x77matt
    Been watching on instagram- love your car! Really cool traditional choice of parts to go on it!
  21. HomemadeHardtop57
    HomemadeHardtop57
    Some lettering by Zach Suhr. Going to chop the windshield next IMG_20190707_185546_261.jpeg IMG_20190707_185546_248.jpeg
    1947knuck, brEad, enfieldjoe and 9 others like this.
  22. alchemy
    alchemy
    That art by Zach looks good! He may have a career ahead in that field. ;)
  23. HomemadeHardtop57
    HomemadeHardtop57
    1947knuck, pivir123, brEad and 6 others like this.
  24. gordspeed
    gordspeed
    from Oregon
    Before:
    Nice Car!
    Now:
    Really Cool Car! :)
  25. HomemadeHardtop57
    HomemadeHardtop57
  26. HomemadeHardtop57
    HomemadeHardtop57
    Got the dash swapped out this morning. Just have to tidy up some wires and we are good to go 20190711_175952.jpeg 20190711_180112.jpeg
  27. Stogy
    Stogy
    :rolleyes:...You are fortunate that that other dash which was I think 40 Ford came out so easy...and that does look right at home...
  28. HomemadeHardtop57
    HomemadeHardtop57
    The other one took 3 hours to get out. Lol
    loudbang, lothiandon1940 and Stogy like this.
  29. did you consider flipping the insert upside down?
  30. enfieldjoe
    enfieldjoe
    from Eustis, FL
    Very nice looking traditional 32. Been searching for one with that look...
