Technical 1932 Roadster Install door check straps
Discussion in 'Traditional Hot Rods' started by Jamoke, Jun 8, 2019.
  1. Jamoke
    Jamoke
    I'm looking at the kit and it looks like pre threaded screws . But don't see pre threaded holes in kick panel or door panel . Am I supposed to drill and tap or use sheet metal screws to attach . Sorry never installed this type of door check . Any help would be great
    Thanks Tommy
  2. Are the factory holes hidden behind the door and kick panel upholstery?
    Phil
  3. Jamoke
    Jamoke
    It's a Brookville body I've never had the panels off so I don't know I'm not sure if Brookville goes to that extent of building them
  4. hightower611
    hightower611
    here is a pic I took at one of their open houses (Brookville)
    It shows the location of the holes.
    town sedan and loudbang like this.
  5. Jamoke
    Jamoke
    Very cool thanks that works
    Thank you so much
  6. Fogger
    Fogger
    Remove the kick and door panels and you'll see the threaded inserts where the straps attach. Same on original and Brookville roadsters. 12-24 threads. The straps mount on top of the panels.
  7. Jamoke
    Jamoke
    Thank you so much for all the help
  8. clem
    clem
    Any one have a pic of one correctly installed ?
    I have used the other type and not that thrilled with it.
