Technical Vega steering box.
Discussion in 'Traditional Hot Rods' started by 38nailhead, Dec 24, 2018.
  1. 38nailhead
    38nailhead
    from England
    Hi everyone.
    In my truck their is a vega steering box , the guy that I purchased it from said that’s in no good / worn out . Can you rebuild them ? Or is it just easier to buy a new one ?
    Cheers Benedict
  2. MrMike
    MrMike
    I do not believe they can be rebuilt, try Borgeson Universal Company for a steering box or more information, they bought out Mullins steering gear a few years ago .
    dylan60, figure8, 3340 and 1 other person like this.
  3. iafraser39
    iafraser39
    from Warmland
    Go with the Unisteer rack, its way superior to the vegas cross steer. the kit
    bolts in where the vegas box was mounted. No more steering problems.
    zzford likes this.
  4. 38nailhead
    38nailhead
    from England
    Great , thanks for both replies , I will look up the unisteer rack
    zzford likes this.
  5. alchemy
    alchemy
    I am no fan of the Unisteer racks. Ugly as hell, and not traditional in any fashion.
  6. 38nailhead
    38nailhead
    from England
    Yeah I was just looking at them :/ And I see what you mean , I like the look and as you say the tradion of the vega box, I will stick with what I have and what I’m know.
    3340 likes this.
  7. alchemy
    alchemy
    I'm not saying a Vega box is traditional, but at least they look like a steering box, not the arms off a robot.
    clem, verde742, GuyW and 3 others like this.
  8. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    F 1 may be traditional....
  9. butch27
    butch27
  10. Bandit Billy
    Bandit Billy
    Follow MrMike's lead on this one. Borgeson.
    figure8 and 38nailhead like this.
  11. 41rodderz
    41rodderz
    from Oregon
    I don't believe you can beat a F 1 box for it's simplicity and size. I have a complete one from box to steering wheel and it turns smooth as butter.
  12. MMM1693
    MMM1693
    I'm with alchemy on the Unisteer plus it's been said you lose turning radius. If you stay with the Vega style box you won't have to redo a bunch of other crap. I have a Chinatown Vega box on my coupe and have not had any problems for two years. Maybe I just got lucky. When it does come time to replace it I will use a Borgeson.
    38nailhead likes this.
  13. 38nailhead
    38nailhead
    from England
    Thanks for all the opinions, I have been reading through the technical info on Borgesons website and it’s helped me out and I have started to learn a lot more.
    bct likes this.
  14. speedshifter
    speedshifter
    Very difficult to eliminate excessive bump steer using any rack & pinion with a solid front axle. Greg
  15. 38nailhead
    38nailhead
    from England
    This is what I have in my truck , and that is what I will stay with.... traditional and nothing more
  16. krgdowdall
    krgdowdall
    from Alberta
    That's not a Vega Box
    verde742 and X38 like this.
  17. 38nailhead
    38nailhead
    from England
    Guy who sold me it told me it was , just went through my pics he sent me and found it. Does anyone know what it is then please ?
  18. Ron Emerson
    Ron Emerson
    That's a GM power steering box. Don't no what year though.
  19. 38nailhead
    38nailhead
    from England
    And I have learnt something new , I was just going by what I was told. Cheers for that...
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Since you have a GM power box replace with 525 manual box. Pitman may need changing depending year of 525 box purchased.
  21. 38nailhead
    38nailhead
    from England
    Well as soon as it’s here I will have a proper look to know and learn what everything is and go from their, I know how I want it and what I want , so I will stick to that plan. And if it’s no good to me I will sell it on for what I want.
  22. Johnny Gee
    Johnny Gee
    from Downey, Ca
    525 looks like this. Many mistake it for a Vega.
  23. BamaMav
    BamaMav
    from Berry, AL
    That power box looks to have the lines plugged? That would be a muther to turn, worse than a bad manual box.
  24. mgtstumpy
    mgtstumpy
    Given the size and weight of your panel truck I wouldn't even consider using a Vega sized box as it's suited to smaller and lighter cars less than 2,500lbs. A 525 is better suited given it's more robust and heavy, that looks to be a heavier Delphi 600 PS box
  25. Weedburner 40
    Weedburner 40
    That is a 800 series Saginaw power box. Nothing wrong with them. I have had one in my forty for over 30 years. Get a gm teardrop pump and hook it up. The larger of the two fittings id the pressure side.
    GuyW likes this.
  26. Pete Eastwood
    Pete Eastwood
    from california
    Could be from a Vega with power steering. They used the larger power box like that.
  27. GM used that same power box on many vehicles for a lot of years. It looks like the same one that was on a '70 Pontiac Lemans that my father used to have. That 525 non-power box was likewise used on many applications for years. It looks like the one on my truck that came from a '64 Chevelle.
  28. zzford
    zzford
    I have used a Unisteer and loved it. I found no problems with bump steer or reduced turning radius.
  29. iafraser39
    iafraser39
    from Warmland
    the reduced turning radius is usually caused by the ram hitting the hairpins on the driver's side.
    you have to make sure that there is clearance. It us usually only on a right hand turn.
  30. MIKE STEWART
    MIKE STEWART
    I have used manual Vega (Flaming River USA 1/3 stronger) and mid 1960's manual 525 Saginaw. When I installed block headers on my 351W - went with Flaming River Vega for needed clearance. 3 years - no problems works great. The 525 did great for 25 years - needed the room for headers. In a Chevy engine - the 525 should fit. Had pro builders tell me to avoid the 1/2 rack product. If you try it - watch out for split wish bones - per rack maker tech line - need unsplit wish bones. Mine were split for the C-4. For a passenger car - and the beefed up USA made Vega box - will be fine - but cheap China copy Vega / buyer be ware.....
    deathrowdave likes this.
