Technical 1939 Mercury Build
Discussion in 'Traditional Customs' started by swissmike, Jun 28, 2015.
  1. Is that a 5 window Coupe, with the roof whacked off???
    Not for the faint of heart.
    Than again, none of this old car shit is.
    Cool project
    Brother Mike has Mad Skills
    swissmike likes this.
  2. oliver westlund
    oliver westlund
    awesome project, great metsl work! im taking notes!
  3. Ed Angel
    Ed Angel
    It’s a 1936 Club cabriolet
  4. quickrack-alan
    quickrack-alan
    from Ireland
    Seriously impressive work and you still have to actually Hot-rod the thing!
    Wow!
  5. Toyjunky
    Toyjunky
    from Gilroy,Ca.
    Thanks for sharing, great workmanship !!!
  6. Ralph Moore
    Ralph Moore
    Hey I recognize that car!
    Love to see it back on the road again.
    I wonder if it ever spent time with mine on the streets of Fairbanks.
    swissmike and chryslerfan55 like this.
  7. swissmike
    swissmike
    I’m back for more..
    I seam sealed the body and all floor joint and subrails using 3m products (will post later).
    I decided to strip the frame and suspension parts. I made an axle puller for the rear drums but the first iteration deformed like taffy due to the insufficient thickness of the bottom flange (had suspected as much but gave it a try). Had success after making a 3/8” flange which was welded from both the inside and outside.
    I also bought a NOS axle knocker, basically an oversized Acorn nut which bottoms out on the axle and can then be hit with a sledge to break the bond between axle and hub.
    After a couple of whacks the puller made short work of it.
    The axle bolts / perches were extremely stubborn and repeated heating, penetrating oil,etc. only let me remove one nut with the impact wrench. The second ended up rounded and mangled beyond hope. I ended up chiseling out little pieces and cutting the perch flush. More heating and banging finally drove the perch out. With the first perch out I could rotate the axle to break the bond in the radius rod. But it took a come along - no chance by hand. Now the perch still held to the axle, but some creative hammer work finally got it out.
    Everything was pretty crusty, but the cotter pins were the worst part of getting everything unbolted.
    The brake pedal assembly had about 1/4” of hardened grease and dirt buildup, but cleaned up nicely with the wire wheel.
    The frame mostly only has surface rust, except where the rubber ball of the front radius rod sits in the crossmember. The rubber trapped moisture and partially rusted out the cup. I will remove the entire plate prior to sandblasting and replace the cup.
    jakespeed63 likes this.
  8. swissmike
    swissmike
    I was pleasantly surprised that the rear axle bearing races and axle tapers are in nice shape the axles rotate freely.
    I am still debating whether to drop the original axle or to go with a new one. Anybody have any recommendations? I am considering Kohler Kustom or Sid’s.
    https://www.droppedaxles.com/axles
  9. swissmike
    swissmike
    Found a nice 40 dash which I will use....
    Xtrom, heavydumper and 40two like this.
  10. alchemy
    alchemy
    Drop the original axle. Kohler does good work, I've had him drop an axle of mine.
    Nailhead Jason and swissmike like this.
  11. Just found this thread and spent the last few hours reading through it. Inspiring, great work and very well documented!
    Lines and swissmike like this.
  12. swissmike
    swissmike
    Okie Pete, Lines, brEad and 4 others like this.
  13. Lines
    Lines
    from Germany
    Loopking good. Nice to see how you solved the door gaps.
  14. 392
    392
    Great work and your eye for details show.
  15. swissmike
    swissmike
    Removed the spacer from the rear crossmember.
    Interesting to see that Ford used their own version of pop rivets.
    The problem area is the socket of the wishbone, where water accumulated between the rubber ball and the metal and rusted out the metal.
    I removed the crossmember plate to fix the rust through an d found the underlying socket to be rusted as well. I got a model A stamped cap, but it uses a larger 2.2” rubber ball, compared to the 39/40 Merc with two diameters.
    I decided to try to use the model A cap inside the frame, and make a new thicker crossmember plate to take up the space. The problem is obviously how to make a socket to reduce the diameter from 2.17” to 1.8” of the Merc rubber ball.
