Hot Rods FE Motor In A '34 Coupe?
Discussion in 'The Hokey Ass Message Board' started by CAHotRodBoy, Apr 16, 2019.
  1. CAHotRodBoy
    CAHotRodBoy
    Just found a 427 side oiler for sale and thinking about buying it for my '63.5 Galaxie replacing my brand new built 390. I have a little Buick 231 in my '34 three window now and was thinking about replacing it with the 390. Anyone running an FE motor in a '34? Wondering how it fits and if the weight is too much.
  2. IronFord
    IronFord
    from NoDak
    You would have to change or cut the firewall. A 35/36 ford pickup/truck firewall works really well. Put the 427 in the coupe leave that 390 where it's at
  3. oldiron 440
    oldiron 440
    loudbang and IronFord like this.
  4. saltflats
    saltflats
    from Missouri
    Put one of those BBM tunnel wedge top ends on it, that should knock a few # off the front end. ;)
    loudbang and mad mikey like this.
  5. boutlaw
    boutlaw
    Have 427 SO in my 31 Model A. Used Pete and Jakes spring and Super Bell axle. Have 8000K + miles on the car so far with no issues. The FE is not as heavy as folks say, especially if you get rid of the stock 90 pound intake. I recessed my firewall 5 inches just to move the engine back some but the FE is no longer than a BBC. Im even running a clutch so all the naysayers that speak of the FE's massive size are just misinformed IMO. Id stick the 427 in the coupe as well, just saying. I ran iron heads forever on the 427 but am changing to BBMs, so aluminum heads will also reduce engine weight if you are overly concerned.
    loudbang, Boneyard51 and arkiehotrods like this.
  6. CAHotRodBoy
    CAHotRodBoy
    Cool! Any chance you could post some photos of your car?
    Thanks.
  7. boutlaw
    boutlaw
    They are in my HAMB member album .
  8. boutlaw
    boutlaw
    Pics are in my HAMB member album for ez viewing....Will send PM
    BOutlaw
  9. FrozenMerc
    FrozenMerc
    Where does this myth keep coming from???
    An FE with an aluminum intake and iron heads weighs LESS than an all iron SBC.
    The FE was the first engine produced utilizing thin wall casting techniques. Of course, this limits the over bore capabilites, and core shift can be a problem, but it kept the blocks weight down considerably.
    Dave Schuten's Iron Orchid does just fine with an FE.
  10. Not a 34 ford , but fit good in my 34 chev ,actually the chev was on a 34 ford frame .
    SOHC427 and loudbang like this.
  11. CAHotRodBoy
    CAHotRodBoy
    Looks cool. A Ford in a Chevy! Well maybe, is it registered as a Chevy or a Ford? A '34 Ford has VIN/SN on frame.
  12. An FE in a '34 Ford coupe is as good as it gets.
  13. aftermarket 34 ford frame ,body has Chevrolet tags and ownership
  14. crf500
    crf500
    8A55A077-FE49-4C2B-94A8-22FCBA4E30A1.jpeg 651526F0-ECA3-42E0-931E-70A3653043B4.jpeg 892326B8-BDA0-4855-A6C7-D70386D7B846.jpeg 34850803-9068-4DD4-9FC5-1188477B7D53.jpeg
    they actually fit pretty good. The first picture is when I had the 427 in it with full hood. Stock length. It drove just fine! That bullshit about to heavy to big. Comes from the everyone do the same thing guys!
    I won’t say who! If you need more detailed pics just look for The Burrows Coupe.
    I had mine sitting high in the saddle. Which is not even necessary. I would just run the big pan that is flatter on bottom. Good luck!
    mgtstumpy, Jeff Norwell and loudbang like this.
  15. SOHC427
    SOHC427
    An FE, but not a 34, a 40 Willys instead. It's all doable...
    Jeff Norwell, IronFord and loudbang like this.
