Technical AV8 Radiator to fan distance
Discussion in 'The Hokey Ass Message Board' started by Chappy444, Feb 18, 2019.
  1. Morning All.
    I am looking at putting a full hood on my 30 AV8 and it taking some measurements I have found that the top of the radiator is laid back a little over an inch to far to allow the hood to be fitted. In the current configuration the fan is about 1 inch from the rad.
    If it move the top of the rad forward I will have a bit over two inches between the fan and rad.
    My question is, how much will this harm cooling (especially if there is a full hood fitted)?
    Thanks for the info.
    Chappy
  2. flatford39
    flatford39
    1" is the gold standard I believe. At lease that's where I put mine after a lot of research on it.
  3. harpo1313
    harpo1313
    from wareham,ma
    A shroud would help , but two inches should be fine.
  4. Blues4U
    Blues4U
    from So Cal
    Can you post pics please?
  5. G-son
    G-son
    from Sweden
    Add a descent shroud and it'll cool better than ever even if the fan is two yards behind the radiator.
  6. dwollam
    dwollam
    Try it before investing in a shroud. Aluminum radiator? Should cool well. Any cooling issues now?
    Dave
  7. Yes. Aluminum radiator. No cooling issues now aside from hot days in heavy traffic...gets into the 200* area.
    Just cant figure why it was assembled this way. The tabs at the bottom of the rad sit flush on the crossmember now. If I move the top forward would I need to wedge the trailing edge of the mount tab? It will be raised up off the crossmember a bit.
    Thanks again
    Chappy
  8. Model A Gomez
    Model A Gomez
    I'm building a 30 with an 8BA and a 32 grill shell with the stock hood and have about 1 1/2" fan clearance, I had a 28 with a flathead and had a couple of inches clearance and it never cooled quite right.