    I had a 3/16” plate which is the right thickness, but without a BIG press or forge there is no easy way to shape the cup.
    [​IMG][​IMG][​IMG]
    I pie cut the area to be able to hammer small section against the stamped piece. I made a separate piece for the center and started tracking everything in place. Now I wouldn’t have done this if it were not just a spacer. The overall thickness of the cup will be 3/8”, about double the stock thickness, once the model A cup is welded in place. There will be a lot of welding and grinding. But I’ll give it a try. It’s only metal...
    Okie Pete, Lines, brEad and 1 other person like this.
  16. Grandadeo
    Grandadeo
    Mike, glad you took time off from the Merc build to join us at the Black Dog yesterday. 20190302_111812.jpg
    heavydumper, BigO, hfh and 2 others like this.
  17. swissmike
    swissmike
    Thanks, Lee!
  18. Black Clover Custom
    Black Clover Custom
    Nice work on your car!
    So maybe heating it up with a torch... and getting a ball from a trailer hitch/reciever in the right size and hammer that down on the plate would save the grinding time. Just a thought.
  19. 59Tele
    59Tele
    What about using a piece of a trailer hitch that fits over the ball?
  20. swissmike
    swissmike
    Good ideas, but I don’t have a hitch laying around. I found metal places which make half spheres, but only in .120“ thickness.
  21. fantastic work, Mike, a pleasure to watch your thread.
    Cheers, Carsten
  22. swissmike
    swissmike
    Grinding and welding inside and outside...
    [​IMG][​IMG][​IMG][​IMG]
    After cutting out the stock inner socket, fabricating the new piece using the model a cap.
    Kage, Okie Pete and brEad like this.
  23. swissmike
    swissmike
    The bolt pattern of the Merc cap is smaller so the holes had to be filled and redrilled. I temporarily tacked the inner and outer pieces together to make sure everything is lined up.
    Welding in the nuts and using weld through primer before welding the inner plate in place.
    I added slots in the top plate to bend the sides down so they contact the crossmember. The two vertical pieces are about 1/8” taller than the crossmember. I suspect this was done to register the stock plate side to side during assembly. Anyway, I wanted to keep the socket at the same height so I will bend the ends down before welding the plate in place. I will use JB weld to fill any irregularities and gaps between inner and outer socket and to keep rust from forming.
    Kage, Okie Pete, BigO and 3 others like this.
  24. CURSED GEARS
    CURSED GEARS
    Pretty smart repair on that cup, but I would expect no less from you.
    BigO and swissmike like this.
  25. swissmike
    swissmike
    Thanks but I probably would do it differently now. This was a total overkill, but once I dipped my toe in it I had to go down that road. The top plate would be plenty strong by itself and I should have just turned a half sphere on the lathe and welded it in the plate and be done. Unfortunately the lathe at my work was just moved and has no power at the moment.
    BigO and Peanut 1959 like this.
  26. Amazing repair on that cup! It looks original. Very nicely done.
  27. Andy Kohler does killer work, and is the go to guy on the east coast. He does beautiful work.
  28. swissmike
    swissmike
    Final fitment; applying some jB weld to fill any remaining voids between the spheres and clamping in place. I will weld the plate solid after cure.
  29. swissmike
    swissmike
    Moving on to popping some frame rivets where rust developed between x member and frame rail at low spots on the lower rail.
    I drilled out the rivets and use an HF oscillating tool with flat carbide burr while keeping a gap open using a chisel and whatever I had laying around, working on small increments.
    After getting all loose rust out I used metal prep to neutralize the remaining rust and prepare for Por15 application next week.
    Letting everything dry out now...
    Starting to straighten the frame rails and crossmember using whatever fits in addition to the trusty BFH and dolly.
    I will use 3/8” carriage bolts with the heads slightly ground down to mimic the stock rivets. Thought about welding the frame and x member along the seam but decided against. Don’t want to trap water in the seam and also don’t want to locally change the springiness of the frame. There are cracks in the frame where the rear lever arm shocks were mounted. Work hardening of the frame eventually led to material failure. Will be easy to fix, but don’t want to provoke a similar result by welding in boxing plate/ x member.
    Kage, brEad and The 39 guy like this.
  30. swissmike
    swissmike
    Duplicate post deleted...
