Technical Sealing a thermostat housing.... opinions?
Discussion in 'The Hokey Ass Message Board' started by Al T, Sep 29, 2018.
  1. I had stripped threads in the manifold for the thermostat housing on my ‘37. I’ve installed a couple of helicoils and am ready to reassemble. I could use some advice.
    I was planning on using the gasket in the photo below. The thermostat housing has a small crater in the mounting surface as seen below. Should I use the gasket and RTV, just RTV, or just the gasket?
    Really don’t feel like taking this apart again. lol
    Thanks in advance.
    Allan
    96DED966-E634-4486-AD3F-9C53B210766E.jpeg 938C6D40-3B51-4EFD-899C-6F5A18798CD9.jpeg
  2. bigdog
    bigdog
    Normally I say that if the gasket is installed correctly you don't need sealer. But with imperfect surfaces I would use a THIN layer of rtv on both sides of the gasket. If it squeezes out the sides then you used too much.
    samurai mike likes this.
  3. Thanks.
    Is that enough of an imperfection to warrant RTV?
  4. tombstone
    tombstone
    from sk.canada
    RTV will work .... I’ve had real good luck withSEAL ALL , both sides of gasket , let set up a bit , put together. Don’t run until set up for an hour or two , patience.....
  5. tractorguy
    tractorguy
    Don't over think it.......use the gasket with Permatex Aviation Form-A-Gasket liberally brushed on the thermostat surface and manifold surface. Never did understand the need for using slippery silicone gasket creation material (and hope it cures) along with a perfectly good gasket. Been using Permatex as mentioned with gaskets for almost 60yrs. Seldom has failed me. Can't count the number of jobs I have re-done that someone wanted to be high tech, so they smooshed on lots of cool colored, expensive silicone stuff and prayed to the curing gods for a good repair.
  6. Torana68
    Torana68
    from Australia
    +1 for permatex but also make sure that housing is flat.
    Hnstray and Texas Webb like this.
  7. upspirate
    upspirate
    Hold some wet or dry sandpaper on a flat surface and move the housing over it to true up the surface first
    Petejoe, Hnstray, BJR and 4 others like this.
  8. My only comment is that chrome housings like those made from that 'metal' corrode from the inside out very quickly. It won't be long before pinholes appear in the chrome.
  9. Could not make out the small spot,but as said above sand a little till you have a better surface.
    tractorguy likes this.
  10. squirrel
    if it were my car, I'd buy an aluminum or iron thermostat housing, and put that chrome pot metal one in the trash can, where it belongs.
    But I'd also use Permatex Aviation gasket sealer on both sides of the gasket, with the new housing.
  11. RMONTY
    RMONTY
    I've had good luck using RTV in these situations by costing the gasket with a thin layer, bolting the housing finger tight, go away from it for an hour, then snug it up. Don't over-tighten and as mentioned, don't overthink it. Millions have been done leak free.
  12. noboD
    noboD
    With RTV, the amount that oozes out the outside goes to the inside. And will wind up in the intake, oil pump, oil pump screen, water pump, fuel pump, carb, or any other place you use it. Stick with Perma-tex.
  13. woodiewagon46
    woodiewagon46
    from New York
    Couple of things, as squirrel suggests loose that housing. I have been thru two of them, both developed pin ho;e leaks in the center of the housing. If you do user RTV or some other type of sealant, make sure it is totally dry, and use a heat gun if necessary. Assemble the unit and let it dry over night. It should seal, but use the housing that 36 suggests.
  14. OK...... consensus is lose the chrome housing and go with this one that fortunately was sitting on a shelf.
    So....... gasket, gasket and RTV, or RTV? lol
    215738B1-8AB6-446C-83CE-230D5C674CB6.jpeg 4B858524-2E54-4958-B35A-46745ABBBED2.jpeg
  15. evintho
    evintho
    If it were me I'd true up the mating surface, as suggested, spread a very thin coat of RTV on the mating surface (just enough to hold the gasket in place), install the gasket and bolt it down. Don't overtighten.
  16. squirrel
    RTV has uses on an engine, sealing gaskets is not one of them.
    Hnstray and tractorguy like this.
  17. slowmotion
    slowmotion
    You're on the right track. Now get a piece of 180 sand paper, put it on a level surface (a piece of glass is ideal), and true the mating surface up some. Then getcha some of this:
    Done.
    egads and upspirate like this.
  18. tractorguy
    tractorguy
    Gasket with Permatex Form-A-Gasket brushed on each side.......keep it simple
    Hnstray, squirrel, X38 and 1 other person like this.
  19. kursplat
    kursplat
    RICH B and doug j like this.
  20. chargin03
    chargin03
    Use Summit gasket Sum-G2399 with no sealer.
  21. [​IMG]
    ^^^^ Mine too.... Only caution is don't use it everywhere. Great for thermostat housings, water pumps, oil pans, fuel pumps, OD of press-in seals, other smaller parts. Use it on valve covers and you may bend them if you ever need to remove them. Absolutely don't use this on most intakes for the same reason. The best stuff in the world for painting onto assembled battery terminals to prevent corrosion as long as everything is spotlessly clean.
    If you want a RTV-like sealer, try Yamabond (available from any Yamaha dealer). This stuff 'flows' onto adjoining surfaces so it doesn't leave any 'strings' like RTV does. Seals matching machined/flat surfaces without a gasket. Disadvantage is it isn't 'heavy bodied' so it won't fill large gaps (like intake end seals) but works great where you can use it. Other downside is it definitely has a shelf life...
  22. kursplat
    kursplat
    for intakes, i like this on the end gaskets on small block mopars. this is the only stuff i've used that never lets those PIA things walk
  23. Truck64
    Truck64
    from Ioway
    Right, the gasket IS the seal. Can also use gasket maker in lieu of a gasket.
  24. Blue One
    Blue One
    from Alberta
    Stogy and squirrel like this.
  25. Truck64
    Truck64
    from Ioway
    Gasket maker doesn't need a gasket, which is the point init?
  26. Those chrome housings almost always get warped a tiny bit in the chroming process and will almost always leak. As mentioned by others, do your self a favor and trash it.
    lothianwilly71 and i.rant like this.
  27. I have never got those chrome housings to be leak free unless they have an O-ring.
  28. sunbeam
    sunbeam
    In replaceing a thermostat on a Pontiac Fiero it came with a gasket and it leaked because the factory stamped a number on the machined surface of the head the factory used RTV.
