Projects My first Av8
Discussion in 'Traditional Hot Rods' started by deluxester, Jul 4, 2018.
  1. deluxester
    deluxester
    I bought some Cyclone heads, mostly for the historical tie in to Los Angeles racing equipment manufacturing. The company that made these back in the 40’s is still around!
    I gave them a rough polish before torqing them down.
    F962E512-0221-4E1C-B0E2-BCAC4E556CAD.jpeg 05CAABA2-F9A2-4756-BAB9-7C3A31EE56BF.jpeg
  2. deluxester
    deluxester
    F1FA0D04-6F15-4C6E-B1D6-739EE2A607BA.jpeg 96FB750D-DC00-4781-9817-33B73388B366.jpeg 705255C1-ADEE-489C-9A11-204E4C7206BB.jpeg 5D149FE3-FD57-4481-9922-F90FAE39C976.jpeg I made a master cylinder adapter for a dual res setup to a F1 type (I think) pedal assembly. I later discovered that I could have just purchased one of these adapters alone instead of going through the trouble of making my own.
  3. deluxester
    deluxester
    More recently, I knocked out that forward wishbone bracket. 854560D7-2879-4CDF-BD40-2BE99D9A3050.jpeg 37A4BDF7-73A4-4DCF-8225-FD53A1584ED8.jpeg 931C8E83-9FBD-4C2C-89E2-CC7B9A3D0CBF.jpeg 18CE49FA-B919-4C58-98DB-F8F224BCDC5F.jpeg 3163D7EE-08CD-494B-BBB3-20517B5DE932.jpeg
    1947knuck, rpm56, j-jock and 4 others like this.
  4. deluxester
    deluxester
    Relocated the radius rod(s) mount further back along the shortened torque-tube 4920E0A7-744E-49BD-96E8-EDE7B760D084.jpeg E573EA77-AB96-43EA-B2A1-501521CA5EF5.jpeg 0850E93F-0019-4070-ABA1-F968F0C87150.jpeg C23A4F70-C4F1-4548-904A-C976E0D6CB8C.jpeg
  5. Everything looks great except that pic of the tap in the head stud holes. That's a big no no and they now have a high possibility of leaking. Those threads were cut by Ford to be tight when the studs or bolts are threaded in. Best bet would be to coat them with sealant and run a non pressurized cooling system.
  6. WTF really
    WTF really
    Awesome job so far. I am in the process of collecting parts for my first AV8 build myself. Look forward to watching and learning from your build.
    3340 and deluxester like this.
  7. deluxester
    deluxester
    Good to know, thanks! I had no idea so I just followed the instructions that came in the Speedway box. I did use sealant though.
    Pocket Nick and Stogy like this.
  8. deluxester
    deluxester
    I cleaned up an old F1 steering box that I had kept around over the years. Swapped out the original flange for a model A type that I cut off the original steering. After plenty of measuring and grinding and filing, I was finally satisfied with where the box and column sat along the firewall and headers. Welded and honed. The pieces were actually chamfered pretty deep before those welds were applied.
    I had a friend with a lathe help cut a relief for a seal.
    The box was reassembled with new bearings, shims and a wormscrew from a rebuild kit I bought at the Early Ford Store.
    C3E85814-715A-468D-9364-B9C0CABA7631.jpeg 970C2F41-0424-48A9-93F9-FE331BD0EB82.jpeg 6CB45E9F-9839-4B5E-8DC7-ADA1D284773B.jpeg B85DBE6C-CE3C-49C1-A3F7-D8E0F3B43295.jpeg
  9. deluxester
    deluxester
    Its amazing how much time you can spend modifying something as unimportant as a license plate-tail lamp bracket. 0DAA490A-5038-476D-9BFD-85ED90B7AE27.jpeg 36DEF6FD-95A0-4063-B26B-84286E5C264A.jpeg CBB4236E-554E-4724-BE5B-0A06F30A1A63.jpeg
    1947knuck, Tim, brEad and 2 others like this.
  10. deluxester
    deluxester
    44877422-2A0D-409B-AF19-F2D34DC3652D.jpeg 8A5642F4-55D1-49CF-B3B3-CD9E041BDBBF.jpeg
    Here is a sort of mock up I did recently, using an earlier stock motor I had and a burlap sack for a seat cover.
  11. deluxester
    deluxester
    The steering was actually a lot more difficult for me than simply making clearance at the headers and keeping the column centered at the firewall cut out. Before finally welding that box to the model A flange, I had to also decide on a drop distance at the dash. But before I could make a proper column drop, I had to take my best guess as to the height and location of my butt, seated in a seat I had not made yet.
    I tacked in a drop that I think should work but we will see..
    8AAA977B-D92E-4F1D-8577-3777EF99A3AE.jpeg 7BA9E840-1C6C-4FB1-860F-D13C2EE59B1F.jpeg
  12. Like that simple wishbone bracket.
    deluxester likes this.
  13. Aaron D.
    Aaron D.
    Coming out really nice. How long have you been working on it? It seems to be coming together very quickly.
    Aaron
  14. deluxester
    deluxester
    I started in January but I just now made the time to start posting. — i wish I could work this quickly!
    Aaron D. likes this.
  15. woodz
    woodz
    Just found this build. This car is going to be amazing. Nice work.
    I also used Havlir House of Fab rear spring perches. He makes some great parts.
    Keep up the good work and thanks for letting us follow along.
  16. akoutlaw
    akoutlaw
    I would like to see the other end of your pcv valve hook up. I was thinking on doing something similar.
    deluxester and 3340 like this.
  17. 100% Matt
    100% Matt
    Nice looking build!
  18. cederholm
    cederholm
    Loving this!! ...and I appreciate the photos of your fabrication work. Saving this thread for reference when I drop an 8BA in my Coupe.
    ~ Carl
  19. deluxester
    deluxester
    I will try to take some photos after work today. The other end is temporarily connected externally to a vacuum port at the intake manifold. The cleaner way to do this is to drill a hole at the bottom side of the manifold but I just couldn’t bring myself to making a new hole in my original PM7.
  20. Just wanted to say I’m deeply impressed by your workmanship! Sitting in the DMV and decided to hop on HAMB, and found this! How close are you to the LA area? I’m in the Santa Barbara county area. Would love to meet up and shoot some high quality pictures next time I’m in the area!
  21. gonzo
    gonzo
    Nice work. Making a decent looking column drop is a lot trickier than it appears at first.
  22. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    I LIKE IT !!!
  23. rjones35
    rjones35
    Awesome!!
  24. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Great build Steve!!!!!!!!
    “Awesome Fabrication”
    Glendora, CALIF.
  25. deluxester
    deluxester
    Hey thanks Kevin. Thanks for all your help with the heads!
    Cyclone Kevin likes this.
  26. deluxester
    deluxester
    So I have a short video on the first startup of that flathead... what is the best way to share it on this thread?
  27. deluxester
    deluxester
    Thanks! I finished up the drop so I’ll try to post some better pics.
    Cyclone Kevin and WTF really like this.
  28. Cyclone Kevin
    Cyclone Kevin
    Alliance Vendor
    Looking forward to grabbing some chow in our roadsters soon!!!!!!
  29. lodaddyo
    lodaddyo
    Looking good! I really enjoyed your videos. I am also building my first Av8, i got everything torn down for paint right now. Ill post an update soon
    deluxester and WTF really like this.
  30. bundybiker
    bundybiker
    from australia
    Great build , and good pics that make things easier to work out,
    gives me some inspiration to get off my butt and start on mine again.
