Projects garagefind/ survivor 40 coupe build. FIRED IT UP!
Discussion in 'Traditional Hot Rods' started by joel, Sep 26, 2014.
  1. joel
    joel
    Thanks, it has been a long road.
  2. joel
    joel
    The pass. door is on and fits good. I had 1/8 " holes through the hinge to hold alignment; it worked great. IMG_1060 (600x800).jpg IMG_1063.JPG
    Progress!
  3. joel
    joel
    I have the body cut up to 2000 and was buffing the drivers door when the Makita died. I tried to get it apart but failed. I am pretty sure it’s the switch or maybe a loose wire. So I bought a new one from Home Depot. They had the best price and 2 days shipping.
    The plan was / is to get the painted stuff on the car so that I can paint the rear fenders. IMG_1064.JPG
    Here is how it looks now.
  4. joel
    joel
    After the buffer failure the other day, I installed the tank vent hose. A non-paint related project was needed. There is the same setup on the truck ( done by PO ) mounted with a zip tie.
    farmer12 and loudbang like this.
  5. joel
    joel
    With my brand new buffer, I finished the drivers door and my son helped install it. I buffed the deck lid today. IMG_1068.JPG IMG_1067.JPG
    40LUV, Tim, Runnin shine and 7 others like this.
  6. farmer12
    farmer12
    Just read through the whole build thread. Impressive work! Keep it up!
  7. loudbang
    Nothing looks as good as nice SHINY black paint :)
    i.rant and farmer12 like this.
  8. olscrounger
    olscrounger
    very nice!!
  9. Shiny paint.....I can't even imagine! Your car is gorgeous. Can't wait to see it all buffed out and assembled.
  10. The 39 guy
    The 39 guy
    Paint is looking great Joel! Tell me more about that vent please.
  11. joel
    joel
    I got the the piece on the end of the hose from Summit and it's a vent/rollover valve. Since the tank is from Tanks, it has it's own rollover valve that also acts as a vent, which allows you to run a non vented cap. The only " tricky" thing is the vent hose needs to stay level or above the fitting on the tank. If there is a low spot, you might get fuel splashing into the vent hose and forming a liquid "trap".
    I think the above scenario is not likely, but better safe than sorry. It is possible to over fill the tank until fuel rises into the filler pipe.
  12. joel
    joel
    Thanks for your comment
    Thanks for following.:p
    Thanks, it looks like it will be spring before I get to drive it.
    Me too, Rocky, Me too. It will be 53 years in the spring since I drove it. Now I really feel old.:(
  13. The 39 guy
    The 39 guy
    Thanks for the vent info Joel!
  14. 4D-4EVR
    4D-4EVR
    Joel, I'm just starting my build on my 8th 40 Ford. I don't think I can hold a candle to your work.
    I just found your thread this week and enjoy every post, keep it coming.
  15. Runnin shine
    Runnin shine
    Joel, when I was a bodyman/painter 20+ years ago we used Milwaukee buffers. I thought they were awesome. We replaced triggers on them so often I felt it was far too much. I bought a Makita in a pinch for my personal use almost 18 years ago. I’ve been waiting for the trigger to fail. Now I’m sure it will as soon as most inconvenient.
    Thanks, Wyatt
  16. joel
    joel
    I guess it’s confession time. I couldn’t get the old Makita apart,although I was sure it was the cord. Long story short, a friend suggested I look on Utube for repair info. I did; there was; it was a bad cord. BTW I have had the first buffer since the mid 80s. I wouldn’t worry about the switch but they are still available.
    Runnin shine and loudbang like this.
  17. I've repaired the cord on 2 different Makitas I own. Well, shortened them up, to eliminate the break. Have owned them for 30 years+
  18. neilswheels
    neilswheels
    from England
    Wow Joel, its in colour, well, black, looks great, what an achievement, I'm still playing with my headers....
  19. Dick Stevens
    Dick Stevens
    If my memory serves me right, it isn't black......it is dark blue!
  20. joel
    joel
    You’re correct, Dick, although it even looks black to me sometimes.
  21. neilswheels
    neilswheels
    from England
    Sorry Joel, for some reason I thought I read black somewhere, but looking at the pics, its obviously dark blue, and looks great.
  22. joel
    joel
    No problem, I noticed that , after buffing , the “metallic “ is more prominent and the color is more blue.
  23. Great work! Out of curiosity, what are you using for buffing compounds/grits?
  24. okiedokie
    okiedokie
    from Ok
    Just a super build.
  25. joel
    joel
    I use 3M compounds. I also use foam hook and loop pads. There are 3 different pads; one for each of the compounds. The pads are each a different foam( also different colors). IMG_1078.JPG
  26. joel
    joel
    Pix of car about 3/4 buffed with just compound. IMG_1080.JPG IMG_1079.JPG
    Hivolt5.0, loudbang, 40FORDPU and 2 others like this.
  27. The 39 guy
    The 39 guy
    Looks good Joel! We just started the cut and buff on the Merc. It's gonna take us awhile like it has you but it will be worth it when we look at that smooth panels over the coming years.
  28. joel
    joel
    Thanks, Sam. I hope I get it all done soon so I can start putting it back together. An upholstery guy is coming to look at the inside sometime this week, hopefully. The Merc looks good. Do both of you sand and buff or do you split it?
  29. The 39 guy
    The 39 guy
    So far on this car we both sand and he buffs. I have been doing yard work and carpentry projects the last two days leaving him doing both. i need to get some things finished up on my shop expansion before it gets too cold. I have an acre of property here with lots of leafy trees. They keep me busy this time of year.
  30. joel
    joel
    I sympathize; we have a lot of Oak trees here. PITA
