Projects What can I use to fill these griding marks
Discussion in 'The Hokey Ass Message Board' started by junkyardjeff, Dec 15, 2018.
  1. junkyardjeff
    junkyardjeff
    Bought this glovebox door off ebay and was covered with contact paper and it looks like someone took a grinder with 36 grit to it,so what can I use to fill them.
  2. DDDenny
    220 grit paper and elbow grease.
    firstinsteele and flatford39 like this.
  3. F&J
    F&J
    High build primer is what i'd do.
    seb fontana, Rich S., dan31 and 3 others like this.
  4. TagMan
    TagMan
    ^^^^^^ I agree - hi-build primer & sand it down.
    If they're too bad, a skim coat of Rage Gold or similar fiberglass, then sand it down.
    dan31 likes this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If you want it in a spray can this stuff works great. It's lacquer.
  6. john worden
    john worden
    from iowa
    80 grit on a DA followed with 180 and see if/what scratches remain.
    If minor scratches remain repeat sanding and or apply 2 coats epoxy primer and block sand.
    Prime with 2 part primer before color.
    Use only primers with hardeners to avoid for the most part sand scratch swelling.
    Basically treat it as if it were an exterior panel.
    mikhett, tb33anda3rd, joee and 2 others like this.
  7. Kiwi 4d
    Kiwi 4d
    Why would you render a glove box useless by installing gauges.
    But the above advice is sound.
  8. junkyardjeff
    junkyardjeff
    I think I will try this since I would like to work on it in the basement or just cover it with rattle can primer and work on it when it warms up.
    john worden likes this.
  9. junkyardjeff
    junkyardjeff
    Its made for a clock and ash tray and hard to find.
    RICH B and WanatahHustler like this.
  10. oldsman41
    oldsman41
    skim coat it with filler and sand with 2000 grit. Just enough to fill it in not an inch deep. Then shoot it with high build primer scuff with 4000grit and shoot it wth your favorite color.
  11. As John said lacquer primer is a waste of time and money it will shrink and won't fill 36 grit scratches.
    ABONES, Pist-n-Broke, mikhett and 2 others like this.
  12. There is not a high build primer made that advises spraying ever 2000 grit sand scratches.
  13. Kiwi 4d
    Kiwi 4d
    “Its made for a clock and an ashtray hard to find”
    Duh , I saw the neat little cut outs but made an ass of my self by “assuming”
    So it sure is worth some effort to get it done right.
  14. junkyardjeff
    junkyardjeff
    This is what its supposed to look like
    belair likes this.
  15. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Back in the mid 70’s cars would come in the shop with major hail dent damage. We would run a 9 inch grinder with 36 inch course disc over the roof panel /deck lid/hood to remove the dents. The 36 inch disc would heat the low spot and raise the dents out! Not to be an ass- the old cars could take a 36 grit pounding and be rectified by lacquer primer / paint ! Lived It.
  16. fordpatina
    fordpatina
    This is your remedy
  17. Hollywood-East
    Hollywood-East
    KIMG3792.JPG KIMG3791.JPG $.02 More... I use 2K catalyzed primer, but here/there like to cover bare metal spot's, this stuff is at your Napa, about $8.00 decent build, an dries pretty quick if around 70°, Had real good luck with it, But definitely as mentioned hit that Baby with 80, an work your way down to 150, Use a etching primer first , SEM is a Good automotive grade, be mint...
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If you don't let it gas out and your in a hurry sure it will do that. If it were a huge piece I wouldn't have suggested it. Like any product. Know how it behaves and work accordingly and there will be no problems.
    blowby and F&J like this.
  19. F&J
    F&J
    Some of you are totally full of shit about high build primer (thickness). I see countless threads on here & web of "pros" with coat after coat after coat of high build and blocking in between...and then you are saying 36 grit scratches need proper filler?
    ..and don't BS that you don't..
    Lmao..give me a break..
  20. Tell em Frank
    Ben
  21. Blue One
    Blue One
    from Alberta
    Wow I’m really surprised that your arms were long enough to run that 36 inch disc, and I’m wondering how you got the 9” grinder to handle it :D
    TagMan likes this.
  22. blowby
    blowby
    from Nicasio Ca
    This is why we're not going for a walk?
  23. Onemansjunk
    Onemansjunk
    from Modesto,CA
    36 grit disc——-need to proofread
    Blue One likes this.
  24. Mr48chev
    I'd have to agree that a lick or two with 80, a bit of 150 and maybe some 220 and then start laying primer and blocking.
    I think the main issue is that too many of us have tried to do something like that too fast by laying on several coats without taking the time to let it set up properly or sanding between coats.
  25. Budget36
    Budget36
    I'd just DA it with 180, prime and paint.
    Of course I'm lazy.
  26. junkyardjeff
    junkyardjeff
    Just got my new to me air compressor up and running and will start working on it during the week,I am probably low on paper and if so it will not be until after friday before I can get to it. I know I do have some 220 grit but might be too fine but will look when I get home from work tomorrow and I hope I have something to work with.
  27. SimonSez
    SimonSez
    Another option is to mix a small batch of epoxy primer and use a small disposable foam roller to apply it.
  28. blowby
    blowby
    from Nicasio Ca
    I'd skim it with Rage* filler, especially if it has waves or a ding. The stuff spreads like butter, sands even easier, it's stable and ready to go in a few minutes. Then you don't have to pile on paint.
    *Wonder if some poor guy was there with a sanding block and a sore arm when they were developing this stuff.
    "Hey George, how was that one?"
    "Huh, huh, huh, not bad, huh huh."
    "Hmm, well this time let's try adding more of A and leave out C, and mud the quarter again. Take 10 George."
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    "I'll do it in 5"
    blowby likes this.
