Technical 53/54 Chevy taillight I.D.
Discussion in 'Traditional Customs' started by agutto13, Apr 18, 2019.
  1. agutto13
    agutto13
    Hey all, just picked up someone else's project a couple weeks ago and I need some help identifying what taillights are on her.
    I thought 55 Chevy, but the taillight trim I have is much wider than what's on the car!
    Thanks guys, heres some pics!
  2. 55 Plymouth?
    Stock in a Plymouth-
  3. BJR
    BJR
    55/56 Chev.
  4. agutto13
    agutto13
    Thanks for the reply! The Plymouth lights seem to be too large
  5. agutto13
    agutto13
    The last pic I posted is the 55 Chevy tail trim.
    Possibly just a poor fab job
  6. This you tube might be of help. My first thought, was that it was for a 56 Chevy light.
    Bob
  7. Chrisbcritter
    Chrisbcritter
    Do you have any bezels that came with these? It looks to me the PO may have been trying to french in a set of lenses that would have been cut down to fit the openings.
    agutto13 and Hnstray like this.
  8. Hnstray
    Hnstray
    from Quincy, IL
    I agree the openings are NOT correct for any of the lights mentioned above. The angles are wrong, the sharp corner at the transition from vertical to horizontal is wrong and I think the overall size is wrong.
    agutto13 likes this.
  9. Squablow
    Squablow
    My first thought is it looks like they made the opening to use the top part of a '55 Buick lens without the bezel.
  10. Hnstray
    Hnstray
    from Quincy, IL
    Possibly the '56 Buick lens..........
    Squablow likes this.
  11. rudestude
    rudestude
    My guess would have been the Plymouth with out the bezel..then there's the 56 Chevy with out bezel..is the extension sheet metal or pot metal? The 56 Buick lens goes into a stock 55 Chev tail light assembly if you remove the lens and divider and back up lens then you can put the Buick lens in its place a little file work needs to be done on the Buick lens to make it fit right..so how about Studebaker? I'm not sure what' the body contour is under the bumper . With out the bezel ...mmmm.. 20190418_192136.jpeg 20190418_192138.jpeg 20190418_192153.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
  12. Squablow
    Squablow
    I agree now seeing those closeups, '56 more likely.
  13. agutto13
    agutto13
    Now that you mention it, I can see that seems to be the case. The car came with the 55 Chevy taillight kit, but neither the lenses or bezel fits
  14. agutto13
    agutto13
    This looks promising!
