Art & Inspiration Tri-power Air Cleaner/Filter Ideas
Discussion in 'The Hokey Ass Message Board' started by anothercarguy, Mar 2, 2019.
  1. Hi all...looking for ideas and inspiration for topping off the tri-power for my current project.
    Let's see what you've got or what you've seen.
  2. jimmy six
    jimmy six
    Stock form something, I think the 348, 58 to 61 Chevs are the best.
    anothercarguy likes this.
  3. manyolcars
    manyolcars
    I made a top and bottom plate and use an oval 3 deuce filter. The plenum is important
  4. Thanks, any pictures?...curious as to what about the plenum is important? Looks? Functionality? Air volume within plenum? Something else?
  5. The more of the filter exposed to the air the more it will flow.
    The re-pop Pontiac-Tri power ones have an open style filter.
  6. Grace and Co. Parts makes some real nice looking ones.
    Nailhead Jason and anothercarguy like this.
  7. This was my ole 55 348, they probably weren't that good for all out performance but they looked good. IMG_0697.JPG
  8. I post this in jest.......
    There's a joker selling this on fleabay. :p
    It looks like it's for a 4-barrel so you would have to fab a bottom plate.
    anothercarguy, egads and Deuces like this.
  9. Maybe that's one of those "cow inductions" that I keep hearing about...
    Texas Webb and catdad49 like this.
  10. nochop
    nochop
    from norcal
    No! That’s as bad as “ Rocket” valve covers for sbc’s
    anothercarguy and Deuces like this.
  11. X-cpe
    X-cpe
    I've got the three little louvered pots on mine.
  12. hrm2k
    hrm2k
  13. DDDenny
    Right up there with those lameass phony stack fuel injection carb covers!:eek:
    nochop and anothercarguy like this.
  14. Blake 27
    Blake 27
  15. garage2small
    garage2small
    Saw these today, don't know how they perform but they got killer looks! 20190302_154039 (3).jpg 20190302_110352 (2).jpg
  16. Jalopy Joker
    Jalopy Joker
  17. Currently running these old spark arrestors on 327 in the 55 Chevy
  18. IMG_1293.JPG something different we did
    4speed411, XXL__, '51 Norm and 5 others like this.
  19. Just plain ole' small filters on mine. Just like a million others....
  20. Blue One
    Blue One
    from Alberta
    As pretty as those are, there are no actual air filter elements available to fit them. :confused:
    All you can run is the screen that you see them fitted with.
    I was told this by the makers Grace and Co.
  21. FORDY 6
    FORDY 6
    I used a WIX filter #42719...had to "dress" both sides of the filter and change the threaded strap on the bottom. Don't know what other similar brands of filter would fit. 20190304_080547.jpg
    XXL__ and anothercarguy like this.
  22. FORDY 6
    FORDY 6
    Forgot to include the air filter element 20190304_084302.jpg number info was for the Grace & Co air filters
    anothercarguy and Blue One like this.
  23. Blue One
    Blue One
    from Alberta
    What exactly is the change to the threaded strap ? And what does the "dressed" filter look like on its own after
    "dressing" ?
    Probably works OK, but I found it odd that they made these units without considering an actual filter that fits.
  24. FORDY 6
    FORDY 6
    Had to change to a flat strap, drilled & tapped for a 1/4" X 20 bolt...the element was to thick, sanded the top & bottom of the filter elements to get the lid to fit properly. Mine were plain Grace & Co units...I painted them after "massaging" the elements and riveting the new straps. Yeah, they probably should have sized the air filter unit to an available element, but they do look good.
  25. Blue One
    Blue One
    from Alberta
    Can you tell me the finished diameter and thickness of your filter element ("dressed" down ) so that I can do a little searching on my own ? I have some unconventional sources for filters that I can check out.
  26. FORDY 6
    FORDY 6
    Looks like 1.549 inches thick after sanding the top / bottom only. Didn't do anything to the sides 20190304_134311.jpg ...3.91 inches.
  27. Blue One
    Blue One
    from Alberta
    Thanks for the info.
  28. Speed~On
    Speed~On
    Here's 2 Boettger air cleaners I recently bought. I really like the look.
    Shadow Creek and cactus1 like this.
  29. Jokester
    Jokester
    I made a top and bottom plate out of flat steel. Then used an oval filter. I think Datsun, maybe 240Z. It's been a long time so my memory is a little fuzzy. Sorry, no pics.
    .bjb
  30. There weren't a lot of choices back in the 80's when I built my Roadster, so I used these small stainless mixing bowls, buffed out to a shine. Used the standard carb mount and K&N filter. Not trad anymore.
