I have a B' engine in my 31 A, and the outlet from the pump is 2" going into the top tank of a stock radiator. Here is my situation: for me to have someone rod out the core, fill in the original filler neck and then add a pressurized filler elbow on the back side of the top tank so I can run my 32 shell, this amount exceeds the cost of several of the replacement all aluminum radiators sold on e-bay. These are for a 32 shell (1" shorter), they have a 90 degree pressurized elbow on the back side of the top tank, come in either 3 or 4 row design, and would be a great replacement at less than the cost of repairing & modifying my 80 year old original radiator. The only issue I have is that none of the manufacturers will modify the radiators they sell & all of them are 1.5" inlet in the top tanks. Does anyone make a hose reducer from 2" to 1.5", or is there a hose available with a 2" on one end and a 1.5" on the other? What other suggestions might any of you have? Thanks
What about putting a piece of the 1 1/2 inch hose on it them sliding the 2 inch over that and use one clamp?
I seen this done on a Jeep radiator that I modified.. was working well. Sent from my iPhone using The H.A.M.B. mobile app
Done it many times. In fact that's pretty much how those fluted metal radiator hoses do it and those are on COUNTLESS hot rods.
You can go 1/4 inch pretty easy with the spacer hose between the inlet and the hose but 1/2 inch may be a bigger jump than is advisable. Here= for 13 bucks and shipping this may be the most viable solution. it is stainless and 4 inches long. https://www.fillernecksupply.com/1-1-2-to-2-fuel-filler-hose-reducer-stepped-joiner-adapter-38-51mm/
How about a metal tube upper? Can make the shape you want and either end can be sized how you need it. Something like this: SPark
Fantastic ideas and solutions to a simple problem. For now the best direction will be the stainless tube reducer from Fillerneck Supply and then get back to all of the dealers on ebay for their radiators listed. I need them to supply me with their mounting bracket measurements: heights - widths - offsets , so I can make a good choice.. Aganin, thanks to everyone for your help. Steve
I agree 200%. When they first told me about these, I was thinking "Ya, right! That things going to leak like hell!. Well, I was wrong! ( 2nd time this year). They work great, they're cheap, you don't really see them, and you don't need a pile of clamps to hold it together. I get them from NAPA, but any auto parts store will probably have them.
