Hot Rods Radiator fixes?
Discussion in 'The Hokey Ass Message Board' started by WB69, Feb 16, 2019.
  1. WB69
    WB69
    from Kansas
    Had a retired mechanic tell me that he used to fix small or slow radiator leaks by putting mustard in them when hot and run it. I've heard of pepper and a few other things but never mustard. Anyone else hear of this and does it work?
  2. 41hemi
    41hemi
    An egg or 2 also works. Bars Leak works for small leaks.
    lothiandon1940 likes this.
  3. alanp561
    alanp561
    Cigarette tobacco
  4. 302GMC
    302GMC
    from Idaho
    Coffee grounds ...
  5. 81DC407C-6F79-4203-98BB-DB49505D2F4E.jpeg EF457029-009D-455D-A9B4-2B36D0F09389.jpeg EA050C7F-4529-48D9-99CA-88A7903DE61A.jpeg
    Are we fixing cars or making sandwiches?!?
    WB69 and Truck64 like this.
  6. Temporary fixes, none are long term. HRP
    jazz1 and VANDENPLAS like this.
  7. Jalopy Joker
    Jalopy Joker
    take radiator to repair shop or buy a new one
  8. WB69
    WB69
    from Kansas
    This is what I do myself, just was wondering about the mustard. It was the first time that I had heard of it.
  9. Seen it once at a shop I worked at an old Chevy van came in overheating.
    Open the rad cap and this white goo cake out.
    On closer inspection it was rice!!
    Someone sabotaged this guys van by dumping a bag of uncle Ben in his rad!!
    The rice cooked and expanded and filled everything!!
    Rad out , heater core all hoses and popped every freeze plug we could access to flush out the block.
    What a bloody mess and an easy way to write off a car.
    Only saw it once. Don’t know who the owner pissed off but it was a good/bad way at revenge !
    Truck64 likes this.
  10. Truck64
    Truck64
    from Ioway
    How do you know it was Uncle Ben's, hm? Could have been Rice-a-Roni.
    VANDENPLAS likes this.
  11. Gman0046
    Gman0046
    My Grandpa said back in the day They used Horse Shit for a radiator stop leak.
  12. My 36 had one leak up close to the top the prev owner stuck a foam earplug in it and ran it for months like that...YMMV
    Said earplug below:
  13. Truck64
    Truck64
    from Ioway
    Earplugs?? Hadn't heard that.
  14. G-son
    G-son
    from Sweden
    Well, they ARE meant to plug holes. :p
    I've soldered a number of leaking old brass radiators/heaters for friends, not the easiest thing to do but if you can get the metal clean and heat just the right spot it works pretty nice.
    Black_Sheep likes this.
  15. sawbuck
    sawbuck
    from 06492 ct
    gotta be dry mustard .not the squeeze stuff o_O
  16. BJR
    BJR
    Mustard only works if you stuff the radiator full of hot dogs first.
  17. Gman0046
    Gman0046
    Fix it right or not at all.
    56don likes this.
  18. Don't understand why anyone would risk using these old wives tales remedies today when they could use a product that is researched and designed to fix the problem, if only for long enough to get it fixed properly.
