Hot Rods 56 Bird suspension
Discussion in 'The Hokey Ass Message Board' started by MeanGene427, Feb 19, 2019.
  1. MeanGene427
    MeanGene427
    from Napa
    Is the front suspension of a 56 T-bird the same as a 56 passenger car or wagon? Have one with a decent straight axle but might switch it back, can't remember if the a-arms & such are Bird-specific, or same as full-size Ford- thanks
    dirty old man and chryslerfan55 like this.
  2. Other than the springs, it's the same as the other cars.
    dana barlow and dirty old man like this.
  3. fordrodsteven
    fordrodsteven
    If you're running a "Y" block the original springs are good. If you go to a later SBF it weigs less than the "Y" block and the front end will rise up. If you want the stance back down (with the SBF) you might want to put in springs from an Aerostar.
  4. MeanGene427
    MeanGene427
    from Napa
    427FE of course, had one in it with a toploader that was just pulled out
  5. jimmy six
    jimmy six
    Same as the big car. Very strong and many ways to lower even using stock length springs. Aerostars are compound wound and can give you a fun ride in a dip in a street or highway. The front frame cross member is very important and needs to be rust free.
  6. Elcohaulic
    Elcohaulic
    I always thought the T-Bird had long control arms for such a small car and that's a good thing.
