I have 2 40 ford pedal assembly -A is an early one- it has tabs welded on the bottom of it as it came out of a car that had an olds in it with a lassalle tranny. they will cut off easily B IS SOLD AND GONE- C is an early assembly. note the difference in the clutch pedal on the part that is on the back part of the firewall- im told the early cars had the stamped looking casting and the later ones didn't?? these are both 40 ford assemblys as I took em out of the cars 75.00 each your choice View attachment 4078699
