Technical Kingpin bushings
Discussion in 'Traditional Hot Rods' started by topher5150, May 18, 2019.
  1. topher5150
    topher5150
    Putting in my kingpin bushings I thought I had the grease holes lined up but I didn't. The holes don't look too far off, but they aren't coming out with a fight, can I drill a new hole instead?
    Sent from my XT1710-02 using The H.A.M.B. mobile app
  2. Dirty Dug
    Dirty Dug
    Drill away.
    dana barlow likes this.
  3. X2-carefully.
  4. Cliff Ramsdell
    Cliff Ramsdell
    You bet, and clean up the burrs when done.
    Cliff Ramsdell
    topher5150 likes this.
  5. "Drill 'em, Dano!".
  6. And connect your new hole to the groove inside the bushing if you missed by that much.
  7. topher5150
    topher5150
  8. alchemy
    alchemy
    The bushings are shorter than the spindle boss, so it should sit down from both directions so nothing rubs the bushing edge.
