Technical rear end gear ratios
Discussion in 'Traditional Customs' started by fordcoupeguy, Mar 27, 2019.
  1. fordcoupeguy
    fordcoupeguy
    Hello all,I have a 51 Ford V8 and I need to know the rear end gear ratio. I would like to run a 200r trans. and keep the stock rear. Wondering if that will work out. Oh ya,it will have a 283. Cant seem to find any info on the net.
  2. Hnstray
    Hnstray
    from Quincy, IL
    Depending on what engine and trans your Ford had when new, it is probably a 3.70, 3.90 or 4.10. Any of which would work with an Overdrive Automatic and a 283. They would range from about 2.60 to about 2.75 effective ratio.
    lothiandon1940, mgtstumpy and Hombre like this.
  3. Stan Back
    Stan Back
  4. Mike VV
    Mike VV
    from SoCal
    Agreed too.
    Mike
    XXL__ and lothiandon1940 like this.
  5. '51 Ford with overdrive 4:11
    with 3 speed 3.73
    with Fordomatic 3.31
    Optional with Fordomatic 3.54
    lothiandon1940 likes this.
  6. Unless your 51 Ford is a pickup.
  7. fordcoupeguy
    fordcoupeguy
    Thanks for the info guys. It was a flathead with a 3 speed so it must be a 373. Should work well with an overdrive.
