Hot Rods "THE WALL OF SHAME"
Discussion in 'The Hokey Ass Message Board' started by duncan, Oct 8, 2018.
  1. gatz
    gatz
    Not car related, but definitely "LACK of MAINTENANCE"
    I could not believe what I found when on my nephews' Toro GroundsMaster when checking out why the Mitsubishi diesel engine was hard-starting.
    This wasn't their doing.....They bought the unit "used", and they did go see it and drive it.
    Seemed to run OK at the time; early fall.
    But there were some problems starting it when the weather got a little colder.
    This is/was the dry air cleaner assembly ..... Toro 223D aircleaner assy_1.JPG
    A little rust...a few holes? No prob, stuff in some paper shop towels...
    There's actually a 60w trouble light inside here...
    Ran a compression check. Not good. Poor little Mitsubishi....could barely breathe !
    And if it did, it inhaled all kinds of grit, rust, fibers, etc.
    The engine had to be replaced as it would only start when it was warm out, or with ether.
    Not ideal for snow-blowing.
    New filter assembly,
    The existing air intake was just behind and slightly above the left drive wheel.
    Excellent location for sucking up water, dirt, and debris.
    Built this assembly to get the air intake ABOVE "water-line"...
    Engine replaced, and all work done. But a few months later they sold it.
    mgtstumpy and classiccarjack like this.
  2. Ok , ok, ok ok ok....... I am not smart enough to figure it out on my own.
    What in the fuck is the trailer hitch doing on that front end ?!?!
    I am speechless at everything I have seen there is just so much wrong with everything on this .... um.... car?!?
    jimmy bruns, lewk, Bearcat_V8 and 9 others like this.
  3. gatz
    gatz
    quick-change front end ?
    The headlight aiming looks like it would be easy from the cockpit tho'
    Nicholas Coe, AldeanFan and 62rebel like this.
  4. Joe H
    Joe H
    Trailer ball appears to being used as a ball joint attaching the front axle to the frame with short leaf springs under them. Wonder what the rod and pivot does running up towards the front? On top of all that, it has coil-over shocks along with the cut down leaf springs!
  5. Looks like a school experiment on how to design a suspension using no conventional or logical engineering.
    classiccarjack and vetteguy402 like this.
  6. 62rebel
    62rebel
    Are those Ford "twin-I beam axles"? WTF..... I feel like I'm watching "Junkyard Wars"
  7. BJR
    BJR
    That is without a doubt the rattiest rat rod I have ever seen!!!:(
    Nicholas Coe likes this.
  8. Boneyard51
    Boneyard51
  9. How about this redneck brake switch.
  10. upspirate
    upspirate
    At least they have new radials for safety
    VANDENPLAS and 62rebel like this.
  11. turdmagnet
    turdmagnet
    I didn't even notice the trailer hitch - saw the rad on the side and thought what the hell
  12. flatheadpete
    flatheadpete
    from Burton, MI
    Can't believe this but I'd like to see more of this thing. Bet it's a grin!
    lewk, VANDENPLAS and alanp561 like this.
  13. They are using the trailer coupler as a suspension pivot....
  14. scotts52
    scotts52
    Definitely Ford twin I beam.
  15. GraeffSS
    GraeffSS
    Looks like it's a Twin Traction Beam, 4x4 version of the Twin-I Beam.
    Either that thing has 4wd or there is a diff just hanging on the axle as dead weight
  16. I wish I could say the same for my nose. :D
  17. Side pipe?
    mgtstumpy, petersen43 and blowby like this.
  18. vetteguy402
    vetteguy402
    from omaha, ne
  19. Hollywood-East
    Hollywood-East
    10974.jpeg I'll raise you on the exhaust...
    mgtstumpy, petersen43, brad2v and 7 others like this.
  20. IT's ALIVE:eek:
    61Cruiser, Bleach and 56don like this.
  21. RMONTY
    RMONTY
    So this thread will be closed soon with the OT pics of RRs being posted. I would rather see real Wall of Shame pics of repairs and "what were they thinking"...and not pics of what that RR crowd likes. I'll just unsubscribe. :rolleyes:
    56don, akoutlaw, FlyFisher and 3 others like this.
  22. upspirate
    upspirate
    I always loved this idea....never thought of buying an exhaust system at Home Depot. Need to make sure you use the aluminum and not the vinyl though!!!:rolleyes::D
    chryslerfan55 and Hollywood-East like this.
  23. Hollywood-East
    Hollywood-East
  24. Hollywood-East
    Hollywood-East
    I completely agree with You, but this shit is Really silly funny... Hence I posted The rain gutter exhaust that was seen here in western NY... But You can't say You haven't almost spit your Choose your favorite beverage at the screen your using...
    chryslerfan55 and RMONTY like this.
  25. It spawned this guy.
  26. Hollywood-East
    Hollywood-East
    I believe that's a thread on here about coker inner tubes...
    chryslerfan55 and Bleach like this.
  27. Since I was a 16 year old idiot, I'll confess to this stuff we did in the '50's. My friend had a '49 Lincoln, I had a '50 Olds. Both had heavy rocker panel rot. We taped over all the exposed rust holes, then made some big holes in the top of the rocker panel. Mixed up some thin plaster of paris and poured it in the rockers. When it set up, we pulled the tape, did a little finish sanding and sprayed primer over it with a bug sprayer. Looked perfectly good from a few feet.
