Projects 33-36 Ford Solid Axle......I Think
Discussion in 'Traditional Hot Rods' started by Potts, Jun 1, 2019.
  1. Potts
    Potts
    Pretty sure what I have here is a 33-36 Axle Assembly. I've looked at what I could find online and I'm still not positive if it's a 32 heavy or the 33-36 setup? Any help would be appreciated.
  2. BJR
    BJR
    Looks like 37 to 41 to me.
  3. dlw1932
    dlw1932
    from Nebraska
    It’s a 1935 front end. It has spring ahead of axle and mechanicals. Because it doesn’t have wide fives tells it’s a 35 as well. The axle will go 33-36.
    47ragtop and Fordors like this.
  4. RoddyB34
    RoddyB34
    It’s a 35 ,,,the axle has the longer distance between the king pin and perch bolt ,,axle will work for Model A onwards,,
    Fordors likes this.
  5. Looks like it has 42 to 48 square back spindles. Someone might have put this together with spare parts.
    town sedan and Just Gary like this.
  6. '33 thru '36 has 50 1/2" kingpin center to center, 36 1/2" spring perch center to center.
  7. Andy
    Andy
    All 1935
    Fordors likes this.
  8. 32-36 were square as well,but a bit smaller with a smaller backing plate pattern.
    Montana1 likes this.
  9. Fordors
    Fordors
    The big giveaway is the smaller span between the king pin yokes with the thrust bearing on top of the spindle.
  10. dudley32
    dudley32
    definitely '32-34...also in first pic you can see the ventilated brake drums
  11. Thanks, I never knew that as I've only dealt with hot rod stuff and not original. I learned something today! ;)
  12. 47ragtop
    47ragtop
    Times 2 !!
  13. Potts
    Potts
    You all are Great! Looks like it's a 35!
  14. treb11
    treb11
    Note the spring is in FRONT of the axle (35-48) not on TOP of the axle.
  15. dudley32
    dudley32
    Yep...you're right a hodgepodge...
  16. BJR
    BJR
  17. 421-6Speed
    421-6Speed
    Bingo, and the wishbone on the ends for the spring shackles tells you its 35-36 and the drums are says 35.
  18. Potts
    Potts
    Anyone have a new / like new pair of cast headers for a Flathead in a 1938 Ford Coupe, original steering? I'd be willing to trade this front end set-up for them. I wouldn't want to ship this front end so pick up only. Southern WI.
  19. BJR
    BJR
    Why does the axle look more like the 37 to 41 in the picture I posted? Or is that picture wrong?
  20. Deuce Lover
    Deuce Lover
    Its a '35 as noted by several.Measure the axle boss at the wishbone.'37 and later are 2 1/4".'32-'36 are 2".
  21. millersgarage
    millersgarage
    picture is correct, just the description goes to the axles below them.
    BJR likes this.
  22. BJR
    BJR
    Now I feel really stupid!:eek:
