Technical Long time to build oil pressure
Discussion in 'Traditional Hot Rods' started by Marcus Jacobsen, Jun 1, 2019.
  1. Marcus Jacobsen
    Marcus Jacobsen
    Hey guys.
    Im a little concerned about the time it takes to bulid oil pressure, in my newly rebuild sbc.
    It takes 8-10 seconds of cranking, or up to 5 seconds of idleing, before the gauge needle starts to move, even with engine off a pretty short time.
    Its a 1986 350 with stock oil cooler adapter over the oil filter, HV oil pump, and its an anti drain oil filter.
    The oil cooler is mounted in front of radiator with inlet at the bottom and outlet att the top.
    Is this normal or something to be conserned about?
    Ill be thankfull if anybody whold share their thoughts
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    8-10 seconds is a lot of cranking , why?. My be just gauge/sending unit lag . What's running oil pressure ?
    Marcus Jacobsen likes this.
  3. saltracer219
    saltracer219
    Most likely the gauge, check it with a good mechanical gauge.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Gauge topic covered. Next to try if gauge isn't the issue. Try running with oil cooler adapter removed to see if there is any improvement. Sounds a little off topic by the way?
    Marcus Jacobsen and jaw22w like this.
  5. jaw22w
    jaw22w
    from Indiana
    Sounds like a tow vehicle. Oil cooler not normally needed on a hot rod. I would bet the problem is to be found in that extra 8 or 10 feet of plumbing for the oil cooler.
    Marcus Jacobsen and Deuces like this.
  6. Marcus Jacobsen
    Marcus Jacobsen
    I have a start button so it feels better to crank it till i get oil preassure, and its a mechanical gauge.
    Cold Idle pressure at 60psi and about 70psi at cruising speed.
    Sent from my Moto G (5S) Plus using The H.A.M.B. mobile app
  7. Marcus Jacobsen
    Marcus Jacobsen
    Its a new bosh mechanical gauge.
  8. Marcus Jacobsen
    Marcus Jacobsen
    Ive thought about that, i dont really need an oil cooler i think, My oil pan holds 9 quarts
  9. sdroadster
    sdroadster
    Take off the oil cooler, and plumbing and see how long it takes to build pressure.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Hope the oil cooling system was flushed before rebuild went in?
  11. woodiewagon46
    woodiewagon46
    from New York
    If your remote oil cooler is mounted higher than the pan, the oil will drain back to the pan. When you start your car the oil takes a few seconds to recharge the lines.
  12. Marcus Jacobsen
    Marcus Jacobsen
    That makes sense, but this engine had the oil cooler built in the Side of the radiator, on the van it came from, and that is sertanly higher than the oil pan.
  13. Budget36
    Budget36
    Consider that a SBC's lifters will clatter for a second after an oil change sometimes, then never again.
    I/e if you don't hear the lifters clattering, I think you're okay.
    Just screw in a mechanical gauge into a pressure port and see what you really have.
    firstinsteele likes this.
