Projects 1930 Ford Coupe Build
Discussion in 'Traditional Hot Rods' started by m.ralph, May 4, 2019.
  1. m.ralph
    m.ralph
    Three months ago, I bought a full fender coupe with original drive train. I disassembled the coupe and removed the coupe body, that is all that I was going to use. I sold all the rest of the coupe. [email protected]
  2. m.ralph
    m.ralph
    After removing the coupe body, I ordered a 1932 Ford pinched frame from Brookville.
    Thor1, spurgeonforge, swade41 and 4 others like this.
  3. m.ralph
    m.ralph
    Installing Ford nine inch rear end assembly with triangulated 4 bars and coil over shocks.
    kidcampbell71, Thor1, swade41 and 2 others like this.
  4. m.ralph
    m.ralph
    Installing dropped front axle, Posey springs, and split wishbones. Then changed my mind and installed radius rods instead. Because the drag link was going to be too low.
  5. m.ralph
    m.ralph
    After installing the front axle assembly and rear axle, the chassis was a roller. With the chassis finished, I installed the engine and transmission. Then I mounted the body.
    kidcampbell71, Thor1, swade41 and 4 others like this.
  6. fastcar1953
    fastcar1953
    Looking good . Working fast. Keep updating.
  7. m.ralph
    m.ralph
    thanks Fastcar1953
  8. m.ralph
    m.ralph
    Added a few more goodies.
  9. m.ralph
    m.ralph
    I installed the front floor and trimmed the hole for the American Shifter and adjusted the neutral safety switch. Also mounted the brake pedal. Cut a hole for access for the master cylinder and made a cover for it.
    Thor1, Phil55Kratz and loudbang like this.
  10. fastcar1953
    fastcar1953
    At the rate your moving it should be done this week. wow .
    loudbang and lothiandon1940 like this.
  11. fourspd2quad
    fourspd2quad
    Very nice! great body to start with too.
  12. m.ralph
    m.ralph
    Thanks fourspd2quad, yes it is a good coupe body. Thanks, fastcar1953 I can usually build them in 2 or 3 months.
    Zettle Bros. and loudbang like this.
  13. m.ralph
    m.ralph
    Next came the dash, gauges, and wiring. I make my own harness for the dash with one or 2 connectors. So the dash can be removed easily, instead of removing every wire off each gauge.
    Thor1, swade41 and loudbang like this.
  14. 3banjos
    3banjos
    from NZ
    Your motor looks pretty low, how close are the drag links to bottom pulley. But you did say you've done it before.
  15. Phil55Kratz
    Phil55Kratz
    Sweet! Lookin good
    Dino 64 and loudbang like this.
  16. m.ralph
    m.ralph
    3banjo, yes I build about 3 cars a year. Mostly 32 Fords, coupes and roadsters. No fiberglass , all Henry Ford bodies or Brookville. Thank you Phil55Kratz.
  17. m.ralph
    m.ralph
    Steering column and wheel mounted down to a Vega box for cross steering.
  18. m.ralph
    m.ralph
    A little more goodies for the engine area.
    Thor1, spurgeonforge, swade41 and 2 others like this.
  19. m.ralph
    m.ralph
    Mounted the 15 gallon gas tank and battery in the trunk. Also installed a battery cut off switch.
    loudbang and Aaron D. like this.
  20. m.ralph
    m.ralph
    then decided on some Lake style headers with baffles.
  21. m.ralph
    m.ralph
    A little drive around the block to test everything out.
  22. Zettle Bros.
    Zettle Bros.
  23. m.ralph
    m.ralph
    Thanks to everyone that left comments or likes.
  24. Zettle Bros.
    Zettle Bros.
    Was wondering if you were going to chop the top any.
  25. Bajita
    Bajita
    from Laredo
    Project coupe looks almost done. Will you get a hood for it.
    Looks like you didn't have to cut the firewall, to fit the motor.
    Howd you do that. Looks good. No chop.
  26. m.ralph
    m.ralph
    Thanks everyone that asked about the chop. People that know me, know it has to be chopped. Last week I took it to my friend Lee Moore ( 409 679-2660) at Lee's Speed Shop in Orange, Texas to get a chop. It was hard to decide how much. I knew it had to be between 4.0" to 6.5"
    Zettle Bros. likes this.
  27. m.ralph
    m.ralph
    Bajita , On the firewall, I get the engine as far forward as possible then use a little force to push the firewall back a little to clear the distributor cap. I don't normally use hoods on my cars. I will be installing a 3 deuce manifold soon, so I like to show off the engine area. I usually put 3 deuce setup on all cars.
    Dino 64, Just Gary and loudbang like this.
  28. Zettle Bros.
    Zettle Bros.
    M.Ralph keep us posted on the outcome of the chop, love to see it.
    m.ralph likes this.
  29. Bajita
    Bajita
    from Laredo
    Got it thanks for the firewall info.
    Chop top it is. Any paint color in mind.
  30. sloppy jalopies
    sloppy jalopies
    nice hot rod !
    Careful how much you chop, as it directly relates to the rod's rake...
    the more ; biggie rears, tiny fronts, 4" dropped, reversed eye, stock visor, the less vision...
    don't get carried away... you can always chop it more later...
    a crook in the neck to see what is 10 car lengths out in front is fine in your 20's...
    30 years of working, a little grey hair and that will change...
    ….. my personal opinion only.
    nunattax and fastcar1953 like this.
