Project 29 Tudor in Mass.
Discussion in 'Traditional Hot Rods' started by Mikel50, Apr 17, 2015.
  1. Tim
    Tim
    from KCMO
    Good looking gas cap, any idea if it’s vented or not?
  2. Are there any houses for sale on your block?
    Looks Perfect!
    loudbang and Mikel50 like this.
  3. Mikel50
    Mikel50
    Negative. The tank itself will be
    loudbang and Tim like this.
  4. Dick Stevens
    Dick Stevens
    Good work , that looks much better!
  5. mike bowling
    mike bowling
    Love the overhead shot! Did you hook your belt onto the chain fall trolley?
    Great progress - be time to fire that sucker up before you know it!
    patmanta, Mikel50 and loudbang like this.
  6. Mikel50
    Mikel50
    This afternoons project was in the Arts and Crafts type.
    Now that I’ve got things buttoned up on the frame and filler. It was time to start laying out the sheetmetal templates.
    It was a long afternoon of cutting heavy floor protection for templates.
    Started out laying out the main structure panels first
    After staring at the tank enclosure I decided it didn’t look as finished as I would like.
    So I added “wings” to the enclosure
    They will be mounted after the main tank enclosure will be mounted and will finish off the look and seal the entire rear of the car from the passenger cabin.
    It has to work ... I see I’m in my brain
    Like the rest of this thing I call a hotrod.
    I’m adding a ton of work to my plate but it’ll be how I want it to be in the end.
    IMG_4377.JPG [​IMG]
    Thanks to everyone throwing roses at me ... Im hard on myself.
    Even though this is the first car I’ve ever built, I expect a lot of myself.
    I push myself to do the best I can with everything.
    Thanks again
    48fordnut, biggeorge, Stogy and 9 others like this.
  7. NashRodMan
    NashRodMan
    No cup holders??!! LOL
    Mikel50 likes this.
  8. sloppy jalopies
    sloppy jalopies
    nice bulkhead, I like you extending it to the body sides...
    nows the time to make a couple access doors that take advantage of the space either side of the tank...
    your tools and skills will make a handy stash for a first aid kit, nylon towstrap, small toolbag, quart of oil, jug of water, blanket... etc. …
    you certainly don't need my advice, go mike go !
    Stogy, loudbang, brEad and 3 others like this.
  9. Mikel50
    Mikel50
    Opinions and advice are always welcomed.
    Already the plan. I’m way ahead of ya
    Stogy and loudbang like this.
  10. Mikel50
    Mikel50
    I was extremely fortunate to have the opportunity to buy a rare set of Early ford pattern Accessory Wheels made by Carter Mfg. for Firestone Tire Co in the mid 30’s.
    They have a Cast Steel Center that is riveted to a steel hoop.
    They were originally Chrome center with a black hoop.
    They’ll be all painted once the good weather comes.
    These are 17” and will find their home under the sedan or roadster when the time comes.
    They’re fresh from the Sand Blaster.
    They primed them for me and they’re looking like the Cats Ass.
    Found that early Chevy Baby Moons have a similar Dimension on the lip to fit inside the wheel.
    The original caps for these wheels are a bit bulky and more rare than the wheels themselves.
    Blessed to have these in my possession
    Can’t wait to see them painted striped with a sunburst pinstripe and wide whites.
    Hell Yeah
    Tim, biggeorge, Stogy and 5 others like this.
  11. wow, I bet they looked awesome with the chrome and black hoop. did the caps get painted body color originally?
    they are going to look great on the car.
  12. Mikel50
    Mikel50
    The caps that came on them originally were chromed.
    I’ll post up a picture. I think I have a few
  13. Mikel50
    Mikel50
    These are similar to the original caps
    Stogy, loudbang and brEad like this.
  14. Love those wheels with the chevy caps!
  15. Mike Colemire
    Mike Colemire
    Those wheels look dang good with the chevy caps.
  16. NashRodMan
    NashRodMan
    Those wheels are awesome. I like both type of caps!
  17. Mikel50
    Mikel50
    Quick modification to my Woodward Fab Bead roller this am.
    Purchased a 20” Boat Stainless Steel steering wheel off Facebook Marketplace early this week for $20
    The supplied crank is 10” and create a 20” throw. So I figured the 20” wheel would be just right.
    Took some time to modify it, about 30 minutes of work will make a world of difference in my bead rolling game
    Added a 3/8” spacer made from DOM tubing behind the wheel
    Took a 1/8” spacer welded a flat washer to it.
    Drilled and tapped the lower shaft to accept the bolt.
    The outside spacer / collar and the inside spacer pinch the wheel onto the shaft.
    Also added a set bolt to hold the wheel from spinning on the shaft.
    Enjoy the day fellas !
  18. Mikel50
    Mikel50
    Few people have messaged me about my super cool handy magnets
    https://www.amazon.com/dp/B01LVW8945?ref=ppx_pop_mob_ap_share
    This is the link to them. They’re fairly strong.
    Not as strong as other rare earth magnets. But plenty for heavy paper like I use.
    Have a great day
  19. sloppy jalopies
    sloppy jalopies
    ahoi matie !
  20. Mikel50
    Mikel50
    Captain Mike at the Helm of this sinking ship
    loudbang and mike bowling like this.
  21. mike bowling
    mike bowling
  22. Mike Colemire
    Mike Colemire
    Those magnets are nice, it's hard to find any that are strong enough to hold anything. Good job on the fuel neck, I got the stuff to do mine today.
  23. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Kinda the same thing I did. Great minds think alike...
  24. Mikel50
    Mikel50
    Started picking away at the bulkhead yesterday afternoon
    Put my Girlfriend and bead roller to work rolling some strength and detail in the panels.
    This is where I stopped for the night last night.
    LSJUNIPER, patmanta, brEad and 3 others like this.
  25. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Impressive workmanship. I'm thinking you should hang up the paint brush and open you're own shop. You have come a long way Grasshopper...
    mike bowling, Mikel50 and loudbang like this.
  26. sloppy jalopies
    sloppy jalopies
    When you said you were way ahead of me, you were not kidding... spiff !
  27. shadetreerodder
    shadetreerodder
  28. You don’t do anything by halves, do you. Your bulkhead looks great!
  29. Mikel50
    Mikel50
    I always try to do better than yesterday.
    Thank you
    brEad, 48fordnut and loudbang like this.
  30. NashRodMan
    NashRodMan
    Holy crap! That looks amazing!!
    Mikel50 likes this.
