Projects lets see photos of your 29 sports coupe made into a hard top
Discussion in 'Traditional Hot Rods' started by marcshall, Jan 31, 2019.
  1. marcshall
    marcshall
    or a three window coupe and how you did it thanks
  2. Why not just get a coupe? I’m all for hotrodding, but we need more sport coupes. [​IMG]
    Stogy, Dannerr and scrap metal 48 like this.
  3. sloppy jalopies
    sloppy jalopies
    Should be a bolt on, as the '28-'29 coupe, special coupe and sport coupe started life as almost identical bodies...
    some interior brackets [wood] are model specific... bought a pair of roof quarters at a swap meet couple years ago... they are out there... toughie will be the roof to quarter molding... go M go...
  4. Fixxxr
    Fixxxr
    from Sk, Canada
    Might in fact be a bolt-on, but the issue I had was not being able to find the pieces. Ended up starting with the back section of tudor sedan followed by fabricating the belt mounding strip using some flat iron. Not fun, not fast, but do-able for the average joe like myself that doesn't have a lot of fancy tools.
    Deescott, mgtstumpy, redoxide and 2 others like this.
  5. sloppy jalopies
    sloppy jalopies
    I see you made your own roof to quarter molding... good stuff...
    but for the interested ;
    try '30-'31 one ton AA truck cowlbands, made of steel not stainless...
    the radius is a very close match to the quarter's...
    the leading edge is narrower than the rear of the band... handy as the roof will be narrower than the quarter tops... weld anchor bolts across the back and nuts around the corners and sides...
    the C Bs are not long enough to span the rear of the cockpit... you will need 2... but bands with 3" rusted off the bottom are just what you need...
    Stogy likes this.
  6. redoxide
    redoxide
    same but different. mine was a special coupe with the special coupe bits beyond rescue, so made the rear roof section as close as I could from 19gauge steel swaged a strip and stretched and shrunk it into submission I wasnt worried about originality, more saving an unwanted body so I welded the top and bottom together . I think the original is actually bolted on ? I haven't got round to making the rear window aperture yet. Ive been looking for a donor part from the likes of a sedan to graft in but no luck s far . Might have to get around to making some tooling when I find time ..
    DSCF3864 (1).JPG DSCF3866.JPG DSCF2931.JPG DSCF3869 (2).JPG DSCF3873.JPG DSCF3877 (2).JPG DSCF3858 (2).JPG
  7. sloppy jalopies
    sloppy jalopies
    wow ! … good stuff, nice work, gonna be 1 good looking coupe...
    go red go !
  8. 51box
    51box
    from MA
    This was a special coupe and I put a UP 32 5W roof retaining the special coupe belt line piece. Only reason I did this was because I couldn’t find standard panels to bolt on which would have been much less time consuming. 3DE6941B-6B60-4CF9-90A8-5A9637D6B04E.jpeg
    tomkelly88, Jet96, D-Russ and 16 others like this.
  9. redoxide
    redoxide
    ^ great solution ..
  10. sloppy jalopies
    sloppy jalopies
    not stepping on toes, but I think I like the later roof better...
  11. madfish
    madfish
    Is there any way you could post a front and side view? Looks great from the rear.
    shadetreerodder likes this.
  12. This one is homemade from a bugeye sprite top bows and cutting, stiching and dyeing some bimini top fabric. But it was Hard to make. Just to keep the breeze off my neck. Guess I could fiberglas it.
    redoxide and scrap metal 48 like this.
  13. scrap metal 48
    scrap metal 48
    Be proud of a sports coupe.. They can be very cool...**clic pic** ImageUploadedByH.A.M.B.1440528829.479202.jpg drivermain2.jpg 147851.jpg 1923-model-a-sport-coupe-pinter-left-profile.jpg
    Jet96, camcrusher, D-Russ and 9 others like this.
  14. Stogy
    Stogy
    Vintage Aviation Inspired
    Riveted Aluminum Removable Top
    Hamber @Koz's Handiwork
    I have not removed it however but just saying...
    This is technically a hardtop like the Sport Coupe @Retson the Racer posted and they actually take the shape of the canvas tops they replaced...
    Yes I think more should exploit the Uniqueness of the Sport Coupe...and yes I didn't build it but am quite proud of it...;)
    clem, Jet96, camcrusher and 1 other person like this.
  15. chev34ute
    chev34ute
    Not mine but a mates 29 Coupe. But I lent a lot of my own coupe parts so he could repair it including the quarter panels, cowl, seat frame and even my deep throat shrinker/stretcher so he could shape up the centre roof section. The rear window was made up from the discarded door frames from the doors that the previous owner had capped. The center panel itself was made from a roof skin from a late model sedan.
    5B42C954-127A-48F2-8986-DD11E3F8EBF0.jpeg A4406622-6BC4-492F-8C99-F9D171070B80.jpeg
    dwollam and redoxide like this.
  16. camcrusher
    camcrusher
    from Candor, NY
    Here's my '29 Sport Coupe. I plan on making a detachable cloth top for it eventually. I just want to get it running and driving first. IMG_20190524_182132107.jpg IMG_20190524_182142704.jpg IMG_20190524_182202346_HDR.jpg
    Jet96 and Stogy like this.
  17. clem
    clem
    ^^^^^^^It’s got potential, and a perfect chop !
    camcrusher and Stogy like this.
  18. lonewolf52
    lonewolf52
    I agree.
  19. low budget
    low budget
    from Central Ky
  20. rcavaliers
    rcavaliers
    from downey
  21. camcrusher
    camcrusher
    from Candor, NY
  22. justabeater37
    justabeater37
  23. camcrusher
    camcrusher
    from Candor, NY
    It's about 3"- 4".
  24. clem
    clem
    You’ve started this neat thread, but how about a few photos of your avatar ?
    Is that what you are wanting a hard top for ? Thanks.
  25. clem
    clem
    ........and so you should be proud of it. - a real hot rod !
