Customs Repowering a 47 Frazer
Discussion in 'The Hokey Ass Message Board' started by junkman73, Dec 20, 2018.
  1. junkman73
    junkman73
    Picked up a 700r4 today .I hope I have the rite flex plate laying around to put this trans to the 250.Managed to get it for $125.oo.
    gimpyshotrods likes this.
  2. junkman73
    junkman73
    Looks like I might have to buy a new flex plate.After looking at what I have laying around I don't think I have the right one.Oh well they are only twenty bucks at the auto parts.
  3. s55mercury66
    s55mercury66
    from SW Wyoming
    That should make a nice combo. Check the distributor for wear, they like to wear at the upper end, and can make setting points a challenge. I may have missed it, but what is the rear axle ratio?
    Dixon Bastie likes this.
  4. junkman73
    junkman73
    I'm not sure about the axle ratio but I think it is around a 3.73 or4.10.I plan on dropping in an HEI distributor.I have one on the shelf so I might as well use it.
  5. junkman73
    junkman73
    IMG_0483.JPG Went to my local Napa today and picked up the flex plate to put the 700r4 behind the mighty 250 I6.
  6. Rusty O'Toole
    Rusty O'Toole
    Original rear axle gear was pretty low by today's standards but should be just about perfect with an overdrive transmission. And the six won't have enough HP to overpower it so, no reason to change it.
  7. junkman73
    junkman73
    Just waiting for the weather to brake so I can get to work on it.
    'Mo likes this.
  8. 'Mo
    'Mo
  9. Rickybop
    Rickybop
    Alone bad. Friend good.
    Nice to see you making progress, junkman.
    junkman73 likes this.
  10. junkman73
    junkman73
    Thanks guys ,I have been collecting the parts that I am going to need and pretty much have them.Now I just need to push everything into one big pile and bolt it all together.
  11. David Chandler
    David Chandler
    Good looking car too! You won't meet another one every time you drive it. A 250 is a good engine. I've had several, and I have parts to make one more, plus a spare block and crankshaft. I'm hanging onto it.
    Good luck!
  12. junkman73
    junkman73
    Today was the day all the parts gathered in one place.Now I just have to let them do their thing and hopefully I end up with a running driving car soon.
    Oldioron likes this.
  13. oldiron 440
    oldiron 440
    I like your powertrain choice and should work for you for some time. I'm anxious for the build to begin, I hope to see pictures of the installation.
  14. junkman73
    junkman73
    Heck I'm still trying to get the SBC and Th400 out that the last owner was trying to rig into it. I have done some odd things over the years but this guy takes the cake.Rewiring with Romex and extension cords.
  15. junkman73
    junkman73
  16. junkman73
    junkman73
    IMG_0539.JPG The 67 Chevy 250 engine and the 92 700r4 are joined together in a union of greasy matrimony.
    40LUV, Torkwrench, Squablow and 3 others like this.
  17. junkman73
    junkman73
    I think that I might be setting the engine a little further back the what it did originally.The previous owner had cut out a big piece of the floor and firewall so cutting just a little more is not going to brake my heart.
  18. Rusty O'Toole
    Rusty O'Toole
    You might get a few laughs out of this, a guy buys an old Frazer and puts it back in commission as his daily driver.
  19. junkman73
    junkman73
    It's been a minute since I last updated you guys.The motor and trans is hanging in the engine bay.Now I need a driveshaft to help set some drive line angles before I start making mounts.
  20. junkman73
    junkman73
    Stopped off at one of the local pick a part places today and found my driveshaft.It's a split shaft from a 2004 Dakota extended cab.
  21. junkman73
    junkman73
    Went to Joint Clutch and Gear today and ordered the correct flange for the drive shaft to bolt to the rear axle.That should be in on Wednesday or Thursday.
  22. plym_46
    plym_46
    from central NY
    When you get it together you are are going to want to see somebody who is good with the 700r4. They are very sensitive to throttle cable position, the later ones are better then the eaely 80's ones but they are still prone to eating themselves up pretty fast is not correctly set. They are also fussy about operating temp so an good sized aux cooler in a necessity. I have one on a Studebaker pickup behind a 195 HP Studie 259. The rear end in it is a three fifty something ford 9 in. With 235 75 15 radials it's running about 22/2300 at 65. The only complaint I have is mine came out of a late Caprice taxi and first gear is done at 20 mph. Ok for fully loaded operation but with a light empty vehicle there could have been a better ratio. If I recall, fourth is .78 OD.
    There is also an inside the sump wiring adaption that will make the lock up operate independently of the aftermarket wiring harness. Lots of info on the r4 on the web. Check out a few so you are familiar with their quirks. I had a guy who works in a UPS garage go through mine an did the mods refreshed the seals gaskets and such. Then had the throttle pressure cable set but a guy familiar with it's care and feeding. Good luck? Now whaddya gonna do with the
    /6??
    Shadow Creek likes this.
  23. junkman73
    junkman73
    I have done an exhaustive amount of reading on the 700r4.I don't quite understand the question about the 6.If you are asking if I'm going to modify it.I am not.
  24. junkman73
    junkman73
    Dropped off the drive shaft to get shortened today.Taking 19.5 inches out of it.
  25. junkman73
    junkman73
    I get to pick up my drive shaft tomorrow afternoon on my way to work.
    Stogy likes this.
  26. junkman73
    junkman73
    Got my rebuilt/shortened drive shaft today on my way to work.Between cutting/welding/rebalancing/replacing two joints/and the center bearing total came to almost $300.oo Ouch!!!!
  27. s55mercury66
    s55mercury66
    from SW Wyoming
    The price of progress. It sounds like things are moving along for you though. I may have missed it earlier, but what is your shifter setup going to be?
